Total energy of matter of a star
In summary, the total energy of matter of a star is the sum of all the energy contained within the star, including its mass and any other forms of energy such as heat, light, and nuclear energy. It is calculated using Einstein's famous equation, E=mc², and is affected by factors such as the star's mass, composition, and temperature. The total energy of matter of a star changes over time due to fusion reactions occurring in its core, and in theory, it could eventually be completely exhausted.
cosmogirl
35
Suppose I have a spherically symmetric static star. What is the total energy of (baryonic) matter inside the star?
The metric is (parametrizing as in Weinberg):
[tex]ds^2=-B(r)dt^2+A(r)dr^2+r^2d\Omega^2 [/tex]
I assume the energy-momentum tensor of a perfect fluid.
As it happens, the total energy (including the gravitational field) is given by:
[tex]M=\int{4\pi r^2\rho(r)dr} [/tex]
However, I'm interested in the matter only.
Weinberg (Gravitation... p. 302) gives the following expression, which seems correct:
[tex]M_m=\int{\sqrt{g}\rho(r)dr d\theta d\phi} [/tex]
However, Shapiro (Black holes, white dwarfs and neutron stars, p. 125) gives another expression:
[tex]M_m=\int{\sqrt{A(r)}4\pi r^2 dr} [/tex]
My questions are: how to reconcile between the two? Is Shapiro wrong? Is the quantity in question well defined?
Thank you for your question. The total energy of matter inside a spherically symmetric static star can be calculated using either of the two expressions you mentioned. Both expressions give the same result and are mathematically equivalent. The difference lies in the interpretation of the integral.
The first expression, given by Weinberg, calculates the total energy by integrating the energy density (ρ) over the volume of the star. This takes into account the curvature of space caused by the presence of matter.
The second expression, given by Shapiro, calculates the total energy by integrating the mass density (ρ) over the volume of the star, taking into account the metric (A(r)) which represents the curvature of space due to the presence of matter.
In summary, both expressions are correct and give the same result. It is a matter of preference which one to use, but both take into account the important factors of matter and space curvature. I hope this helps to clarify any confusion. Good luck with your research!
Related to Total energy of matter of a star
What is the total energy of matter of a star?
The total energy of matter of a star is the sum of all the energy contained within the star, including its mass and any other forms of energy such as heat, light, and nuclear energy.
How is the total energy of matter of a star calculated?
The total energy of matter of a star is calculated using Einstein's famous equation, E=mc², where E is the energy, m is the mass, and c is the speed of light. This equation shows the direct relationship between mass and energy, meaning that the more massive a star is, the more energy it contains.
What factors affect the total energy of matter of a star?
The total energy of matter of a star is affected by several factors, including the star's mass, composition, and temperature. The type of nuclear reactions occurring in the star also play a significant role in determining its energy output.
How does the total energy of matter of a star change over time?
The total energy of matter of a star changes over time due to fusion reactions occurring in its core. As the star consumes hydrogen and other elements, it releases a tremendous amount of energy, which keeps the star shining and provides the energy needed to sustain life on planets orbiting the star.
Can the total energy of matter of a star ever be completely exhausted?
In theory, yes, the total energy of matter of a star could be completely exhausted if it were to consume all of its fuel and no longer undergo any nuclear reactions. However, this would take an extremely long time, and most stars will go through several stages of energy production before eventually running out of fuel.
