Thermal expansion coefficient of a Debye solid
In summary, the thermal expansion coefficient of a solid, δ, is defined as the derivative of volume with respect to temperature, divided by the volume. In the Debye model and at low temperatures, δ is a positive quantity and is proportional to the cube of temperature. At high temperatures, δ is still positive but is independent of temperature. The Debye model can be used to solve for δ in this scenario.
Catria
152
A solid's thermal expansion coefficient is defined as
δ= [itex]\left(\frac{1}{V}\frac{∂V}{∂T}\right)[/itex]
In the Debye model and at the low-temperature limit, show that δ is a positive quantity and is proportional to [itex]T^{3}[/itex]. At the high-temperature limit, show that δ is still positive but does not depend on temperature anymore.
I don't even know how to express volume as a function of temperature!
I'm pretty sure this is supposed to be done using the Debye model, but I'm not sure how to apply it here. Any help is appreciated!
Related to Thermal expansion coefficient of a Debye solid
1. What is the thermal expansion coefficient of a Debye solid?
The thermal expansion coefficient of a Debye solid is a measure of the change in size or volume of the solid as its temperature changes. It is typically denoted by the symbol α and is expressed in units of length per unit temperature (e.g. m/K or mm/°C).
2. How is the thermal expansion coefficient of a Debye solid calculated?
The thermal expansion coefficient of a Debye solid can be calculated using the equation α = (1/V) * (dV/dT), where V is the volume of the solid and dV/dT is the change in volume with respect to temperature. This calculation can also be expressed in terms of the linear coefficient of thermal expansion (αl) and the bulk modulus (B) as α = (1/3) * (αl * B).
3. What factors affect the thermal expansion coefficient of a Debye solid?
The thermal expansion coefficient of a Debye solid is affected by various factors such as temperature, pressure, and the crystal structure of the solid. In general, higher temperatures and pressures lead to a larger thermal expansion coefficient. The crystal structure of the solid also plays a role, with different crystal structures exhibiting different thermal expansion coefficients.
4. How does the thermal expansion coefficient of a Debye solid relate to its heat capacity?
The thermal expansion coefficient of a Debye solid is directly related to its heat capacity. This is because both properties are influenced by the same factors, such as temperature and crystal structure. In particular, the thermal expansion coefficient is related to the heat capacity at constant volume (Cv) through the equation α = (1/V) * (dV/dT) = (αl * B) / (3 * Cv).
5. Why is the thermal expansion coefficient of a Debye solid important in materials science?
The thermal expansion coefficient of a Debye solid is an important property in materials science because it can affect the performance and reliability of materials in various applications. For example, a high thermal expansion coefficient can lead to thermal stress and cracking in materials, while a low thermal expansion coefficient can be beneficial for maintaining dimensional stability in precision instruments and electronic devices.
  • Mechanical Engineering
