Voltage Compliance Range & Load Resistor Values for Current Source Circuit
  • Thread starter Duave
  • Tags
    Compliance
In summary, the voltage compliance range of the current source is between 0.1V and 9V. The range of load resistors for the circuit to function as a current source is between 100 ohm and 8.9 kohm. The voltage across V_RL can be calculated by using KVL and is dependent on the value of Vce.
Duave
81
Thank you for any help that you can offer.
Did I answer the questions?
What is the voltage compliance range of the current source?
Between what range of RL values will the circuit function as a current source?
https://scontent-a.xx.fbcdn.net/hphotos-ash3/t1.0-9/1488711_10151945891295919_440459508_n.jpg
VB = 1.6V
VE = 1.0V
IE = 1.0mA
IL = 1.0mA
VLimit = VCC - ILRE
VCE < V < VLimit
Minimum staturation voltage:
VCE (Sat) = 0.1V
compliance range is:
VCE < V < VLimit
VCE < V < VCC - ILRE
0.1V < V < 10V - 1V
0.1V < V < 9V
The range of load resistors can be found by:
iOUT = Vin/R
VCE/iE < R < (VCC - ILRE)/iL
0.1V/1.0mA < R < (10V - 1V)/1.0mA
100(ohm) < R < 9000(ohm)
Are answers? Are there any errors located?
Thanks again for your help.
Can you tell me why you think that for RL<100R this current source won't work?
Also calculate Vce for RL = 9K.
Likes 1 person
So the ranges are incorrect?
or correct?
incorrect
So the active region is not in between 0.1V and 9V
If you assume that transistor is in saturation region for Vce<0.1V. In this case the active region (Vce range) is indeed between 0.1V and 9V. But still you have incorrect resistor range.
Likes 1 person
Jony130 can you look at what I did and tell me where I went wrong?
Vce voltage is not the voltage that "appears" across RL resistor.
V_RL = Vcc - Vce - Ve. So for Vce = 0.1V --->V_RL = (10V - 0.1V - 1V) = 8.9V.
And if Vce = 9V --->V_RL = ??
Likes 1 person
I'm lost .
I knew my answers were incorrect.
V(limit) was said to be the maximum before saturation
so the compliance voltage range is okay.
the load resistance range is not
so what do I do? Cause I don't get this now
Do you see the difference between Vce voltage and voltage across RL resistor?
Likes 1 person
Vce is a junction voltage, The voltage across RL is a branch voltage,
But I don't understand this range business.
What does range mean with respect to Vce and RL?
Q1. What is the voltage across V_RL if Vce = 0.1V ?
Q2. What is the voltage across V_RL if Vce = 9V ?
Likes 1 person
See I confused because I wasn't given an RL value,
Ic = Ie only during the active region so I have no currents,
I'm stuck like a duck.
You don't need to know RL value. First we need to know V_RL voltage range. Next we can use this range to find RL value. The only think you need is to find V_RL range by using KVL and find V_RL voltage.
Vcc-(ILxRL) - Vce = 0
10V-(IL x RL) -0.1 = 0
9.9V -(ILxRL) = 0
9.9V = ILxRL
9.9V/IL = RL
9.9V/1.0mA = RL
9.9 k(ohm) = RL
You forget about Ve voltage.
Likes 1 person
Vcc-(ILxRL) - Vce -Ve = 0
10V-(IL x RL) -0.1 - 1V= 0
8.9V -(ILxRL) = 0
8.9V = ILxRL
8.9V/IL = RL
8.9V/1.0mA = RL
8.9 k(ohm) = RL
So is this the lower or the upper limit?
8.9V -(ILxRL) = 0
8.9V = ILxRL
8.9V/IL = RL
8.9V/1.0mA = RL
8.9 k(ohm) = RL
Finally, some good work.
What do you think ?
Related to Voltage Compliance Range & Load Resistor Values for Current Source Circuit
What is the purpose of a voltage compliance range in a current source circuit?
The voltage compliance range specifies the maximum and minimum voltage that a current source can output while maintaining a constant current. It ensures that the circuit does not exceed its limits and protects the components from damage.
How do you calculate the voltage compliance range?
The voltage compliance range can be calculated by multiplying the maximum current output by the load resistor value. This will give the maximum voltage that the circuit can output without exceeding its limits. The minimum voltage can be calculated by dividing the minimum current output by the load resistor value.
Why is it important to choose the right load resistor value in a current source circuit?
The load resistor value determines the amount of current that will flow through the circuit. Choosing the right value is crucial because if it is too low, the circuit may draw too much current and damage the components. If it is too high, the circuit may not be able to supply enough current for the desired load.
What happens if the voltage compliance range is exceeded in a current source circuit?
If the voltage compliance range is exceeded, the current source may become unstable and may not be able to maintain a constant current. This can lead to damage to the circuit components and affect the accuracy of the current output. It is important to ensure that the voltage compliance range is not exceeded during operation.
How can the voltage compliance range and load resistor values be adjusted in a current source circuit?
The voltage compliance range can be adjusted by changing the maximum and minimum current output values, which can be controlled through the circuit's design or through external components such as potentiometers. The load resistor value can be adjusted by choosing a different resistor with a higher or lower resistance value.
