How Does Belt Friction Calculate Maximum Load Around a Cylinder?
In summary, the conversation discusses the formula for maximum load held by traction of a band or strip wrapped around a cylinder, with a given force applied on one end. It mentions the role of the coefficient of static friction and introduces the concept of belt friction, providing a link to a Wikipedia page with the basic formula and suggesting other sources for a full derivation. The conversation ends with a thank you for the help.
jamesadrian
33
I have been trying to figure out the formula for maximum load held by traction of a band or strip wrapped around a cylinder where there is a given force holding the other end of the strip.
Suppose the strip is wrapped 180 degrees around a horizontally positioned cylinder so that the strip is vertical as as it comes onto and leaves contact with the cylinder. The load is on the left and a holding force is applied downward on the right hand end of the strip. The load would be a larger force than the holding force. From experience, a rope around a tree can resist slipping in the face of tons of load force if the rope is wrapped a few times around the tree and a man holds the end of the rope with only a few pounds of force. It seems to me that the ratio of the two forces is an exponential function of the angle through which the wrapping is done. Of course, the coefficient of static friction between the strip and the cylinder must be known.
Thank you for your help.
Jim Adrian
I believe what you are looking for is called belt friction. Here is the wiki link that has the basic formula:
http://en.wikipedia.org/wiki/Belt_friction
There are some other sites & videos you could find if you want a full derivation.
kjohnson,
This information completely solves the problem. It even led to a PDF of a derivation.
Jim Adrian
1. What is traction around a cylinder?
Traction around a cylinder refers to the force or grip that is applied to the surface of a cylinder in order to move or rotate it.
2. How is traction around a cylinder calculated?
The calculation of traction around a cylinder involves using the formula: T = μN, where T is the traction force, μ is the coefficient of friction, and N is the normal force.
3. What factors affect the traction around a cylinder?
The main factors that affect traction around a cylinder include the coefficient of friction, the normal force, the surface area of the cylinder, and the type of material the cylinder is made of.
4. How is traction around a cylinder used in real-world applications?
Traction around a cylinder is used in various industries, such as manufacturing and transportation, to move and rotate cylindrical objects. It is also used in sports equipment, such as wheels and bearings, to ensure smooth movement.
5. What are some common challenges in calculating and maintaining traction around a cylinder?
Some common challenges in calculating and maintaining traction around a cylinder include variations in the coefficient of friction due to factors like surface roughness and temperature, as well as wear and tear of the cylinder surface over time.
  • Mechanics
  • Other Physics Topics
