Wronskian to determine L.D
In summary: I did matrix form and put them in all in the same column the determinant would be the wronskian.In summary, the wronskian of a system of linear equations is a 2 by 2 determinant. If the system has three solutions, then the wronskian will be a 3 by 3 determinant.
BrettJimison
81
Hello,
I was just looking for a quick tip:
If I have three distinct solutions to a second order linear homogeneous d.e, how would I show that the wronskian of (y1,y2,y3)(x)=0?
I know how to show the wronskian is not zero for a linearly independent set, but I'm confused since I'm given three distinct solutions to a second order.
I know y=c1y1+c2y2+c3y3 by the principle of super position but I'm not sure how I would go about showing a wronskian evaluated at these is zero...any tips? just need a point in the right direction
BrettJimison said:
Hello,
The Wronskian in the case of a 2nd order DE is a 2 by 2 determinant. What does the Wronskian of three solutions mean?
[Edit] Or maybe you mean the 3 by 3 Wronskian anyway? In which case you know they are linearly dependent from the DE so...
I'm trying to find a 3x3 wronskian with y1 y2 y3 that is equal to zero...not sure how to do it symbolically. It's a lot easier when I know the functions...
What theorems do you have about Wronskians and linear dependence/independence?
Well I know the set will be linearly dependet since the wronskian will equal zero. I also know that the set has to be L.D since it has 3 elements and the D.E is only 2nd order.
If
L2[ y1]=0
L2[y2]=0
l2[y3]=0
Then
y1=c1y2+c2y3
y2=c1y1+c2y3
y3=c1y1+c2y2
I then have three functions that I can plug into the wronskian...I tried this and got a soltion that doesn't seem to simplify to zero.
If
L2[ y1]=0
L2[y2]=0
l2[y3]=0
Then
y1=c1y2+c2y3
y2=c1y1+c2y3
y3=c1y1+c2y2
Also letting a=y1, b=y2, c=y3
My determinatnt simplfies to: a"(bc'-b'c)+a'(b"c-c"c)+a(b'c"-b"c')
No, you don't know that. You are trying to show the Wronskian is zero.
Yes. You do know the 3 functions are linearly dependent and that is why.
Now think about what being linearly dependent tells you about the system of equations
##c_1y_1 + c_2y_2 + c_3y_3 = 0##
##c_1y_1' + c_2y_2' + c_3y_3' = 0##
##c_1y_1'' + c_2y_2'' + c_3y_3'' = 0##
and what that implies about the Wronskian.
Well...I know If I put that into matrix form its determintant will be the wronskian. I am taking its determinant now but its not looking like its going to cancell out...
edit: I know that those equations are L.D which means they can be wriiten as linear combos of each other..
I actually get exactly what I posted previously...hmmm
The thing is: I know the set of equations is L.D and I know the wronskian will be zero. I have no idea how to show its zero though. When I take the determinant of the matrix, I don't get something that cancells
[edit] I understand why its not zero: I am basically evaluating a wronskian of a set of solutions for L3[y] so I won't equal zero...I need to find a way to get the three equations into a different form?
You aren't expected to actually calculate the determinant. You have ##n## equations in the ##n## unknown ##c_i##'s. What would you know about the ##c_i##'s if the determinant of coefficients (the Wronskian) wasn't zero? What would Cramer's rule tell you?
If the determinant wasnt zero (wronskian) then that means that there is non trivial solutions to the system which means linear dependence but I don't know how to show that since I can't compute the wronskian to show that it isn't zero...
Im pretty sure cramers rule would just tell us we could find non trivial solutions...
No. Think about what you are saying. Try a little 2 by 2 system:
##x + y = 0##
##2x - y = 0##
Here the determinant of coefficients isn't zero. Solve it with Cramer's rule.
The SPECIFIC question states:
Suppose y1,y2,y3 are three distinct solutions of L2[y] =0 on I = (a,b)
Show that W(y1,y2,y3)(x)=0 on I.
##x + y = 0##
##2x - y = 0##
Sorry meant to say if the determinant WAS zero...typo, this is what I have been trying to prove the whole time.
But what if the determinant isn't zero. What does that tell you? What does that say about your system of equations?
I have to run for now. Back in a couple of hours.
Ok Thanks for your time!
If the Det wasnt zero, then equations would be linearly independent and ONLY the trivial solution would work.
I can explain my reasoning in words, but I am having a hard time putting it into math...
Thanks!
Thanks!
There isn't much math to write, but you need to be careful about your notation. You don't talk about "equations being linearly independent" in this context. You talk about the functions ##y_1,...y_n## being independent. What you have stated above that is correct and relevant is that if the determinant is zero, you can get only trivial solutions for the ##c_i##'s. But you know the solutions are linearly dependent so there is a non-trivial solution for the ##c_i##'s. So, what do you conclude?
There isn't much math to write, but you need to be careful about your notation. You don't talk about "equations being linearly independent" in this context. You talk about the functions ##y_1,...y_n## being independent. What you have stated above that is correct and relevant is that if the determinant is nonzero, you can get only trivial solutions for the ##c_i##'s. But you know the solutions are linearly dependent so there is a non-trivial solution for the ##c_i##'s. So, what do you conclude?
Likes BrettJimison
W(y1,y2,y3)(x)=0 Thanks for your time and help!
Related to Wronskian to determine L.D
1. What is a Wronskian and how is it used to determine linear dependence?
A Wronskian is a mathematical tool used to determine linear dependence between a set of functions. It is a determinant formed by arranging the functions in a matrix and taking the derivatives of each function. If the Wronskian is equal to zero, the functions are linearly dependent. If it is non-zero, the functions are linearly independent.
2. Can the Wronskian be used to determine linear dependence for any number of functions?
Yes, the Wronskian can be used to determine linear dependence for any number of functions. It is not limited to just two or three functions, but can be used for any set of functions.
3. How is the Wronskian calculated?
To calculate the Wronskian, first arrange the functions in a matrix, with the first row containing the functions, the second row containing their first derivatives, the third row containing their second derivatives, and so on. Then, take the determinant of the matrix to get the Wronskian.
4. What does it mean if the Wronskian is equal to zero?
If the Wronskian is equal to zero, it means that the functions are linearly dependent. This means that one function can be expressed as a linear combination of the other functions in the set.
5. Can the Wronskian be used to determine linear dependence for non-polynomial functions?
Yes, the Wronskian can be used for both polynomial and non-polynomial functions. It is a general method for determining linear dependence and can be applied to any set of functions, regardless of their form.
