Why does the heavier cart get greater velocity than the lighter one?
In summary: If you are saying that it surprises you that the final speed of the heavy cart is greater than the final speed of the lighter cart, then yes, I can see where your intuition might not have expected that, but it is perfectly understandable in terms of the conservation of momentum. The best example of that is the case where the masses are equal. After the collision the incoming cart has no velocity, and the originally stationary cart has all the velocity.Perhaps part of the reason you are having trouble understanding this is because you wrote your equation wrong. You wrote:Relevant Equations:: m1×v+m2×v= -(m1×Vo)+m2×VoThat
VitaminK
46
So I did this lab at school where we had to investigate conservation of momentum. A lighter cart was set in motion (friction free track) towards a heavier stationary cart. After collision the heavier cart got at greater velocity. Why? Are there any energy transformations occuring during the collision?
I'm thinking some of the kinetic energy and momentum from the lighter cart transferred to the heavier.
VitaminK said:
Homework Statement:: So I did this lab at school where we had to investigate conservation of momentum. A lighter cart was set in motion (friction free track) towards a heavier stationary cart. After collision the heavier cart got at greater velocity. Why? Are there any energy transformations occurring during the collision?
Did you expect that the lighter should just bounce off the heavier cart? Is your question how a lighter object can make a heavier one move at all?
Hi Pero K,
Yes, I expected the lighter to bounce off the heavier cart
VitaminK said:
Hi Pero K,
What if the cart is just a bit lighter? What if it was only ##1g## lighter? And does it matter how fast you fire the lighter cart? What if the lighter cart was moving at ##100m/s##?
Do you know how to work with the equations of momentum conservation?
Velocity matter because I get greater kinetic energy. Some of it would transfer to the other cart during collision.
I do know how to work the equation and I am familiar with the law of conservation of momentum.
Good. Can you post some analysis of the momentum conservation in this case?
phinds said:
Fair enough but I think my analogy was a good one and he's only focused on the analogy, not on what it means.
I also gave him a strong hint on how to expand his understanding of the situation and there's no follow-up on that either.
Well surprise I'm not a he.
In my case the momentum Before and after collision differ by 0,0002684565kgm/s. Can I in this cases say that the system cannot be considered as isolated
What's your experimental margin of error?
Likes hutchphd
Haven't calculated that. My teacher wants us to just calculate the before and after momentum and then discuss potential sources of error (high school physics)
Okay, so that's what you need to do. Analyse potential sources of error.
It is possible we are misunderstanding your question. You say that after the collision the heavy cart “got a greater velocity”. Many have answered as if you were surprised that the heavier cart had greater velocity than it started with, i.e. zero. That is to say you were surprised the larger cart had any velocity at all. However, from your follow on posts it sounds like you understand that the heavier cart should wind up with some velocity, but perhaps you are surprised by how much velocity.
When you say “greater velocity” what do you mean? Greater than what? What is it about the final velocity of the large cart that surprises you?
That is incorrect. The idea is that the total momentum of the two carts does not change before and after the collisions. You need to distinguish their individual initial and final velocities:
##m_1 v_{1i }+ m_2 v_{2i} = m_1 v_{1f} + m_2 v_{2f}##
The initial velocity of the second cart is zero so this becomes
##m_1 v_{1i } = m_1 v_{1f} + m_2 v_{2f}##
The velocities have direction which will come in here as signs.
To go further you need to say something more about the collision. In physics problems they almost always use one of two easy to calculate extremes: A) perfectly elastic implying that energy is conserved or B) perfectly inelastic, implying that the objects stick together and the final velocities are the same.
Likes Lnewqban, hutchphd and PeroK
You should include the words "for a purely elastic collision" here I think. And it always surprises me when I see it.
Likes phinds
1. Why does the heavier cart get greater velocity than the lighter one?
This is due to the principle of inertia, which states that an object at rest or in motion will remain in that state unless acted upon by an external force. In this case, the heavier cart has more mass and therefore more inertia, making it harder to change its velocity. This means that it will take more force to accelerate the heavier cart, resulting in a greater velocity compared to the lighter cart.
2. What factors affect the velocity of an object?
The velocity of an object is affected by its mass, the applied force, and the presence of external forces such as friction or air resistance. The larger the mass of an object, the more force is needed to accelerate it and the greater its resulting velocity. Additionally, any external forces acting on the object will also impact its velocity.
3. How does Newton's second law explain the relationship between an object's mass and velocity?
According to Newton's second law of motion, the acceleration of an object is directly proportional to the net force applied to it and inversely proportional to its mass. This means that an object with a larger mass will require a greater force to accelerate it, resulting in a smaller acceleration and therefore a lower velocity compared to an object with a smaller mass.
4. Can the velocity of an object be equal to zero?
Yes, the velocity of an object can be equal to zero if it is at rest or if it is moving at a constant speed in a straight line. This means that there is no change in its position over time and therefore no change in its velocity.
5. How does the velocity of an object change over time?
The velocity of an object can change over time if there is a net force acting on it. This change in velocity is known as acceleration and can either be positive (speeding up) or negative (slowing down) depending on the direction of the applied force. The magnitude of the velocity change will depend on the strength and duration of the applied force.
