Turbulent flow velocity profiles
In summary, the question asks for the velocity profiles of air and water flowing in a duct and pipe, respectively, with given dimensions and Reynolds numbers. To answer the question, you must first calculate the values of vmean and vy=0 using the formula vmean = Q/A, where Q is the volumetric flow rate and A is the cross-sectional area. Then, using the Blasius equation f = 0.079Re-0.25, you can calculate the values of f and ΔP/L for both cases.
suvernfraggle
i've been given this question by my lecturer at university and I am struggling with where to start with it to be honest. it feels like i don't have enough information. please can someone help?
For turbulent flow, the velocity profile inside a duct and a pipe of diameters Dd and Dp and
both with distance y from the centre line is: vy/vy=0 = (1-y/r)1/7, where vy=0 = vmean/0.817 and vmean=Q/A. Plot the velocity profiles for:
(a) Air flowing in a duct measuring Dd = 0.6m and with Re = 105.
(b) Water flowing in a pipe measuring Dp = 0.5m and with Re = 105.
(c) Calculate the vmean and vy=0 for both cases (a) and (b)
(d) If the Blasius equation f = 0.079Re-0.25 applies, calculate the values of f and ΔP/L for (a)
and (b).To answer this question, you will need to first calculate the values of vmean and vy=0 for both cases. The formula for vmean is vmean = Q/A, where Q is the volumetric flow rate and A is the cross-sectional area. For case (a), the cross-sectional area is given by A = pi x (Dd/2)^2 (where pi = 3.14159). For case (b), the cross-sectional area is given by A = pi x (Dp/2)^2. Once you have calculated the values of vmean and vy=0, you can then plot the velocity profiles for both cases using the given equation.Once you have plotted the velocity profiles, you can then calculate the f and ΔP/L values using the Blasius equation f = 0.079Re-0.25. The Reynolds number for both cases is given as Re = 105, so you can then calculate the corresponding f and ΔP/L values for both cases.
Related to Turbulent flow velocity profiles
1. What is turbulent flow velocity profile?
Turbulent flow velocity profile refers to the distribution of velocities within a turbulent flow. In a turbulent flow, the velocities of fluid particles are constantly changing direction and magnitude, resulting in a complex velocity profile.
2. How is turbulent flow velocity profile different from laminar flow velocity profile?
In laminar flow, the fluid particles move in a smooth, orderly manner, resulting in a parabolic velocity profile. In turbulent flow, the velocities are constantly changing, resulting in a flatter and more spread out velocity profile.
3. What factors affect the shape of a turbulent flow velocity profile?
The shape of a turbulent flow velocity profile is affected by several factors, including the fluid viscosity, flow rate, and the surface roughness of the channel through which the flow is passing. Other factors such as the Reynolds number and the turbulence intensity also play a role.
4. Why is understanding turbulent flow velocity profile important?
Understanding turbulent flow velocity profile is important in many applications, such as in fluid mechanics, aerodynamics, and hydraulic engineering. It helps in predicting the behavior of fluids in different systems, and is essential in designing efficient and effective systems.
5. How is turbulent flow velocity profile measured?
Turbulent flow velocity profile can be measured using various techniques such as hot wire anemometry, laser Doppler velocimetry, and particle image velocimetry. These methods involve measuring the velocities at different points within the flow and plotting them to create a velocity profile.
  • Materials and Chemical Engineering
  • Classical Physics
  • General Engineering
  • Mechanical Engineering
