Why is magnitude g instead of vector g used in range projectile
In summary: The equation you're asked to use: x = \frac{v_0^2}{g}sin{2Θ}is derived from: y=\frac{-gt^2}{2}+V_{y_0}t+y_0 andx=V_{x_0}t+x_0
negation
818
It is not being explained anywhere in my book nor on the internet.
Can someone explain to me why?
Science news on Phys.org
It's because in projectile motion treatment, the positive value of displacement is assumed to be "up", and accordingly all derivatives have the same assumption embedded in them. V is "up" and -V is "down". a is "up" and -a is "down".
On the surface of Earth, the magnitude of the acceleration vector is assumed to be g, and it's direction "-", or "down", i.e., towards the negative values.
You can use proper vector notation and get the same results. It's just that most textbooks tackle projectile motion before properly explaining vectors.
Correct. g = -9.8ms^-2
However, in a question I posted, I was told not to take g = -9.8ms^-2 but, rather, 9.8ms^-2 without the implication of the direction.
Why question then is why?
In calculating range projectile, should g be a vector g where if upwards is +, then downwards i -. So in utilizing the equation for range projectile, g should be -9.8. However, a poster told me to disregard the signs and take g as a magnitude. This doesn't make sense. Acceleration of gravity is acting on the object during its trajectory.
As long as you use a reference frame in which the displacement "upwards" is in the positve direction, you have to use -g, since that's the direction towards which the gravity acts.
As far as I can see from your posts in the other thread I think you're referring to, the problem is that you use the negative value for g twice, so to speak, and thus get the wrong result.
The general equation for projectile motion is: [itex]r=\frac{at^2}{2}+V_0t+r_0[/itex], where r, a, and V are vectors.
If you reduce the equation to one dimension(y; where the positive values are "up"), you can simply say that [itex]a_y=-g[/itex], you end up with [itex]y=\frac{-gt^2}{2}+V_{y0}t+y_0[/itex]
You seem to be wrongly using [itex]r=\frac{-at^2}{2}+V_0t+r_0[/itex]
and then substituting [itex]a_y=-g[/itex], which erroneously gives you [itex]y=\frac{gt^2}{2}+V_{y0}t+y_0[/itex]
That's all there is to it.
I guess something might've been unclear in the above post. I meant g to be equal to +9.81 in it. It's the magnitude of the gravitational acceleration. The direction is the minus sign you put into the equation when you substitute -g for ay.
I was referring to this
https://www.physicsforums.com/showthread.php?t=730711
If my value for g = -9.8, I get a correct value but in the negative. The book has a positive value. This means that, and echoed by another poster, that g must be positive.
The confusion is, why should g in this equation be a magnitude. It doesn't make an iota of sense.
The value of g is not -9.8. It's 9.8. If you're asked to substitute the value of the scalar g into your equation, you substitute the value without any information about the direction of the vector(i.e., the '-' sign). If you see g in an equation, it's a safe bet the direction was already included at one time.
If you were asked to substitute some value for the vector ##a_y## then you'd have to put the minus together with the magnitude(g), as you'd be asked to provide the full information.
The equation you're asked to use: [itex]x = \frac{v_0^2}{g}sin{2Θ}[/itex]
is derived from:
[tex]y=\frac{-gt^2}{2}+V_{y_0}t+y_0[/tex]
and
[tex]x=V_{x_0}t+x_0[/tex]
the minus sign was already included when we substituted ##a_y=-g## when we reduced the general vector equation to one dimension.
Try solving the first one for t, then substitute the result to the second one, and you'll see what happened to the minus sign that was originally there.
Likes 1 person
is derived from:
and
You are correct.
Related to Why is magnitude g instead of vector g used in range projectile
1. Why is magnitude g used instead of vector g in range projectile?
The use of magnitude g instead of vector g in range projectile calculations is based on the assumption that the projectile is only affected by the force of gravity in the vertical direction. This simplifies the calculations and allows for a more accurate prediction of the projectile's range.
2. How is magnitude g calculated for range projectile?
Magnitude g is typically calculated by multiplying the acceleration due to gravity, which is approximately 9.8 m/s^2, by the sine of the launch angle. This takes into account the vertical component of the projectile's motion.
3. Can vector g be used in range projectile calculations?
While vector g can technically be used in range projectile calculations, it is not commonly done so due to the complexity it adds. Vector g takes into account both the magnitude and direction of the force of gravity, which can vary based on the location and orientation of the projectile.
4. Is magnitude g always accurate for range projectile calculations?
No, magnitude g is not always accurate for range projectile calculations. It is based on several simplifying assumptions and does not take into account factors such as air resistance and wind, which can affect the trajectory of the projectile.
5. How does using magnitude g instead of vector g affect the range of a projectile?
Using magnitude g instead of vector g in range projectile calculations can lead to a slight underestimation of the projectile's range. This is because vector g considers the horizontal component of the projectile's motion, which can contribute to its total range.
  • Mechanics
21K
  • Classical Physics
