Time independent Schrodinger equation and uncertainty in x
wood
Is the gaussian
$$\sqrt{\frac{\pi}{2\alpha}}e^{-\alpha x^{2}}$$
an eigenfunction of ## \widehat{T} = \frac{\hat{p}^{2}}{2m}## ? If so, what is the corresponding eigenvalue? If not, find a P.E. operator ##\widehat{U} = U(\hat{x}) ## which gives rise to a Hamiltonian ##\widehat{H}## for which this Gaussian is an energy eigenfunction. What physical system are we talking about?
Find the uncertainty in ##\Delta x##.
$$\hat{p} = \frac{\hbar}{i}\frac{\partial}{\partial x}$$
time independent Schrodinger equation
##\{-\frac{\hbar^{2}}{2m} \frac{\partial^{2}}{\partial x^{2}}+U(x)\}\psi_n(x)=E_n\psi_n(x)##
I have worked out the relative derivatives and determined that it isn't an eigenfunction.
##\widehat{T}\psi(x)= -\frac{\hbar}{2m} 2\alpha e^{-\alpha x^{2}}(2\alpha x^{2} -1)##
Then I plug all that into the TISE and solve for ##\widehat{U}## and get
##\widehat{U}=\frac {\hbar^{2} + 4\alpha^{2}x^{2}}{2m}##
Hopefully I am correct up to here.
Now I am asked to find ##\Delta x ##
I think I need
## \Delta x= \sqrt{ \langle x^{2} \rangle - \langle x \rangle^{2}}##
where
## \langle x \rangle = \int_{-\infty}^\infty x|\psi|^{2} \,\mathrm{d}x##
which gives me 0
but I get confused here where I think I need
## \langle x^{2} \rangle = \int_{-\infty}^\infty x^{2}|\psi|^{2} \,\mathrm{d}x##
is the x2 term just the square of my function? So in principal I am just multiplying the square of my function by the mod of the function squared? THen taking the integral?
Thanks
edit :- sorted formatting of equation
## \langle x^{2} \rangle = \int_{-\infty}^\infty x^|\psi|^{2} \,\mathrm{d}x##
If you intended to write
## \langle x^{2} \rangle = \int_{-\infty}^\infty x^2 |\psi|^{2} \,\mathrm{d}x##
then yes, this is the expectation value of ##x^2##. Your wording makes it unclear what you are actually having trouble with.
That is what the equation was meant to look like.
My problem is do I square the function ##\psi## and multiply that by the mod squared of the function or multiply the function by x2. In short i am not sure what x2 is in the above formula
thanks
When you calculated ##\langle x \rangle##, how did you treat the factor of ##x##? Why do you think it's different in the case of ##\langle x^2 \rangle## in how you deal with ##x##?
Thanks very much I think I am getting the hang of what is going on. I don't have to treat ##\langle x^2 \rangle## any different to how I dealt with ##x## i.e.I just use ##x^{2}## when workingout ##\langle x^2\rangle ##
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
