What are the uses of current sources?
In summary, current sources are used to measure the I-V curve of a semiconductor device, to bias transistors in an analog integrated circuit, and to power an LED backlighting panel.
Chander G
Hi everyone,
In our undergraduate electrical course,we came across current sources as theoretical concepts.
Are current sources used in real life(such as in electronics)?How important are they?
Thanks in advance.
Chander
Yes, current sources are used "for real" though not nearly as often as voltage sources. Here are two examples: 1) A current source is used to measure the I-V curve of a semiconductor device. 2) Current mirrors, which are a form of current source, are widely used inside analog integrated circuits to bias transistors, especially when devices must be matched (op amps, e.g.).
Thanks.
Yes, there are use of current source. One example used is for electromagnet as
[tex] \int_s \nabla \times \vec B \cdot d\vec S= \mu I[/tex]
So the magnetic flux density is controlled by the current through the electromagnet.
Driving an electromagnet with voltage source is not as accurate as the resistance of the winding can change with temperature. But using a constant current source, change of resistance only cause change of voltage across the electromagnet, the current remain constant and flux density theoretically remain constant. In most part it is true. I designed a magnetic controller using true constant current source to get accuracy into parts per million.
And yes, constant current source is used inside IC as active load. The definition of constant current source is having very high output impedance. It is used as active load for collector of BJT or drain for MOSFET in common emitter/common source stage to get maximum gain out of the stage.
I am not familiar with the latest LED light stuff, but LED is better run by constant current. If you drive LED with voltage source, you can burn the LED easily as once the LED turn on, the current increase exponentially with increase voltage across the LED. Also the LED turn on voltage change with temperature in a negative way, you can get into run off situation and burn the LED. Using constant current source, the current remain constant even the turn on voltage of the LED change.
I use them all the time for calibrating 4-20 Ma input cards.
Battery chargers. Most multi-stage chargers use a constant current source in at least part of the charging process. For a Lead-Acid battery it's usually during the bulk charge mode.
People have be very careful about constant current sources. The definition of current source implies the output impedance is infinite or at least very high. The current breed of so called current supply using switching design is not true current source. They are voltage source with a current sensing feedback to control the voltage. There are application that this will absolutely not work. Case in point for magnet control, using this kind of supply will slow down the speed tremendously. This is because unlike capacitor load where the lower the output impedance, the higher the speed. For inductor, the lower the impedance, the slower the speed. Remember for current time constant:
[tex]\tau=\frac L R [/tex]
We contracted out the current supply design out, and we got the switch mode supply and it absolutely failed. I had do design an analog supply with big MOSFET as current source to get the high impedance. Also remember the big capacitors of the switching supply would be in parallel with the electromagnet? That would be a parallel tank circuit! And it can sing!
One place I have used a current source is to drive the LED backlighting on a graphics display panel. If you don't want the backlighting changing brightness with varying power supply voltage (mobile 12 volt applications) this is what you do. I thought it was a better solution than regulating down to 8 volts or so and using a series resistor. The tolerance of the voltage on the LEDs varied enough so I didn't want to go with a voltage regulator and series resistor. I could have gone with a low dropout regulator and larger resistor for tighter current regulation but the cost went up. So, if configured a 5 volt regulator with a resistor to form a current source.
Related to What are the uses of current sources?
1. What is a current source?
A current source is an electronic component or circuit that is designed to provide a constant, steady flow of electrical current to a load. It is the opposite of a voltage source, which provides a constant voltage to a load.
2. What are the different types of current sources?
There are two main types of current sources: ideal and non-ideal. Ideal current sources provide a constant current regardless of the load, while non-ideal current sources may vary their output depending on the load.
3. What are the applications of current sources?
Current sources have a wide range of applications, including powering electronic devices, driving LEDs, and regulating the amount of current in a circuit. They are also commonly used in scientific research and experimentation.
4. How are current sources controlled?
Current sources can be controlled using various methods such as adjusting the resistance in the circuit, using feedback loop circuits, or by using transistors to regulate the current. The method used depends on the specific type of current source and its intended application.
5. What are the advantages of using current sources?
Current sources offer several advantages, including stability, accuracy, and protection against short circuits. They also allow for precise control over the amount of current in a circuit, making them useful for various applications in electronics and research.
  • Electrical Engineering
