What caused galaxies to start spinning?
In summary, the conversation discusses the concept of galaxies spinning and the role of angular momentum and external forces in causing this motion. It is explained that a quasi uniform gas cloud with zero total angular momentum can still form spinning galaxies due to variations in velocity. It is also noted that there is no such thing as a perfectly uniform blob of gas with zero angular momentum, and even if there was, it would not form a galaxy. The conversation concludes by stating that the smallest disturbance can cause a gas cloud to spin as it contracts, and this is why galaxies spin.
fbs7
345
37
If I take a big, uniform blob of gas that is not spinning, and mark its limit as the limit of a system, then even if that big blob of gas coalesces to make a galaxy, it will not start spinning by itself: its own gravity is an internal force, and conservation of angular momentum says I need an external force to add angular momentum to the system.
As galaxies spin, either:
(a) my big blob of gas was already spinning before it started to become a galaxy, or
(b) there was some external torque applied to my system
So, what's the best explanation as to why galaxies spin?
A quasi uniform gas cloud with zero total angular momentum, can form many spinning galaxies while preserving zero total angular momentum. They spin around different axes in different directions.
It's (a). The gas that later forms a single galaxy already has non zero total angular momentum. The closer it gets together, the higher the angular velocity becomes.
Ah, I see. So there's no such thing in reality as a uniform blob of gas with perfectly zero angular momentum relative to its center of mass. It will have some variations in velocity, and these variations create a non-zero angular momentum. The bigger the blob, the bigger the angular momentum generated by these irregularities.
Now that you explained, it seems obvious to me - the smallest disturbance will get the thing to spin as it contracts.
Thanks for the explanation! :smile:
It is statistically unlikely. And, event there was one, then it would not form a Galaxy, just collapse radially into a BH. So you never see those non-rotating Galaxies.
The most likely explanation for why galaxies spin is due to the conservation of angular momentum. As stated in the content, a big, uniform blob of gas will not start spinning by itself, and an external force is needed to add angular momentum to the system. This external force could come from a number of sources, such as the initial rotation of the gas cloud before it formed into a galaxy, interactions with nearby galaxies, or the gravitational pull of dark matter. These external forces can cause the gas cloud to start spinning, and as the gas collapses and forms into a galaxy, the conservation of angular momentum causes the galaxy to continue spinning. This is similar to how a figure skater spins faster when they bring their arms in closer to their body, due to the conservation of angular momentum. Therefore, it is likely that some external force played a role in initiating the spinning motion of galaxies.
Related to What caused galaxies to start spinning?
1. What is the main force that causes galaxies to start spinning?
The main force that causes galaxies to start spinning is gravity. As matter in the early universe began to clump together due to the force of gravity, it also began to rotate, eventually forming into galaxies.
2. Are there other factors besides gravity that contribute to the spinning of galaxies?
Yes, there are other factors that contribute to the spinning of galaxies, such as the initial angular momentum of the matter and the conservation of angular momentum as the matter collapses and forms into galaxies.
3. Can the direction of spin in galaxies be predicted?
No, the direction of spin in galaxies cannot be predicted. The initial angular momentum and the random collisions and mergers of galaxies can result in a variety of spin directions.
4. Do all galaxies spin at the same rate?
No, not all galaxies spin at the same rate. The rate of spin can vary depending on the amount of matter and the distribution of mass in the galaxy, as well as external influences such as interactions with neighboring galaxies.
5. Is the spinning of galaxies affected by dark matter?
Yes, the spinning of galaxies is affected by dark matter. Dark matter makes up a large portion of the mass of galaxies and its gravitational force contributes to the rotation and stability of galaxies.
  • Classical Physics
  • Astronomy and Astrophysics
  • Classical Physics
  • Classical Physics
