Che8833
- 4
- Homework Statement
- Suppose the force exerted by a spring is F(x) = -kx and the spring has constant k = 325 N/m. Then suppose a wooden cube headed east with mass m = 6 kg traveling with an initial velocity on a level surface with kinetic coefficient of friction 0.250 presses against the spring and it compresses from x = 0 to x = 0.70 meters as it stops. What is the net work done? HINT: You need to integrate to solve.
- Relevant Equations
- F(x) = -kx and the spring has constant k = 325 N/m
Kinetic coefficient of friction 0.250
Spring compresses from x = 0 to x = 0.70 meters
W_net = Integral from 0 to 0.70 meters [ - F_spring - F_friction ]
= 1/2 * (-k) * x^2 - mu * mg * normal force * x
= 1/2 * (-325N/m) * (.70)^2 - 0.250 * 6kg * 9.81m/s^2 * 0.70 - 0
= - 89.93 Joules
Is this correct and am I setting this whole thing up correctly? The negative signs have me bit confused. Also, am I supposed to integrate the Force of friction like this or do I treat it as a constant?
Thanks for the help
= - 89.93 Joules
Thanks for the help
