What happens to the System (s) energies throughout its journey?
In summary: The energy dissipated will be due to the heat created by the car’s engine as it climbs the mountain, so the amount of energy dissipated will depend on how steep the mountain is.Work: The work done by the car will be the sum of the work done climbing the mountain and the work done going down. It will depend on the height of the mountain and the total distance traveled.In summary, the energy of the source remains the same, the change in kinetic energy is constant, the change in potential energy depends on the height of the mountain, the amount of energy dissipated depends on the steepness of the mountain, and the work done is the sum of the work done climbing and going down the mountain.
pxp004
I really need help with conceptual understanding of this topic. Heres the question:
What happens to Energy of source, delta KE, delta Potential, delta Energy Dissipated, and Work of the systems in the question? Basically it's asking the initial and final of these.
The problem is: a car pulls a trailer along a road that climbs from sea level over a mountain and then back to sea level, where it continues to travel at a constant speed. In the process of climbing, the car's engine heats up substantially.
a) System: car, trailer, and earth
b) System: trailer only
c) System: car only
I'm a quick learner at analytical part but i need to understand the conceptual part first which takes me a while. Anyone want to explain the answers to me if you know it. Thanks!
Answer:a) System: car, trailer, and earthEnergy of Source: The energy of the source will remain the same, since no energy was added to the system.Delta KE: The change in kinetic energy will be the same throughout the system, since the car is traveling at a constant speed.Delta Potential: The change in potential energy for this system will depend on the height of the mountain, as the car and trailer climb up the mountain, their potential energy increases, and as they go down, it decreases.Delta Energy Dissipated: The energy dissipated will be due to the heat created by the car’s engine as it climbs the mountain, so the amount of energy dissipated will depend on how steep the mountain is.Work: The work done by the car and trailer will be the sum of the work done climbing the mountain and the work done going down. It will depend on the height of the mountain and the total distance traveled.b) System: trailer onlyEnergy of Source: The energy of the source will remain the same, since no energy was added to the system.Delta KE: The change in kinetic energy of the trailer will be the same throughout its travel, since it is traveling at a constant speed.Delta Potential: The change in potential energy for the trailer will depend on the height of the mountain, as the trailer climbs up the mountain, its potential energy increases, and as it goes down, it decreases.Delta Energy Dissipated: The trailer does not have an engine, so there will be no energy dissipated by it.Work: The work done by the trailer will be the sum of the work done climbing the mountain and the work done going down. It will depend on the height of the mountain and the total distance traveled. c) System: car onlyEnergy of Source: The energy of the source will remain the same, since no energy was added to the system.Delta KE: The change in kinetic energy of the car will be the same throughout its travel, since it is traveling at a constant speed.Delta Potential: The change in potential energy for the car will depend on the height of the mountain, as the car climbs up the mountain, its potential energy increases, and as it goes down, it decreases.Delta Energy Dissip
1. What is the first law of thermodynamics and how does it relate to the system's energy?
The first law of thermodynamics states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that the total energy of the system and its surroundings remains constant throughout its journey.
2. How does the concept of entropy play a role in the system's energy?
Entropy is a measure of the disorder or randomness in a system. As the system undergoes changes, its energy may be converted into different forms, resulting in an increase in entropy. This means that the system's energy may become less organized and more dispersed throughout its journey.
3. Can the system's energy be completely conserved?
In theory, yes. According to the first law of thermodynamics, the total energy of the system and its surroundings remains constant. However, in practice, there may be inefficiencies or losses in energy due to factors such as friction and heat transfer.
4. How do different types of systems behave in terms of energy transfer?
There are three types of systems: open, closed, and isolated. In an open system, energy and matter can be exchanged with its surroundings. In a closed system, only energy can be exchanged. In an isolated system, neither energy nor matter can be exchanged. The behavior of energy transfer in these systems depends on their respective boundaries and interactions with the surroundings.
5. Can the system's energy ever reach absolute zero?
Absolute zero is the lowest possible temperature, where all molecular motion stops. In theory, energy can continue to be transferred and dispersed in a system until it reaches absolute zero. However, practically, it is impossible to reach absolute zero as there will always be some level of residual energy and molecular motion present.
9K
15K
  • Classical Physics
