What are partial derivatives ?
In summary, Partial derivatives are used to get information about a function's behavior when one of its variables is kept constant.
kupid
34
Its about functions with two or more variables ?
Partial Derivatives in Calculus
Let f(x,y) be a function with two variables.
If we keep y constant and differentiate f (assuming f is differentiable) with respect to the variable x, we obtain what is called the partial derivative of f with respect to x
Similarly
If we keep x constant and differentiate f (assuming f is differentiable) with respect to the variable y, we obtain what is called the partial derivative of f with respect to y
How do you keep this x and y constant , i don't understand .
Hi kupid,
It means we treat them as constants, such as $3$.
Recall that the derivative of a constant is 0.
So if we consider x to be constant and differentiate it with respect to y, the result is 0.
To give a couple of examples:
$$\pd{}y x = 0 \\ \pd{}y (3x^2y) = 3x^2 \\ \pd{}y (xy^2) = 2xy$$
In reality x might actually be a function of y, but that's the difference between a total derivative and a partial derivative.
For a partial derivative we treat x just like any other constant, and its derivative is 0.
I like Serena ,
Thanks a lot :-)
From here is it possible to understand partial differential equations ?
kupid said:
I like Serena ,
Thanks a lot :-)
Well, that's a step up from just understanding what a partial derivative is.
But sure, why not.As an example, suppose we have the function $u(x,y)$.
And the partial differential equation
$$\pd{}x u(x,y)=0$$
Since we'd treat $y$ as a constant, the solution is some function of $y$.
That is, the solution is:
$$u(x,y) = f(y)$$
where $f$ is any arbitrary function of $y$.
We can see that if we take the partial derivative with respect to x, we will indeed get 0.
Thanks
1. What are partial derivatives?
Partial derivatives are mathematical tools used to measure the rate of change of a multivariable function with respect to one of its variables, while holding all other variables fixed.
2. Why are partial derivatives important?
Partial derivatives are important because they allow us to understand how changes in one variable affect the overall behavior of a function. They are also used in many fields of science and engineering, such as physics, economics, and engineering, to model and analyze complex systems.
3. How are partial derivatives calculated?
Partial derivatives are calculated by taking the derivative of a function with respect to one of its variables, while holding all other variables constant. This can be done using the standard rules of differentiation, such as the power rule and the chain rule.
4. What is the difference between partial derivatives and total derivatives?
The main difference between partial derivatives and total derivatives is that partial derivatives only measure the rate of change with respect to one variable, while holding all other variables constant. Total derivatives, on the other hand, measure the overall rate of change of a function, taking into account changes in all variables.
5. How are partial derivatives used in real-world applications?
Partial derivatives have a wide range of applications in various fields, such as physics, economics, and engineering. They are used to model and analyze complex systems, such as fluid flow, heat transfer, and economic markets. They are also used in optimization problems, where the goal is to find the optimal values of variables that maximize or minimize a function.
  • Calculus
  • Calculus
  • Calculus
