Time Dilation Formula: Clarifying Confusion
Grimble
I know that this is a very basic question but what is the correct formula for time dilation?
In Wikipedia etc. I read {t^'} = \gamma {t} or at least \Delta{t^'} = \gamma {\Delta{t}}; yet in this http://en.wikipedia.org/wiki/Twin_p...t_of_differences_in_twins.27_spacetime_paths" 'phase 2' and 'phase 5' imply that the formula is {t^'} = \frac {t}{\gamma}.
Also, if a moving clock is seen to 'go slow' by a stationary observer, then one would expect that less time would be seen to pass in the transformed time, and {t^'} = \frac {t}{\gamma}seems to me to fit that scenario.
I have been looking at this for some time on the internet but, taking heed of the warnings I have been given about believing all I read on there, I have followed the arguments and read the 'derivations' and suchlike, but have a problem:
Whichever way I approach it the formula appears to be the latter viz. {t^'} = \frac {t}{\gamma} in the same way that {x^'} = \frac {x}{\gamma} the formula for length contraction.
where:
t is the time on the stationary observer's local clock and
t' is the traveling clock's time, transformed by the Lorentz transformation formulae.
Or are there different formulae applied in different circumstances.
We talk of time dilation - expansion(?) yet also about the moving cock slowing (less time passing)?
:confused::confused::confused:
In a moving system time seems to go slower while objects seem to get longer. As
\gamma = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}} > 1
for v > 0, the correct formula for time dilation must be
t' = \frac{t}{\gamma}
from which follows
t' < t
e.g. when t minutes has passed in the rest system only t' has passed in the moving system meaning that times moves slower in the moving system.
The length contraction formula must be
x' = x \gamma
as the length of an object in the moving system appears to be contracted and not dilated.
I hope this sorted out your confusion. Of course this answer is not a derivation of the equations - this is just my line of thought when I forget when to multiply/divide by \gamma :wink:
I often go through the same thinking as dianaj. It definitely helps to remember that \gamma > 1.
where:
To a "stationary" observer, a clock moving relative to him will appear to run at a slower rate than his. If we call the time between ticks on the "stationary" clock as observed by the "stationary" observer one second, then the time between ticks on the "moving" clock as measured by the "stationary" obsever will be greater than one second, and so in this sense the time in the "moving" frame as observed from the "staionary" frame could be described as expanded. That is, the time between ticks appears to be longer. The term dilated is normally used rather than expanded . So in a certain time as measured by the "stationary" observer on his own clock he oberves a smaller number of ticks on the "moving" observer's clock. More observed time between ticks is taken to mean time passing more slowly, and so the time observed in the "moving" frame by the "stationary" observer can be said to be passing more slowly. I expect you already knew all this but were unhappy with the terminology.
As for time passing more slowly or being dilated, there is no absolute time. For an ideal clock, elapsed time IS the time measured by a comoving observer counting the ticks. Time IS the ticks. To any inertial observer the time elapsed on HIS clock is THE elapsed time, or proper time. For this observer, his own physical time rates never alter.
Matheinste.
Matheinste.
Thank you, one and all, for your inputs.
It is interesting, Dianaj, and Diazona, that you have the two formulae the opposite way round to Wikipedia, whereas I am inclined to think that you each have one right! Confusing isn't it, a slippery thing to keep one's finger on.
You give a nice summary of the problem, Matheinste: there is no Absolute time – agreed; and time is in the eye of the beholder, if I may paraphrase you. o:)
The big difficulty I see is how to describe 'faster' and 'slower' in time when are we counting the 'clicks' but have no agreement on the size of the clicks.
For instance, one clock may be slower than the other yet record the same number of clicks.
Let me refer you to Einstein's 1920 paper: 'Relativity: The Special and General Theory.'
and in particular to chapter XII. - http://www.bartleby.com/173/12.html" where he derives a formula for the time in the stationary system K when {t^'} = 1 of
t = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}
in which {t^'} has been replaced by 1 and which we would write:
t = \frac{t^'}{\sqrt{1 - \frac{v^2}{c^2}}}
He then goes on to state:
'As judged from K, the clock is moving with the velocity v; as judged from this reference-body, the time which elapses between two strokes of the clock is not one second, but
seconds, i.e. a somewhat larger time. As a consequence of its motion the clock goes more slowly than when at rest.'
But, consider just what he is saying here: the time t is the time in system K, the stationary system and is, therefore, 1 second proper time, but the time {t^'} is the time from the system {K^'} transformed into co-ordinate time (as we refer to it).
So where Einstein says that the clock slows one could just as easily say, that the time of system {K^'} has been 'shrunk' or 'contracted' by the transformation such that one second proper time, system K, is now equal to
seconds co-ordinate time, which is greater than one.
So 1 second proper time in system {K^'} (measured in system {K^'} it is in an inertial frame of reference) upon transformation becomes only \frac{1}{\frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}} seconds.
So one might say that it has slowed down as the same duration now measures less elapsed time, or, that the units of time have shrunk and that time now passes faster!
It all depends on what one is comparing, number of units or size of units.
My personal preference would be to say that when transformed by the Lorentz equations, the units of time become smaller.
:confused:
When you compare your clock to a moving clock, the moving clocks units, that is time between ticks, as measured by you, appears to you to be longer than those on your clock. Because number of ticks and length between ticks are inversely proportional, the moving clock will appear to you to have experienced less ticks compared to your clock.
Time dilation refers to the lengthening of the distance between ticks, compared with your clock, of a clock moving relative to you as observed by you. So comparative length between ticks in the frame moving relative to you, appears to you to be longer, or dilated, That is time dilation. But the comparative number of ticks in the frame moving relative to you as observed by you appears to be decreased, that is smaller, not dilated, when compared to your clock. This is true for any observer when observing another clock moving relative to his.
Of course if you interchange the roles of the observers and let the obvserver who was considered to be moving, now consider himself, quite legitimately for the present pupose, to be at rest, then he will consider the other clock to be slower than his. All clocks moving relative to any observer will be observed by him to run slower than his own.
Matheinste.
Matheinste.
Let us take an example of time dilation; if we say that for a clock moving at 0.8c, for each second that passes and is indicated on that clock, how much time, (time dilated), will the stationary observer see pass?
Now if we put the appropriate figures into the formula for time dilation t = \gamma {t^'}
where:
t = the proper time for the inertial observer.
v = 0.8c
t' = co-ordinate time in the moving clock's frame
\gamma = \frac {1}{\sqrt{1 - {\frac{v^2}{c^2}}}} = 1.67[/itex]<br /> <br /> then t = 1.67 {t^&amp;#039;} &lt;br /&gt; &lt;br /&gt; So 1.67 seconds on the moving clock is equivalent to 1 second on the observer&amp;#039;s clock, i.e. less time is seen to pass by the observer, the clock slows.&lt;br /&gt; &lt;br /&gt; But if the moving clock has &amp;#039;ticked&amp;#039; (one second ticks) 1.67 times for each of the observer&amp;#039;s seconds then is it not ticking faster in the observer&amp;#039;s frame of reference?&lt;br /&gt; &lt;br /&gt; And, in the infamous Twin Paradox, would the traveling twin not have aged 16.7 years in his frame of reference, while only 10 had passed for his sedentary sibling? And would that sibling not, therefore, see his brother aging faster than himself?&lt;br /&gt; &lt;img src=&quot;https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png&quot; class=&quot;smilie smilie--emoji&quot; loading=&quot;lazy&quot; width=&quot;64&quot; height=&quot;64&quot; alt=&quot;:confused:&quot; title=&quot;Confused :confused:&quot; data-smilie=&quot;5&quot;data-shortname=&quot;:confused:&quot; /&gt;&lt;img src=&quot;https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png&quot; class=&quot;smilie smilie--emoji&quot; loading=&quot;lazy&quot; width=&quot;64&quot; height=&quot;64&quot; alt=&quot;:confused:&quot; title=&quot;Confused :confused:&quot; data-smilie=&quot;5&quot;data-shortname=&quot;:confused:&quot; /&gt;&lt;img src=&quot;https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png&quot; class=&quot;smilie smilie--emoji&quot; loading=&quot;lazy&quot; width=&quot;64&quot; height=&quot;64&quot; alt=&quot;:confused:&quot; title=&quot;Confused :confused:&quot; data-smilie=&quot;5&quot;data-shortname=&quot;:confused:&quot; /&gt;
Grimble said:
So 1.67 seconds on the moving clock is equivalent to 1 second on the observer's clock, i.e. less time is seen to pass by the observer, the clock slows.
You have
t&#039; \cdot 1.67 = t
and so
t&#039; = 1s \Rightarrow t = 1.67 s
The time passed describes an event: the 'hand' on the clock moving from on place to another, one second passing. According to the observer this event event takes 1.67 sec's. But according to the moving clock it only takes 1 sec. Therefore time must go slower for the moving clock (after, say, 100 of these events, the moving clock will have aged 100 secs while the observer will have aged 167 secs).
It's a good idea to think of t as \Delta t: as a time interval describing an event. Usually solves my problems, when I get confused. :smile:
In every case you need to make clear who is making the observation and which clock they are observing.
"for each second that passes and is indicated on that clock" as observed by who?
" how much time, (time dilated), will the stationary observer see pass?" on which clock?
Matheinste.
dianaj said:
You have
and so
Yes but, t' has been transformed and is in co-ordinate units and t, being in the inertial observer's frame of reference is in proper units.
So what we are saying in your first equation is that 1.67 co-ordinate seconds are equal in duration to 1 second of Proper time at the current velocity.
So really the proper time seconds (as seen by an observer traveling with the clock) have shrunk when transformed at 0.8c such that it takes 1.67 of them to have the same duration as 1 second proper time as measured from the observer's inertial frame of reference.
OK, my friend, I will restate it:
Let us take an example of time dilation; we will take a clock in an inertial reference frame, moving at 0.8c relative to an observer in another inertial reference frame. Then for each second that passes in the moving clock's reference frame, how much time, (which will be time dilated), will the remote observer see pass from his reference frame?
As would be seen by a local observer in the clock's reference frame.
A very good question, for the moving clock observed in its own reference frame (i.e. by a local observer) will be displaying 1 sec Proper time. And the remote observer's clock (relative to which the moving clock is traveling at 0.8c) will also be shewing 1 sec (and it will also be displaying Proper time). The dilated time is the moving clock's proper time transformed into co-ordinate time in the remote observer's frame of reference. But his clock will be displaying HIS local (proper) time.
So you seem to have highlighted another conundrum, on which clock could the transformed time be displayed? One might think that it would be the moving clock as observed by the remote observer, but, if it were a clock with hands (as is often supposed) then how could the remote observer read anything but the position of the hands? It is after all the units of time that have changed (from proper time to coordinate time) not the hands of the clock.
Maybe the observer has another clock set to co-ordinate time?
Or is the difference in time exactly that: a difference in the units of time and the clocks would all read the same but be measuring different units of time.
That is to say both observer's read 1 second on the moving clock, but the 1 second the observer moving with the clock reads (proper time), is equal in duration to 1.67 of the second the remote observer reads (co-ordinate time).
Grimble said:
OK my friend, I will restate it:
First, remeber that there is no "moving" or "stationary" clock, just two clocks moving relative to each other. As they are at rest in inertial frames they can each, for the sake of simplicity consider themsemselves to be at rest and the other moving.
Next, you must take into account the relativity of simultaneity.
Let the two clocks be colocated at the origin and there be set to both read zero (as your transformation equations imply). They will of course at this point read zero simultaneouly for both observers. However, the time when the clock of the observer who considers himself at rest reads one second IS NOT simultaneous , in his own frame, with the time when he observes the other clock read 1 second. The time of greater than 1 second shown on the clock of the observer at rest IS simultaneous, in his frame, with the time when he observes the moving clock reading 1 second. That is, to the observer at rest the other clock appears to be running slow. Of course the reciprocal case also applies.
Matheinste.
Yes, exactly, that confirms my understanding. Thank you.
And this too is exactly my understanding, for the other clock's time has been transformed.
Matheinste.
This last part is what Einstein described in the following section of his paper: “Relativity: The Special and the General Theory”.
In chapter XII. “The Behaviour of Measuring-Rods and Clocks in Motion” he writes:
Let us now consider a seconds-clock which is permanently situated at the origin (x' = 0) of K'. t' = 0 and t' = 1 are two successive ticks of this clock. The first and fourth equations of the Lorentz transformation give for these two ticks:
t = 0
and
:confused:But if t is the time shewn on the observer's clock then it is in the (proper?) seconds of an inertial frame of reference.
Whereas the
is surely the equivalent time in transformed (co-ordinate?) seconds.
So one second on the observer's clock would be simultaneous with
transformed seconds on the other clock.
And the transformed seconds are smaller (contracted) and consequently they pass quicker and so the other clock will be seen to be speeded up, not slowed?
And is not what is shewn on Minkowski diagrams?
And thank you once again for all your help,
Grimble.
Whereas the
Grimble.
Hello Grimble.
The last part should read
-----So one second on the observer's clock would be simultaneous with //www.bartleby.com/173/M5.GIF[/PLAIN] transformed seconds on the other clock.
And the transformed seconds are LONGER. -----
If you interchange observers you get exactly the same result.
We have {t}^{&#039;} = \gamma t and so the transformed seconds are greater in length than the "stationary" observer's seconds. Then for the inverse transform cosidering the frame in which the other observer is "stationary" and {t}^{&#039;} is his time intrerval we have {t}= \gamma {t}^{&#039;}
Where
\gamma =
and is \geq 1
Matheinste
Hello again matheinste and apologies for the delay.
I'm sorry, but how can the transformed seconds be longer, when one second on the observer's clock would be simultaneous with
transformed seconds on the other clock?
For
is >1
Agreed.
But surely, the formula that Einstein has derived:
when {t^&#039;} = 1 gives us {t} = \gamma {t^&#039;}
No, they must be shorter in length.
Where
\gamma =
and is \geq 1
Matheinste
I'm sorry and mean no disrespect to you, but I think that while changing labels to shew reciprocality is fine if those labels are arbitrary, it is inadvisable to do so where the labels have been given particular meanings.
In this case t^{&#039;} was appropriated by Einstein to denote the transformed co-ordinates. But that is purely my own view.
Grimble.
Hello Grimble.
I really have nothing to add.
Matheinste
Grimble:
Try writing down the full coordinates for each event of interest, in each frame. Einstein didn't do that in his book (at least I don't remember him doing so), but it might help, since it will show explicitly how the formulas work out.
We have a clock at the origin of the system K'. Two successive ticks of that clock have coordinates, in K', of:
Tick 1: x' = 0, t' = 0.
Tick 2: x' = 0, t' = 1.
Now transform into the system K. The two events now have coordinates:
Tick 1: x = 0, t = 0 (by definition; this is where the origins of the two systems cross).
Tick 2:
x = \gamma \left( x&#039; + v t&#039; \right) = \gamma v,
t = \gamma \left( t&#039; + v x&#039; \right) = \gamma.
So a time interval that "looks like" 1 in system K', "looks like" \gamma in system K. We can interpret this as saying that the clock at rest in K' is "running slow" with respect to K, because viewed from K, the time between two successive ticks of the clock at rest in K' is \gamma instead of 1.
Here is a very specific real-world test. BNL (Brookhaven Nat. Lab.) physicists stored muons with γ=29.4 in a circular ring. The muon's lifetime at rest is about 2.2 microseconds. In the ring, their lifetime was about 65 microsecons in the lab reference frame.
Bob S
Be aware that many (most?) texts take the word dilation in the opposite sense to Matheinste’s “Time dilation refers to the lengthening of the distance between ticks, compared with your clock, of a clock moving relative to you as observed by you.” For example, in Spacetime Physics (p. 66, problem 10), Taylor and Wheeler explicitly state that by time dilation they mean an increase in the number of seconds: “This time lapse is more than one meter of light-travel time. Such lengthening is called time dilation. To dilate means to stretch.” Presumably everyone who presents the relation in the form
\Delta t&#039; = \gamma \Delta t
and calls this “time dilation” is going by Taylor and Wheeler’s interpretation. Of course, this is just a matter of words.
Now if we put the appropriate figures into the formula for time dilation t = \gamma {t^&#039;}
where:
v = 0.8c
&lt;br /&gt; &lt;br /&gt; You identify &lt;i&gt;t&lt;/i&gt; as &amp;quot;the proper time of the inertial observer&amp;quot; and &lt;i&gt;t&amp;#039;&lt;/i&gt; as &amp;quot;co-ordinate time in the moving clock&amp;#039;s frame&amp;quot;, but our input--the information we actually have (this one second)--is the time between the clock&amp;#039;s ticks in the clock&amp;#039;s rest frame.&lt;br /&gt; &lt;br /&gt; The time between the clock&amp;#039;s ticks in the clock&amp;#039;s rest frame is the proper time between these events. That&amp;#039;s the co-ordinate time between them in the clock&amp;#039;s rest frame. Proper time is co-ordinate time between events in a frame where they happen in the same place.&lt;br /&gt; &lt;br /&gt; The value we want to calculate (our output) is the co-ordinate time between ticks with respect to an inertial frame in which the clock is moving at 0.8c, so we need to multiply one second by gamma to find the (longer) amount of time that will have passed between ticks in the frame where the clock is moving, namely 5/3 = 1.667 seconds for every tick of the moving clock. The proper time between two events is always shorter than the co-ordinate time between them in a frame where they don&amp;#039;t happen in the same place.&lt;br /&gt; &lt;br /&gt; Equivalently, we could refer to the time we&amp;#039;re trying to calculate as the proper time between two events, one of which is simultaneous, in the frame where the clock is moving at 0.8c, with one tick of the clock, and the other of which is simultaneous, in the frame where the clock is moving at 0.8c, with the next tick of the clock. There&amp;#039;s no paradox because in the clock&amp;#039;s rest frame (the frame where it isn&amp;#039;t moving)--where these two events happen in different places--even if we arrange for the first event to be simultaneous with a tick of the clock, the other won&amp;#039;t be simultaneous with the next tick of the clock but rather will still lie in the future when the clock shows one second.
Rasalhague said:
Be aware that many (most?) texts take the word dilation in the opposite sense to Matheinste’s “Time dilation refers to the lengthening of the distance between ticks, compared with your clock, of a clock moving relative to you as observed by you.” For example, in Spacetime Physics (p. 66, problem 10), Taylor and Wheeler explicitly state that by time dilation they mean an increase in the number of seconds: “This time lapse is more than one meter of might-travel time. Such lengthening is called time dilation. To dilate means to stretch.” Presumably everyone who presents the relation in the form
I am sure that ALL authors agree on their use of the term "time dilation". If I appear to use it in the opposite sense then it is wrong of me to do so and my explanation of what I believe them to be saying is flawed. Perhaps one source of some confusion for you may be my use of the words "distance between ticks". This does not refer to the spatial distance traveled by light between ticks.
Matheinste.
I gathered that you meant the temporal distance (amount of time) between ticks.
Incidentally, Taylor and Wheeler refer to "light-travel time" in that quote just to clarify the significance of their use of meters (rather than seconds) as a unit of time.
Just for clarification. By time dilation I mean the effect whereby an observer at rest with respect to inertial frame looking at his own clock and observing it give its first tick has to wait before he observes a clock, at rest in a reference frame moving inertially withh respect to him, give its first tick, both clocks having been set to zero when they are colocated in passing and light travel time having been allowed for. The "stationary" observer describes the "moving" clock's time as dilated. If this is in disagreement with the normal use of the term I apologise and will go back to basics.
Matheinste.
If the expression time dilation appeared in isolation, my intuition could go either way, but because it usually appears as a verbal label for the formula
\Delta t&#039; = \Delta t * \gamma
and because time dilation so often appears alongside "length contraction", typically presented as the inverse of this--which is to say, a formula for deriving a smaller number from a bigger one--I assumed dilation must refer the opposite process, that of deriving a bigger number from a smaller one; otherwise, why not give the same name to the same process? In Spacetime Physics, Taylor and Wheeler clearly take dilation to mean obtaining a bigger number. Tipler and Mosca likewise: "The time interval measured in any other reference frame is always longer than the proper time. This expansion is called time dilation" (Physics for Scientists and Engineers: 5th ed., extended version, p. 1272).
Similarly Lerner: "The interval delta t_0, read by an observer with respect to whom the clock is at rest, is called the proper time. The interval delta t_v is called the dilated time" (Modern Physics for Scientists and Engineers, p. 1053).
http://books.google.co.uk/books?id=Nv5GAyAdijoC&pg=PA1053#v=onepage&q=&f=false
Similarly Schröder: "In the lab system, one measures a dilated time interval for the half life: t' = t gamma" (Special Relativity, p. 42).
http://books.google.co.uk/books?id=sLQ1rSNUjYAC&pg=PA42#v=onepage&q=&f=false
Similarly Petkov: "He projects the event A onto the event A' and finds that the time component [...] is greater than t [...] In S the clock worldline lies along the time axis and has only a time component ('height'); that is why the S-observer measures the proper length of the clock worldline, which we called proper time. In S' the worldline of the clock at rest in S is inclined and thus has both temporal and spatial components. That is why the S' observer measures an apparent or dilated time" (Relativity and the Nature of Spacetime, p. 88).
http://books.google.co.uk/books?id=ZA-yvXu40e0C&pg=PA88#v=onepage&q=&f=false
Fishbane et al. might be interpreting it the other way around: "Time T' is greater than T by a factor of gamma. The observer in frame F' sees longer ticks for the clock; in other words, the moving clock is slower by a factor of gamma. This effect is known as time dilation" (Physics for Scientists and Engineers, 2nd ed., extended, p. 1084). But this looks ambiguous to me. What exactly they're thinking of as being dilated depends on what "this" refers to: the fact of T' being "greater than" T, or the fact of there being "longer ticks" (causing T to be less than T').
Lawden apparenty takes dilation in the opposite sense to Taylor and Wheeler:
\Delta t&#039; = \frac{\Delta t}{\gamma}
"This equation shows that the clock moving with O' will appear from S to have its rate reduced by a factor gamma. This is the time dilation effect" (An Introduction to Tensor Calculus, Relativity and Cosmology, 3rd ed., p. 13.)
In Simple Nature, Benjamin Crowel doesn't address the issue directly, as far as I can see, but one sentence might suggest that he takes dilation and contraction as synonymous in this context, contra Taylor and Wheeler:
"length contraction occurs in the same proportion as time dilation"
http://www.lightandmatter.com/html_books/0sn/ch07/ch07.html
Online sources are divided on the matter. I'm not sure if there's a tendency either way among the reputable ones. For example, here's one in agreement with Taylor and Wheeler:
"That equation tells me that if the passengers on the train measure so many seconds between two events, then I will measure a larger number of seconds between the same events. That's what it means to say that the train's clock counts dilated time."
http://bado-shanai.net/Map of Physics/moptimedil.htm
And here's one against:
"A clock in a moving frame will be seen to be running slow, or dilated according to the Lorentz transformation."
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/tdil.html
The Wikipedia article "Time dilation" also conceives of dilation in the opposite way to Taylor and Wheeler, e.g. "Symmetric time dilation occurs with respect to temporal coordinate systems set up in this manner. It is an effect where another clock is being viewed as running slowly by an observer. Observers do not consider their own clock time to be time-dilated, but may find that it is observed to be time-dilated in another coordinate system." And "as observed from the point of view of either of two clocks which are in motion with respect to each other, it will be the other clock that is time dilated."
http://en.wikipedia.org/wiki/Time_dilation
In psychology, subjective time dilation can refer to the perception of more time passing than is shown by a physical clock. A completely different phenomenon, of course, nothing to do with relativity, but perhaps this is what people new to relativity instinctively think of when they first encounter the term time dilation. For example, in this paper, the "dilation" of durations is synonymous with the perception of time passing slower than it would normally (which could be thought of as a greater number of subjective time units passing than physical time units as measured by a clock, i.e. a longer/expanded/dilated subjective time compared to clock time), but because we naturally take our subjective sense of time as the standard, we tend to think of such effects as being like a clock slowing down, rather than our minds speeding up, and for that reason perhaps the word dilation connotes slowing down.
http://www.plosone.org/article/info:doi/10.1371/journal.pone.0001264
(The actual psychological process, as the paper discusses, is more subtle than that, since not all time-dependent perceptions are affected in the same way.)
Hello again Rasallhague,
I think we are agreed that dilation means becoming larger. But what becomes larger is not the number of ticks of a clock but the relative temporal length between ticks. Take two observers, A and B, in relative inertial movement with respect to each other. A will observe B's clock running slow compared to his own. B will observe A's clock running slow compared to his own. If A counts a number of ticks on his own clock then he observes LESS ticks on B's clock. This is because one second as seen by A on his own clock occupies less than one second on B's clock as seen by A. And vice versa. If that intrerpretation is wrong then I have a serious problem with my basic understanding of relativity because all texts that I have read lead me to this interpretation and none of the knowledgeable regulars on the forum have pulled me up on it.
You give many examples of authors and what they say. When interpreted correctly, whether agreeing with me or not, I am sure that all authors of relativity texts are saying the same thing. There is no room for disagreement among them on something so basic which has consequences for any further study of the subject (including the twins). We are of course not talking about psychological or subjective time.
Matheinste.
Bob S
Very interesting, I was unaware of this experiment; but it is good to know that it supports my contention.
For this demonstrates the correctness of t = γt'
i.e. that 2.2 proper microseconds = 'about' 65 co-ordinate microseconds
where the muon's lifetime at rest, 2.2 microseconds (poper time) is equavalent to the muon's lifetime when moving, 'about' 65 microseconds (co-ordinate time), according to the Lorentz transformation.
Hi there, Matheinste,
It looks to me as though there could well be some disagreement among those quotes, not on the facts of special relativity, of course, just on what exactly they take "dilation" to refer to, or how they conceptualise it. I may be mistaken and the difference only apparent, but it does seem that "dilated time" can mean a bigger number to one author, and a smaller number to another author. I'd be interested to know what our resident experts think on the matter too. Mostly the textbooks, in particular Schröder, Lerner and Petkov who contrast "dilated time" with "proper time", take the dilated thing to be the bigger number. But quotes like Lawden's or the website that said, "A clock in a moving frame will be seen to be running slow, or dilated according to the Lorentz transformation", or the Wikipedia article do appear to be taking it the opposite way, and consider a "dilated time" to be the smaller number shown by a moving clock whose units have been dilated (made bigger) in comparison to a stationary clock. It would be nice if they did agree, and the more authorative sources we've found so far do mostly lean towards the bigger number interpretation, but I wouldn't be surprised if some equally reputable sources thought of it the opposite way round (a bit like the way some authors take their space coordinates as negative and their time coordinate as positive, while others take time as positive and space negative, or like the way some authors use phi and theta the opposite way round to others to label the angles in spherical polar coordinates).
I only mentioned the psychological usage to compare how the similar issue of comparing two rates of time is treated there, and because I thought perhaps it might offer a clue as to how we insinctively think about such things: hence what people are most likely to think time dilation refers to when they first hear of it in the context of relativity.
Then again, when you say, "But what becomes larger is not the number of ticks of a clock but the relative temporal length between ticks", perhaps there isn't such a contradiction; after all, how do we express the idea that the duration (time interval) between the ticks of one clock is longer than the corresponding duration as measured by another clock if not by counting the greater number of ticks on the other clock?
Hello Rasallhague.
I see that there may have been some initial confusion (caused by me) over different uses of the primed and unprimed symbols for the "moving" and "stationary" observers/frames. I have lately in this thread tried to avoid their use. However, the outcome is the same, and, apart from perhaps a different use of this primed/unprimed symbology I am sure that the term dilation is consistently used by authors to mean the loosely described effect of "moving clocks running slow".
Matheinste.
So is it the standard interpretation to think of the time "to be dilated" as being the interval shown on the moving clock, and the result of its dilation--the time "after having been dilated" (the "dilated time" of Lerner, Petkov and Schröder)--as being the length of this interval as recorded by the stationary clock? (This "dilated time" being a bigger number than the proper time between the events that mark the beginning and end of the interval on the moving clock's worldline.)
That may well be but the wording is still confusing to me but that is not your fault.
Let me try to explain what I am saying in detail. The detailed explanation does not imply any lack of knowledge on your part but is just to avoid any confusion as to my point of view. If we let A be an observer with a clock at rest in an inertial frame of reference and let B be an observer with a clock at rest in a frame moving inertially relative A's frame. Let them pass each other at some point and let them set their clocks to read zero at this point. Now in A's frame, the event of A's clock reading 1 second as viewed by A is simultaneous with the event of B's clock reading less than 1 second as viewed by B. This assumes that the standard definition of simultaneity is used. So according to A, B's time is dilated in the sense that B's seconds are "stretched". Both are of course reading their own proper times on their own clocks and for each of them this is THE time. This may well not be the standard way of explaining time dilation but it is another way of saying the same thing, I hope.
Matheinste.
matheinste said:
Let me try to explain what I am saying in detail. The detailed explanation does not imply any lack of knowledge on your part but is just to avoid any confusion as to my point of view. [...] This may well not be the standard way of explaining time dilation but it is another way of saying the same thing, I hope.
That's clear. You explain well. It's certainly the same situation that I was struggling to describe. I suppose what I was trying to get at with my contorted wording was that we're given one value, and use the "time dilation formula" to derive a bigger value from it. Something small becomes something big. We could say that the time between ticks is dilated (bigger, stretched) when measured according to a frame where the clock is moving. But maybe others see the word dilation is a slightly different way, for the situation in general (irrespective of whether a big number is being derived from a smaller one or vice versa), and maybe that's what confused me about the use of the same term to refer to the application of the inverse formula, for which I'd have thought "time contraction" would have been a natural name.
Its still not quite clear to me as to whether we are saying the same thing. I'll try putting it another, very non rigorous way. If you are happy with length contraction think of it as a contraction, or making smaller, of the unit of measurement, the meter. In the same way time dilation can be thought of as making longer the unit of time measurement, the second.
Matheinste
  • #31
Makes sense. Maybe I was wrong to think that these were two different ways of conceptualising it. I think what you say agrees with Tipler & Mosca's definition, doesn't it? "The time interval measured in any other reference frame is always longer than the proper time. This expansion is called time dilation." That just generalises your statement about the second to intervals of any length.
  • #32
Perhaps the difference in my mind could be visualised in the following way.
I was thinking of one image in which we have one object like a rubber tape measure of time that we stretch (dilate) so that one of its seconds covers gamma seconds of any unstretched tape measure we might care to compare it with; rightly or wrongly, this seemed to me more like how you were understanding the word dilation. I was contrasting this in my mind with another image in which we're comparing two objects: a short time (consisting of a small number of seconds) and a longer (dilated) time made up of gamma times the shorter number of seconds.
Of course, this amounts to the same thing mathematically, and such visualisations are just a mental short-hand to account for the word "dilation". They don't clarify the real physical situation in all its aspects as well as a spacetime diagram. But they might affect how an author writes about the subject. In particular, if we think in terms of the first image, it might seem natural to call the shorter period the "dilated time" (as the Hyperphysics site and Wikipedia come close to doing), whereas if we think in terms of the second image, it might seem more natural to call the longer period the "dilated time" (as Lerner, Petkov and Schröder do explicitly). So perhaps there is a significant difference in these interpretations after all...
  • #33
I don't see that as contradicting the Schroder/Lerner/Petkov usage--"running slow" refers to the rate of ticking rather than the time interval, but obviously a clock that is running at a slowed-down rate (in our frame) will take a greater length of time to tick forward by a given amount.
What specific quote in what Wikipedia article do you refer to? They seem to use "dilated" in the normal way in the second-to-last paragraph of the overview section of the time dilation article, where they write: "Thus, in special relativity, the time dilation effect is reciprocal: as observed from the point of view of either of two clocks which are in motion with respect to each other, it will be the other clock that is time dilated." From either clock's "point of view" (rest frame), when they it is "the other clock that is time dilated", presumably they mean that it takes longer to tick forward by a given amount (its seconds are longer).
  • #34
Quite, but it didn't seem at all obvious to me that people would chose to call a time-dilated clock one that displays non-dilated time, while dilated time is shown only by a clock that isn't time-dilated!
This paragraph suggests that a "clock that is time dilated" would be a clock that records a smaller number because, as you say, it takes longer to tick a given amount (the amount being given by the observer's clock). That was also the impression I got from the statement "Observers do not consider their own clock time to be time-dilated, but may find that it is observed to be time-dilated in another coordinate system." It seems natural to think that the time displayed by a "time-dilated clock" would be called "dilated time", no? Well it did to me... But Lerner, Petkov and Schröder all define "dilated time" in the opposite way, as the bigger number recorded by the other clock.
  • #35
Although, I suppose that would fit with the way that we talk of a contracted ruler whose contracted length is shown by the smaller-numbered marks on another, uncontracted ruler.
  • #36
Gentlemen, it appears to me that the difficulty here is that you are both trying to agree that you have a common understanding while holding opposing concepts of what time dilation means.
If the time between 'ticks' increases, the clock runs slow.
If the number of 'ticks' increases, then, surely, the clock runs fast.
What seems to me to be the fundamental problem here is that we are overlooking the fact that if the transformed 'ticks' are longer, or shorter, then the units are different; and if the units are different then the time dilation formula isn't comparing 'like with like', i.e. it is not so much an equation as a conversion.
What we are ascertaining is how many co-ordinate time units are equal to one Proper time unit, as measured by a local observer in either Inertial Frame of Reference (IFoR).
Einstein shewed that the space-time co-ordinates from one IFoR could be converted and transferred to another IFoR by application of the Lorentz Transformation Equations whilst still complying with his two Postulates.
In such a transformation the two IFoRs would, locally, have common time and space dimensions; which I will refer to as Inertial units (as they are a special case of Proper time).
But each IFoR's observation of the other would be in transformed, or Co-ordinate units, giving rise to the Time Dilation and Length Contraction phenomena.
It is obvious from the above that, Time Dilation and Length Contraction, will be observed in another IFoR but cannot be experienced; (This thread is limited to Special Relativity so Gravitational Time Dilation is not addressed) so how can we talk of a traveller, in an IFoR, experiencing dilated time or contracted distances? For he has to experience Inertial time and distance, it is only an observer that will see the transformed units.
Everything becomes very clear and straightforward if we consider diagrams of Minkowski Spacetime.
An important factor here is that relative velocity between two IFoRs is shewn by rotation between the frames of reference.
So, taking this in the simplest case we have the following diagrams:
http://img193.imageshack.us/img193/5910/fig1fig2.jpg
Shewing the effect of rotation on the ct and the x axes where perpendicular projections from the primed axes onto the unprimed axes depict time dilation and length contraction.
Combining these into a single diagram demonstrates the rotation between two IFoRs. In the following diagram one can see the rotated frame of reference, in red and how it relates to the observer's frame of reference.
http://img16.imageshack.us/img16/5218/figure3g.jpg
An important point to note here is that the IFoR of the moving body has the same origin as that of the observer. So the moving body is progressing at a constant velocity within its own frame of reference.
If this were not so, the origin of the moving IFoR would have to be progressing along the x-axis or else we would have two bodies moving at a constant relative velocity, whilst remaining at the same location.
  • #37
Maybe so... We have a common understanding of the phenomenon, I think (albeit only a basic one in my case), but I'm unsure of how exactly this word "dilation" is to be understood with respect to the various aspects of the phenomenon.
Indeed. I was trying to work out whether it was the running slow (counting off a smaller total of ticks) or the running fast (counting off a larger number of ticks) that people call "dilation". The textbooks I looked at generally seemed to refer to the larger number as the "dilated time", but Wikipedia referred to the clock that ticked fewer times as being "time-dilated". That seemed to me to indicate two different usages of the word, but I could be mistaken. Others apparently see no contradiction in talking about a time-dilated clock that displays non-dilated time, and a non-time-dilated clock that displays dilated time. I suppose it's no less logical than talking about a contracted ruler that shows a longer distance (a bigger number of units) next to an uncontracted ruler that shows a shorter distance (a smaller number of units). Is this how the words dilation and contraction are generally understood?
Proper time and coordinate time are nicely unambiguous (as long as we're clear about which events we mean).
  • #38
The "stationary" observer will observe the "moving" clock to have a longer period between ticks than he observes on his own clock. There is no disagreement between texts on this point, only misinterpretations by the readers. There are however many ways of describing the effect, some of which decribe the effect more clearly than others.
Matheinste.
  • #39
So maybe I was wrong to think that there's anything contradictory about characterising the moving clock as the "time-dilated clock" which displays "non-dilated time", and the stationary clock the "non-time dilated clock" which displays "dilated time". Is that how you look at it? Because that's the only way, as far as I can see, to reconcile sources like Lerner, Petkov and Schröder (who contrast dilated time with proper time) with sources like the Wikipedia entry (which characterise the clock itself as being "time-dilated").
Add Freund to the "dilated time"-constrasts-with-"proper time" list:
http://books.google.co.uk/books?id=...nepage&q="proper time" "dilated time"&f=false
Googling for "dilated time" and "dilated clock" produces mainly forum discussions, and there are a few crank sources to weed out (I get that impression that "dilated clock" is a more informal term), but here's a reasonable-looking site that uses both terms:
http://www.geocities.com/syzygywjp/RelativeI.html
It's talking about general relativity, but still relevant, I think. It says, "A body orbting at this range would experience a time dilation of about 1.07 longer than non dilated time." And "According to calculations based on relativistic motion near a black hole, the time dilation nearest the black hole would amount to 1.414 times slower than a non time dilated clock."
So for this writer, dilated time is "longer" than non-dilated time. (But would you say they meant by this that "dilated time" has more or less ticks?) And a dilated clock, as for Wikipedia, is slow and therefore makes fewer ticks than a non-time-dilated clock.
  • #40
One of the sites that I cited:
"But that hour and a half elapsed on the pilot's clock, in the pilot's frame. The Modesto and Fresno clocks tick off dilated time in that frame, each minute dilated to fill two minutes of the pilot's time. So one and a half hours on the pilot's clock corresponds to forty-five minutes elapsed on the Modesto and Fresno clocks, which means that in the pilot's frame the Modesto clock appears to be running forty-five minutes "fast" relative to the Fresno clock. [...] Half an hour later, by John's watch, the train arrives in Modesto, where the station clock, having ticked off fifteen dilated minutes, shows one o'clock, in perfect agreement with Jane's calculation."
http://bado-shanai.net/Map of Physics/moptempoff.htm
Surely this use of the term "dilated time" is the exact opposite of the definition given by Freund, Lerner, Petkov and Schröder, for whom it would be the pilot's clock that showed the dilated time, wouldn't it? For this writer (Dennis Anthony), dilated time is the smaller value, as recorded/measured/displayed (ticked off) by the clock that's running slow. For him, "dilated time" is a reduced number of expanded units, rather than an expanded number of reduced units.
How do you all feel about that? If you see no contradiction, could you explain to me how they amount to the same thing? If you do see a contradiction, could you tell me which interpretation matches your own, or the one that you're most familiar with, and which you feel is the standard way of understanding the term.
  • #41
Here are a couple more sources, Adams and Weinert, agreeing with Freund, Lerner, Petkov, Schröder.
http://books.google.co.uk/books?id=1RV0AysEN4oC&pg=PA152&lpg=PA152#v=onepage&q=&f=false
http://books.google.co.uk/books?id=8eN9zoprUT4C&pg=PA175#v=onepage&q=&f=false
For all these authors, dilated time is the expanded number of reduced units, derived from a proper time interval by the formula
\Delta t = \gamma * \Delta \tau.
I notice that Weinert, rather than talking about a "dilated clock", writes: "The spacio-temporal stages of space-time, which show the history of geodesics, can be measured by clocks, which are either attached to the trajectory (recording the proper time of the system at successive spacio-temporal stages) or from external clocks (recording a dilated time for the system undergoing linear translation)."
Here's a site which confirms what JesseM and Matheinste have been saying that there's no contradiction between, for example, the Wikipedia article and these textbooks. It agrees with all of the above that dilated time is an expanded number of reduced units:
http://www.relativitycalculator.com/stationary_moving_clocks.shtml
And also agrees with the Wikipedia characterisation of a clock which measures non-dilated time as being a "time-dilated clock":
"an observer at either of the two clocks will be stationary relative to the other clock and therefore it will reciprocally be the other clock which will be time dilated to the ( relatively stationary ) observer."
  • #42
With regards to the first point the wording seems over complicated and still confuses me. Clocks just show time
Regarding the extract from Freund I am not completely familiar with four vectors in that context, but earlier in the book his meaning of time dilation will be no different from others.
With regard to GR, of which I know little, time dilation is the same effect through a different mechanism whereby clocks at different gravitational potentials click at different rates. The use of the words longer in the quote is ambiguous.
Perhaps I can give examples, in my view, of faulty and correct reasoning with regard to the often used example of the muon's lifetime as an aid to illustrating time dialtion. These two methods lead to exactly the opposite outcome.
Let the lab frame be regarded as the stationary frame and the muon's frame the moving frame with repect to it. We can use the values of 2 microseconds 60 microseconds as being the figures used for the decay times of the muon measured by clocks in the muon and lab frame respectivley. Both explanations are non rigorous.
WRONG reasoning:- The muon's lifetime of 2 micoseconds its own frame is extended to 60 microseconds in the lab frame. This is an example of time dilation this shows that the number of seconds which the muon lives is dilated, made bigger, to 60 microseconds.
Now bear in mind the definition which says that a moving clock viewed from a stationary frame runs slow, and reason as follows.
CORRECT reasoning:- The muon has a lifetime as measured in its own frame, the time measured by a clock carried with it, its proper time, of 2 microseconds. This is an invariant and is the same for everyone, it cannot be changed. In the lab frame this is measured as 60 microseconds. This is an example of time dilation and shows that 2 microseconds in the muon's frame takes 60 microseconds to pass in the lab frame. So the time it takes 2 microseconds to pass in the moving frame is dilated to 60 microseconds as viewed from the stationary frame. That is, the preiod is extended.
Remember that although the lab frame measures 60 microseconds, the lab observers still agree that the muon's clock reads a proper, invariant time of 2 microseconds.
All other things having been said, look at it from this point of view. Time dilation is so fundamental to the theory that taking opposite stances at to what it means would lead to serious differences and contradictions between authors at later stages in these texts.
Matheinste.
  • #43
Anyone who takes "dilated time" to mean an expanded total (of reduced units), and who also talks about moving clocks as being "time-dilated clocks", would presumably be thinking in these terms. I agree it sounds confusing; so confusing that I assumed at first that the author(s) of the Wikipedia article couldn't possibly have been in agreement with Adams, Freund, Lerner, Petkov and Schröder. But JesseM saw no contradiction, and the Relativity Calculator site did indeed combine these viewpoints. On the other hand, Dennis Anthony takes "dilated time" in the opposite sense, to refer to the shorter interval made up of expanded units. So presumably, for him, time dilation refers to a dilation of unit size. But the textbooks almost all seem to agree with Taylor & Wheeler's view of dilation as referring to a dilation of the total when measured in one frame as opposed to another, Lawden being a possible exception.
My point is just that Freund, like Adams, Lerner, Petkov and Schröder, takes "dilated time" to mean an expanded total (of reduced units). So for all of these authors, dilation seems to refer to the quantity of units, the total, rather than--as I thought you originally suggested--the size of individual units. If these authors had taken dilation to refer to the size of units, then surely they'd have used the label "dilated time" for the interval made up of a reduced quantity of these dilated units, wouldn't they?
In both of these two ways of wording it, dilation refers to the process by which a bigger total, a bigger number of units, is derived from a smaller one. If we can say that "the time [...] is dilated" from 2 to 60 units, then it's the total that's being dilated, not the size of each unit relative to some other standard. The difference I see is that your first description is just shorter and less precise.
Yes, what's changing is not the proper time itself, which is invariant, meaning the same in all inertial frames. Rather we're using the time dilation formula or, more generally, the Lorentz transformation, to transform the value of the proper time into the value of the coordinate time in some other frame. We're just changing which reference frame we're measuring coordinate time with respect to. We begin with an input of 2 * 10^-6 seconds, which is the time interval between two events on the muon's worldline, and hence the proper time between these events. (This is coordinate time measured in the muon's rest frame, this being the unique intertial frame where the proper time between these events coincides with the coordinate time.) Then we use the time dilation formula to dilate this value, i.e. make the number bigger, the resulting bigger number being the coordinate time between these events in a frame with respect to which they're not located in the same places as each other (at the same spatial coordinates). Is that a fair way of putting it?
It would certainly be helpful to get the terminology straight and for everyone to agree on what they meant by dilation or by "dilated time". This discussion shows how important it is for authors to be explicit about what they mean by dilation (what is getting bigger) to avoid misunderstandings, although in practice, if each writer is clear, precise, explicit and self-consistent, at least we stand a chance of understanding them, even if they differ from other authors in the labelling of some concepts. And it's quite possible for an author to describe concepts in later in other terms that don't depend on how exactly they understood the word dilation.
It'd be interesting to know where the term was first applied to this concept in relativity and whether the person who coined it was clear about which sense they had in mind.
  • #44
Your reply.
In both of these two ways of wording it, dilation refers to the process by which a bigger total, a bigger number of units, is derived from a smaller one. If we can say that "the time [...] is dilated" from 2 to 60 units, then it's the total that's being dilated, not the size of each unit relative to some other standard. The difference I see is that your first description is just shorter and less precise.-------
The two descriptions are the opposite of each other so only one can be correct. In the first, incorrect example, the NUMBER of seconds enlarged. In the second, correct example, it is the PERIOD of each second that is enlarged.
I really cannot say any more to convince you than I already have so I only hope others can do so. I will keep in touch with the thread and if at a later date I can think of something else to add then I will do so.
Matheinste.
  • #45
Your first version: "the number of seconds which the muon lives is dilated, made bigger, to 60 microseconds"
Your second version: "the time it takes 2 microseconds to pass in the moving frame is dilated to 60 microseconds as viewed from the stationary frame. That is, the period is extended."
In both instances, you begin with a small number (a short period) and convert it into a bigger number (longer period) and call this process dilation. What else is the period if not some number of seconds? What else is the number of seconds if not how we represent that period? What do we gain by introducing a distinction between "period (as represented by a number)" and "number (that represents the period)" or lose by ignoring it? Both of these descriptions seem to me to match the way Freund, Lerner and the rest label the output of this conversion "dilated time". We convert a short interval of time to a longer one and call what we've done "dilation"; it's the same process whether the interval in question is one second or any number of seconds. Luckily, either way results in people taking time dilation to refer to the same operation.
On the other hand, we could informally visualise the two "times" as physical objects, like rubber tape measures, and identify one with the interval between events on the muon's worldine, as measured with respect to the muon's rest frame (i.e. the proper time between these events), and dilate that "time" by stretching this mental image of a rubber tape measure. We could say its seconds are bigger (the period of each of its seconds is enlarged, the muon's clock is ticking slow, it's been time-dilated) compared to our unstretched, undilated tape measure by which we represent the same period in the rest frame of the laboratory. This seems to be the conception behind some of the language used by Wikipedia and the Hyperphysics site. This is what I thought you had in mind when you said dilation referred to the expansion of each second (hence less seconds needed to cover a given period). Then, as Wikipedia says of clocks, we could say that this muon has been time-dilated. And if we thought in those terms, it might not seem unnatural to call the shorter period the "dilated time" (since it's represented by the mental image of an unstretched tape), as Dennis Anthony does. But this last step, at least, reverses the usual naming convention, as represented by Adams, Freund, Lerner, Schröder, Petkov and Taylor & Wheeler. So there we would have a real contrast that could lead to contradictory use of terminology.
As Grimble put it,
"If the time between 'ticks' increases, the clock runs slow.
If the number of 'ticks' increases, then, surely, the clock runs fast."
If we think of one of the first as dilation, we have one operation. If we think of the second as dilation, we have the inverse of that operation. So this is a difference with consequences.
  • #46
Rasalhague said:
As Grimble put it,
I will not repeat the more accurate desriptions but, putting it loosely, the interpretation that all authors agree upon, is, moving clocks run slow. Time between ticks increases. The number of elapsed seconds is not increased but the duration of seconds is increased. You cannot correctly interpret it both ways. There are not many more ways of putting it. That is time dilation. Any other interpretation is incorrect.
Matheinste.
  • #47
And how is duration expressed? By some number of elapsed seconds! We have a formula which we call the time dilation formula. In the form most often presented, it takes as its input a number of seconds. Its output is also a number of seconds. The output is bigger than the input. In that sense, the number has increased. Our calculation has increased it. If the input is the "time between ticks" (i.e. one elapsed second), we could say, as you do, that the time between ticks has increased. If the input is any other number of elapsed seconds, then that number of elapsed seconds (that duration) has increased.
I don't understand what distinction you're making between a number of seconds and a duration, particularly as either interpretation gives the same result.
\Delta t&#039; = \Delta t \: cosh \theta = \gamma \: \Delta t
The "time lapse", as Taylor and Wheeler call it (i.e. a number of elapsed seconds), expressed by the output \Delta t&#039; is "more than" our input \Delta t (also a number of elapsed seconds). Taylor and Wheeler say, "Such lengthening is called time dilation." That's pretty explicit. What has been lengthened? A time lapse, an interval of time, a duration, a number of seconds (all the same sort of thing, as far as I can see). Either way, almost all of the authors we've looked at call the outut of such a calculation "dilated time", in keeping with Taylor and Wheeler's definition.
On the other hand, as I've illustrated, there are ways of interpreting the expression "time dilation" that could lead someone to call the output of the inverse calculation "dilated time", and such interpretations do need to be distinguished from Taylor & Wheeler's. At least one of the authors I cited did see it that way, and perhaps Lawden would agree, as he presents the inverse formula under the name "time dilation". Others, such as Wikipedia, called the clock that runs slow a "time-dilated clock", without making clear which value they'd call "dilated time". At least one source spoke explicitly of dilated time as the value shown by a clock that isn't time dilated, and non-dilated time as the value shown by a clock that is time dilated, which--while not necessarily a contradiction, as JesseM points out--does strike me as a potentially confusing way to label things.
  • #48
=Rasalhague;2369858]Your first version: "the number of seconds which the muon lives is dilated, made bigger, to 60 microseconds"
It seems to me that, in both these cases, a consistent interpretation would be that what is dilated is the duration of interval of the moving frames clock.
This is of course relative to the labs clock.
SO #1 the proper muon "second" is dilated from 1 lab second ==>30 lab seconds.
The expanded lab lifetime is a result of this but is not itself the object of the term dilation.
#2 Actually same as #1
Semantics is a mindfield :-)
  • #49
Maybe it's not such a good idea to talk, as the Wikipedia article and some other online sources do, of clocks themselves as being time-dilated in special relativity when we really mean only that some interval of time is dilated when transformed from one frame to another. After all, the clocks in these thought experiments are physical objects that exist in all frames. That way we avoid having to contort our minds into remembering that a "time-dilated clock" shows "non-dilated time" and vice-versa. I suppose it's more natural though when the clock is a muon, say, and the only time interval it displays is its own lifespan.
  • #50
The way I looked at it was that a second is just a special case of a duration, and for that reason#2 is the same as #1.
