Time Division Multiplexing
In summary, the conversation discusses how to devise a commutator configuration for time-division multiplexing using signals with different bandwidths. The question involves five messages with specific bandwidths and the goal is to find a permissible sequence of baseband samples for proper interlacing. The example provided in the book has four messages with a similar setup. The conversation ends with a request for further clarification on the example.
Lila
hey y'all!
could someone please explain to me how to devise a commutator configuration when given a number of signals and their bandwidths.
Example:
with four signals bandlimited to W, W, 2W, 3W. Give a possible sequence for a period.
Welcome to PF, Lila. Could you give a little more info about your question? You want to TDM several signals, but you are only giving some frequency domain information about them. What are the time domain characteristics of these four signals? If you want to TDM them, you also need to specify the receive filtering for each (which affects the ringup time of their recevers) and the transmit power-down times for each.
well, here's the question as given from Ziemer & Tranter - Principles of Communications
"Five messages bandlimited to W, W, 2W, 4W, and 4W Hz respectively, are to be time-division multiplexed. Devise a commutator configuration such that each signal is periodically sampled at its own minimum rate and the samples are properly interlaced. "
There is an example in the book with 4 messages(s1 to s4) bandlimited to W, W, 2W, 4W Hz respectively.
A permissible sequence of baseband samples is a periodic sequence, one period of which is: ...s1 s4 s3 s4 s2 s4...
I need to find a permissible sequence of baseband samples for the question with 5messages, but I don't understand the example.
Thanks for any explanation! :)
Related to Time Division Multiplexing
1. What is time division multiplexing (TDM)?
Time division multiplexing (TDM) is a technique used in telecommunications and signal processing to transmit multiple data streams over a single communication channel by interleaving them in time. This allows for more efficient use of the channel's bandwidth and enables multiple users to share the same channel.
2. How does TDM work?
In TDM, each data stream is assigned a specific time slot within a predefined time frame. The data from each stream is then transmitted sequentially during its designated time slot. This process repeats continuously, allowing multiple data streams to be transmitted over the same channel without interference.
3. What are the advantages of TDM?
TDM allows for more efficient use of a communication channel, as it enables multiple data streams to be transmitted simultaneously. It also reduces the overall cost and complexity of a communication system, as it eliminates the need for separate channels for each data stream.
4. What are the applications of TDM?
TDM is commonly used in telecommunications, such as in phone systems, where it allows multiple phone calls to be transmitted over the same line. It is also used in digital multiplexers, satellite communications, and data networking systems.
5. Are there any limitations to TDM?
One limitation of TDM is that it requires strict synchronization between the transmitter and receiver to ensure that data is transmitted and received in the correct time slots. It is also not suitable for real-time applications, as there may be delays in the transmission of data due to the interleaving process.
  • Electrical Engineering
9K
  • Other Physics Topics
