Time-reversal symmetry in QM
In summary, the conversation discusses time-reversal symmetry in quantum mechanics and its implications. It is mentioned that standard quantum mechanics is not time-reversal symmetric due to the collapse post-measurement process, which is an irreversible process. The reasons for looking for a time-symmetric quantum theory are discussed, with a passage from Wikipedia suggesting that theorists may be looking to modify quantum mechanics to hold for equilibrium states. The role of anti-unitary operators is also briefly mentioned. The conversation ends with a speculation about reformulating the second law of thermodynamics in a time-symmetric fashion and the concept of entropy increasing in both time directions.
WWCY
479
TL;DR Summary
What is it and why should it apply to qm?
I've bumped into a few interesting papers talking about time-reversal symmetry in QM (eg: https://arxiv.org/abs/1507.07745) but I can't seem to wrap my head around the concept.
1) What does it mean for one to say that standard QM isn't time-reversal symmetric? Does this have to do with the "collapse" post-measurement?
2) Why should we look for quantum theory that is time-reversal symmetric? Are the reasons empirical or theoretical?
Regarding 2), I found a passage on wikipedia that says: "In other words, time is said to be non-symmetric, or asymmetric, except for special equilibrium states when the second law of thermodynamics predicts the time symmetry to hold. However, quantum noninvasive measurements are predicted to violate time symmetry even in equilibrium, contrary to their classical counterparts,". Does this mean that these theorists are looking to modify QM such that time symmetry holds for these "equilibrium states"? The paper I cited, on the other hand, doesn't say anything about such equilibrium states.
Thanks in advance!
Edit: What role does an anti-unitary operator have to play in all this?
Last first, do you mean non-unitary vs anti-unitary? Non-unitary operators can be used to represent dissipative and hence irreversible evolution.
To your main questions, there are two components to standard QM. The first is the dynamics which is expressed via unitary operators acting on the system description (wave function, "state" vector, or density operator). This is time reversal symmetric.
The second is the interpretation of the system description in terms of acts of observation. Observables are expressed as Hermitian operators, their available values being the eigenvalues. An act of observation is an irreversible process. One is amplifying the "signal" contained in one of the system's observables and that is a intrinsically thermodynamic process. The time asymmetry manifests in the "collapse" i.e. the projection onto the eigenspace of the observable contingent on the actual value observed. The magnitude of the projection relative to the prior description tells us the probability of observing that specific value via Born's formula.
The measurement process is not time symmetric due to the 2nd law of thermodynamics.
(Grandiose speculation warning!)
Now I believe it is possible to reformulate the 2nd law in a time symmetric fashion and I think that might be what the paper is about implicitly.
If you imagine that you sharply measure some system with a large numbers of components, say a box full of many hydrogen atoms, then you would write down a sharp description of the system at that time. The system would have entropy 0. If you then assert the system was coupled to a larger high entropy environment and unitarily evolve backward in time you would find the entropy of the description would increase as time devolves.
Keep in mind that entropy is not a substance or energy. It is a measure of how imprecisely we
We lose knowledge about both past and future systems relative to the present when we allow them to evolve/have evolved while coupled, however weakly, to the environment.
Likes WWCY
Thanks for your response
This is the part I don't quite get in the paper. What would a series of operations in T-symmetric quantum theory, say, state preparation and then measurement in the ##+t## direction look like in the ##-t## direction? And if indeed this lack of reversibility is due to thermodynamics, why would the authors feel the need to formulate a T-symmetric quantum theory?
Cheers.
jambaugh said:
Last first, ...
Love it! Only appropriate in a thread on time symmetry. :biggrin:
  • Haha
Likes *now*, vanhees71 and DarMM
I think it is fair to say that [Boltzmann] entropy increases in both time directions. A measurement would represent a local maximum of knowledge. That is not something normally considered (entropy to the past), but I have seen a few references in the literature over the years.
Time reversal symmetry is somewhat special. I've not followed the above quoted paper, which seems to claim something different to the well-established standard treatment of this symmetry, according to which standard QT is time-reversal invariant. So here I refer to the standard treatment, known since the very beginning of QT.
First of all one has to take into account that the Hamiltonian is a very special observable in QT since it defines the time evolution of the system. One conclusion is that a system can only be stable if the Hamiltonian is bounded from below, i.e., there should be a state (or maybe several degenerate states) of minimum energy.
The first important consequence of this is that you cannot ##\hat{H}## interpret as the canonical conjugate momentum of time and thus time is a "c-number"-parameter in quantum theory, labelling the causality order of events (as in classical physics too).
Now, as proven by Wigner, a single symmetry transformation can always be lifted to either a unitary or antiunitary transformation. For a review, see
https://doi.org/10.1063/1.1704188
If you have an entire continuous (e.g., as usual in physics even a Lie group) the symmetry transformations are necessarily unitary, while discrete symmetries may be antiunitary.
Now the Hamiltonian for a stable system is bounded from below, and since it generates time translations the time-reversal operator must act as
$$\hat{T}(\mathrm{i} \hat{H})\hat{T}^{\dagger}=-\mathrm{i} \hat{H}.$$
Thus, in order for ##\hat{H}## not flip sign, we must necessarily assume that ##\hat{T}## is anti-unitary rather than unitary.
Likes WWCY
1. What is time-reversal symmetry in quantum mechanics?
Time-reversal symmetry in quantum mechanics refers to the principle that the laws of physics should be the same whether time is moving forward or backward. This means that if we were to reverse the direction of time, the behavior of particles and systems should remain the same.
2. Why is time-reversal symmetry important in quantum mechanics?
Time-reversal symmetry is important in quantum mechanics because it is a fundamental principle that helps us understand the behavior of particles and systems. It allows us to make predictions about the behavior of particles in both the past and the future, and it is a key component in many quantum theories and experiments.
3. How is time-reversal symmetry tested in quantum mechanics?
Time-reversal symmetry can be tested in quantum mechanics through various experiments. One common method is to observe the behavior of particles and systems in both the forward and backward directions of time and compare the results. If the behavior remains the same, then time-reversal symmetry is upheld.
4. Are there any known violations of time-reversal symmetry in quantum mechanics?
Yes, there are some known violations of time-reversal symmetry in quantum mechanics. For example, in certain quantum systems, the behavior of particles may change when the direction of time is reversed. This is known as time-reversal asymmetry and has been observed in experiments involving the decay of subatomic particles.
5. How does time-reversal symmetry relate to other symmetries in quantum mechanics?
Time-reversal symmetry is closely related to other symmetries in quantum mechanics, such as spatial symmetry and charge symmetry. These symmetries all contribute to our understanding of the laws of physics and how particles and systems behave. In fact, the combination of these symmetries is what allows us to make accurate predictions about the behavior of particles in quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
