- 18,864
- 13,866
love itmfb said:#FFF4E5 as background color, while the threads with replies have #FDFDFD
I agree w/ that ... it's what PaintShop shows. This is what it looks like on my screen:mfb said:#FFF4E5 as background color, while the threads with replies have #FDFDFD
So you're seeing the same very low contrast that I'm now seeing? Let's lobby Greg to make the contrast a little higher.Evo said:It's barely noticeable. At first I didn't even notice until attention was called to it.
Yeah, it's not really noticeable. Greg, make it more distinct! Pwease.phinds said:So you're seeing the same very low contrast that I'm now seeing? Let's lobby Greg to make the contrast a little higher.
Thanks, Evo.
That's amazing considering that you are wearing sunglasses. Wait, maybe it's polarized somehow and THAT'S how you see it so clearly.Ryan_m_b said:Strange, it's clear as day for me.
What change? Do you mean from before PF 4.0 ? I think it's been the same since 4.0 started.Nugatory said:Weird - this change made the unanswered threads show up for the first time on my ancient iPad.
phinds said:What change? Do you mean from before PF 4.0 ? I think it's been the same since 4.0 started.
Interesting. Looks like I get the least contrast by looking straight on. Off center both the unanswered and the pined backgrounds get much darker. Dell monitor.DaveC426913 said:BTW, if you are not looking at your screen at the optimal angle, these subtle diffs can all but disappear. Try adjusting your eye-to-screen angle and see if that improves things.
For me, on a Dell laptop, if I look obliquely up at it, it is a darker peach/coral. If I look obliquely down at it, it is cyan! (complementary)dlgoff said:Interesting. Looks like I get the least contrast by looking straight on. Off center both the unanswered and the pined backgrounds get much darker. Dell monitor.
Interesting. You are quite right Dave. If I tilt my screen at a big angle away from straight on I see MUCH more contrast.DaveC426913 said:BTW, if you are not looking at your screen at the optimal angle, these subtle diffs can all but disappear. Try adjusting your eye-to-screen angle and see if that improves things.
Oh, I wanted to suggest bright red and blinking.DaveC426913 said:While it is subtle taken without context, in my opinion, it is quite sufficiently distinct when seen in the bulk of multiple rows. The point of a highlight such as this is that it should not be so glaring as to distract from the many other visual cues on a given page for other purposes.
Well, I found that by tilting my monitor WAY away from me, I see the contrast clearly. To get a contrast that I can see when the monitor is straight on will probably be more contrast for most folks than Greg wants to do.mfb said:Oh, I wanted to suggest bright red and blinking.
phinds: did you play around with the colors to see what would be visible on your monitor?
Is it possible that part of your screen backlight is missing?phinds said:Well, I found that by tilting my monitor WAY away from me, I see the contrast clearly. To get a contrast that I can see when the monitor is straight on will probably be more contrast for most folks than Greg wants to do.
No, the screen is beautifully colorful but the very subtle shades don't show up well straight on.m k said:Is it possible that part of your screen backlight is missing?
Change the background to f0f0f0.
Is there a difference between it and right box?
My vision is with Dave's, not from sides, only from very far up.
The right box is also different, very weak blue and red something.
Between tilt and straight direction there is also an angle, very clear one, where both boxes fade away.
This is a broad question and the answer will vary depending on the specific picture in question. It could be a technical issue such as poor lighting or composition, or it could be a more subjective issue such as the message or meaning of the picture.
There are certain elements that can make a picture appear "off" or unappealing, such as blurry or distorted images, improper color balance, or distracting background elements. However, ultimately the perception of what is "wrong" with a picture is subjective and can vary from person to person.
In some cases, yes. For example, if a picture is meant to convey a certain message or information, but it is completely unrelated or misleading, then it can be considered objectively wrong. However, in most cases, the perception of a picture being "wrong" is subjective and based on personal preferences.
There are several ways to improve a picture, depending on what is "wrong" with it. Some common techniques include adjusting the lighting, composition, or editing the image to enhance its colors or clarity. It can also be helpful to get feedback from others and consider their suggestions for improvement.
There are certain technical guidelines and principles that can help improve the overall quality of a picture, such as proper lighting and composition. However, when it comes to the content or message of a picture, there is no right or wrong way. It is ultimately up to the photographer's creative vision and personal style.
