AriAstronomer
- 48
- 1
A cylinder, A, having Va=30L, is connected to a second cylinder B, of circular cross section. Cylinder B is fitted with a piston of radius = 5cm, which slides without friction/leaking. Initially A contains an ideal monatomic gas, in addition, Pa = 10MPa, Ta = 300K, Vb = 0 and the compression force on the spring is zero. The spring, obeying Hooke's law has a force constant of 10^5N/m. The valve, V, is opened slowly and gas leaks from A to B, compressing the spring. Equilibrium is eventaully established again at a temperature of 300K throughout all parts of the system. Neglect the volume of the connecting pipe (between A and B).
a) Calculate the distance by which the spring is compressed in the final equilibrium state.
Vtotal = Vo - xA where x is the distance the piston has moved.
F=PA = -kx
So the answer in the book is .6684m. But I keep getting .7854m:
Vtotal = 30L - xA = .03m^3 - xA
Thus: x = (.03m^3 - V)/A
plug into PA = -kx and solve for V, which I get Vtotal = .02383m^3.
Then plug Vtot back into original Vtot equation and get
x = .7854m.
But the answer in the back says .6684m
Any help would be appreciated.
