- #36
berkeman
Mentor
- 67,248
- 20,232
Frabjous said:We general like physics to be frame independent.
https://www.thegeneral.com/about/contact/
Then they would both be frictionless surfaces to one another and there would be no coefficients of friction between them.Frabjous said:What if I heated the ”hard” plate so that it became the ”soft” plate?
No, there would still be friction between them.jaketodd said:Then they would both be frictionless surfaces to one another and there would be no coefficients of friction between them.
I'm sorry; I thought you meant that the plates would be separate.Frabjous said:No, there would still be friction between them.
There are also adhesive forces so probably not.jaketodd said:I'm sorry; I thought you meant that the plates would be separate.
But in discrete space and discrete bodies, there will always be friction, because there is a smallest unit, always a "roughness." But if possible, continuous for both, I suppose total frictionless is possible, at least in theory.
I suppose in discrete space, smallest units, it's possible for there to be perfect smoothness, but not if near a gravitating body, because then all the quanta would not match up perfectly. Warped discrete spacetime.Frabjous said:There are also adhesive forces so probably not.
Or chemical bonding.jaketodd said:Adhesive forces, good point, like gravity of the two surfaces, however weak
