*Thermodynamics*: Adding air to a bottle, finding internal energy and so on
In summary: For part e, where there is a slow leak in the cap, the process can be represented by a curve on the PV diagram, as you correctly stated. This curve will be a horizontal line followed by a downward sloping curve, as the pressure decreases due to the leak, and then the gas does work on the atmosphere as it expands.I hope this summary has helped clarify the concepts and calculations involved in this process. Remember, when the lid pops off, it is an isobaric process, and when there is a slow leak, it is a combination of isobaric and isochoric processes. Keep practicing and asking questions, and you will become an
jolierouge
In class we saw a demo where a pop bottle was pumped up with extra
air. If we consider the bottle was pumped up to a gauge pressure of 50 psi and let sit until
it returns to room temperature. Describe what happens when the air is rapidly released (for
example if the top suddenly popped off ). Treat this as a change in the volume the gas occupies
not as a change in the number of moles of gas in the bottle.
(a) What kind of process is this? Sketch a PV diagram.
(b) Is there a change in internal energy, and if so, what sign does it have?
(c) Calculate the temperature of the gas when all the excess pressure is released (i.e. the gas
returns to atmospheric pressure).
(d) How much work was done, heat transferred and change in internal energy of the gas that
was contained in the bottle?
(e) If instead there had been a slow leak in the cap, what would the change in internal energy
have been? Add a dashed line to your PV diagram to represent this process.
Volume of the bottle is 2L
Pi=gauge pressure of 50psi=516630Pa
Pf=1psi=101300
T1=293K
n=constant
R=8.3145J/mol*K
PV=nRT
ΔU=nCvΔT
ΔQ=ΔU+ΔW
ΔW=PΔV
a) I think the first process is isochoric (vertical line) because the volume of the bottle stays the same and there is air being pumped into it (causing pressure to skyrocket) I don't know how to show that they let it cool to room temperature and what happens when pressure is released. What I don't get is when they say treat this as a change in volume when the lid comes off. (Is volume continuously expanding?)
b) internal energy is positive because all energy added as heat remains in the system. (kinda unsure about this)
c)
I can find the number of moles in this system which is (516630*0.002)/(8.311451*293)=0.42mol
After that I don't know what to do
d) Can't figure out c so I didn't think I could figure out this one
e)Because there is a leak volume increase and pressure decrease (it will be a curve on the graph right?)
My main problem is the part where the lid comes off and what volume it becomes and how to treat this when I am doing my calculations.
Any nudge in the right direction would be awesome!
Thank you for sharing your thoughts and questions on this topic. I can provide some insights and guidance to help you understand this process better.
Firstly, let's start with the type of process that occurs when the lid suddenly pops off. This is known as an isobaric process, where the pressure of the gas remains constant while the volume changes. This is because the air inside the bottle is now in contact with the atmosphere, which has a constant pressure of 1 psi. So, the pressure inside the bottle will also equalize to 1 psi.
To better understand this process, let's look at a PV diagram. In an isobaric process, the graph will be a horizontal line, as the pressure remains constant. See the attached diagram for reference.
Now, moving on to the change in internal energy. As you correctly stated, internal energy is positive because all the energy added as heat remains in the system. When the lid pops off, the gas expands and does work on the atmosphere. This means that the gas loses some of its internal energy, resulting in a decrease in temperature. This can be represented on the PV diagram by a downward sloping curve, as shown in the attached diagram.
To calculate the temperature of the gas when all the excess pressure is released, we can use the ideal gas law, PV = nRT. We know the initial pressure (Pi), volume (Vi), and number of moles (n) of the gas. We also know the final pressure (Pf) is 1 psi, and we can calculate the final volume (Vf) using the equation PfVf = PiVi. Plugging all this information into the ideal gas law, we can solve for the final temperature (Tf).
Now, let's move on to the calculations for work, heat transferred, and change in internal energy. As the gas expands, it does work on the atmosphere. This means that the gas is losing energy, resulting in a decrease in internal energy. This can be represented on the PV diagram by a downward sloping curve, as shown in the attached diagram. To calculate the work done, we can use the equation W = PΔV, where P is the constant pressure of 1 psi, and ΔV is the change in volume (Vf - Vi).
To calculate the heat transferred, we can use the equation ΔQ = ΔU + ΔW. As we know
Related to *Thermodynamics*: Adding air to a bottle, finding internal energy and so on
1. How does adding air to a bottle affect its internal energy?
When air is added to a bottle, the internal energy of the system increases. This is because the air molecules have kinetic energy and adding more air means increasing the total number of molecules and their overall kinetic energy. This increase in internal energy can also lead to an increase in temperature.
2. What is the relationship between pressure and temperature in a bottle with added air?
According to the ideal gas law, the pressure and temperature in a bottle with added air are directly proportional. This means that as the pressure increases due to the added air, the temperature will also increase. However, this relationship may not hold true for all systems and depends on factors such as volume and the type of gas added.
3. Can adding air to a bottle lead to a change in its volume?
Yes, adding air to a bottle can lead to a change in its volume. As more air is added, the volume of the bottle will increase due to the increased number of gas molecules. This change in volume can also lead to a change in pressure and temperature within the bottle.
4. How does thermodynamics explain the process of adding air to a bottle?
Thermodynamics explains the process of adding air to a bottle by considering the principles of energy conservation and the behavior of gases. When air is added to a bottle, the system's internal energy increases, and this leads to changes in pressure, volume, and temperature. These changes can be explained using thermodynamic equations and laws.
5. Is it possible to remove the added air from a bottle and return it to its original state?
Yes, it is possible to remove the added air from a bottle and return it to its original state. This process can be achieved through various methods such as compressing the air, cooling it to reduce its volume, or using a vacuum pump to remove the air. However, due to the irreversible nature of some processes, it may not always be possible to return the bottle to its exact original state.
