Vector addition in electric field
The problem involves calculating the net force on a point charge due to two other point charges using Coulomb's law. The charges are located at specified coordinates, and the task is to determine both the magnitude and direction of the force exerted on one of the charges.
  • Participants discuss the application of Coulomb's law to find forces between charges and break them into components. There are questions about the signs of the components and the direction of the forces involved.
Participants are actively clarifying the setup of the problem, including charge values and positions. There is ongoing exploration of how to correctly calculate and interpret the components of the forces acting on the charge in question.
Some participants express confusion regarding the initial problem statement and the need for clearer definitions of the charges and their locations. There is also a focus on ensuring the correct interpretation of vector directions and magnitudes.
hteezy
Two positive charges = = 2.0 are located at = 0, = 0.30 and = 0, = -0.30 , respectively. Third point charge = 4.0 is located at = 0.40 , = 0.What is the net force ((a)magnitude and (b)direction) on charge exerted by the other two charges?
Columbs law (force between two point charges)
F = 1/4 piEo times abs value of q1*q2 divided by r^2
first i have to find the force that Q exerts on q1 (F1 on q1)
i use coulumbs law
F = k * [q1q2]/[r^2]
k = 8.988 e 9
so i plug in q1 and Q and the distance between them and i get...
F1 on q1 = .29
i break that down into components x and y
F1x= .29cos(.40/.50) = .287
F1y = .29sin(.30/.50) = .00301
so now i find the force that q2 exerted on q1 (F2 on q1)
q2 and q1 are both on the vertical axis so there will only be a y component
so i use cuolumbs law again and now i plug in q1 and q2 and r is the distance between them so..
F2= k [2.0 e -6][2.0 e -6] / (.60 ^2) = .1
so now i add the x components and y components up
there is only one x component and 2 y components sooo
F1x = .287
F1y + F2y = .10301
F = square root of ( .287^2 + .10301^2)
which is equal to .30 (2 sig figs)
then to find the angle i would use tan(theta) = Fy/Fx
which gives me an angle of 19.7 degrees
It is supposed to be in the +x direction so i think i am supposed to subtract it from 180 and that should give me my angle
im afraid to type the answer in into masterinphysics because i have only a few attempts left...so i want to make sure I am right before i do anything!
It's hard to understand what you've written (when I compare it to what follows). Please fill in the gaps. What are the charges? Where are they? (I assume those are x and y coordinates?) You need the force on which charge?
i use coulumbs law
k = 8.988 e 9
OK.
F1 on q1 = .29
Redo these calculations. Also: Direction (and thus signs) counts.
redo
opps sorry the question didnt copy right. my fault
Two positive charges q1 = q2 = 2.0 \muC are located at coordinate (0,.30) meters and (0,-.30) meters, respectively. The third point charge Q = 4.0 \muC and is located at (.40,0) meters. What is the net force magnitude and direction on chare q1 exerted by the other two charges.
i made a lil drawing so that it could help give a visual...its attached
So first i found the force exerted by Q on q1 which i will call F1
the diff between q1 and Q is .50 meters
F1 on q1 = k (2.0 e -6)(4.0 e -6) / (.50^2) = .29 N
i then had to break that down into x and y components
i need to use cosine for the x component so... = F1 * cos (.40/.50)
and then the y component would be = F1 * sin (.30/.50)
i hope that makes sense now
Much better.
Good. That's the magnitude of the force.
F1*cos(theta) = F1*(.40/.50)
F1*sin(theta) = F1*(.30/.50)
Those are the magnitudes of the components. What are their signs?
signs?
:confused: I guess they are positive?
Draw yourself a picture of the force that Q exerts on q1. Which way does the vector point?
ok so the force that Q exerts on q1 is negative
and the force that q2 exerts on q1 is positive
so F1 and its components are negative?
actually no...only the x component is in the negative direction for F1
the y component of F1 is still positive
I don't understand what you mean by saying that the force is negative or positive.
F1 is shown on your diagram in post #3. Which way does its x-component point? Its y-component?
its x component points in the - x direction
the y comp. points in the + y direction
Right!
ok and the force exerted by q2 on q1 (F2) is also in the positve y direction
and there is no x component for that force
so now that i know the components for all the forces do i just add them all up...add the y component of F1 and F2 together?
then do i just add the final x and y components together?
and that would be the magnitude of the force exerted on q1 by the other two charges right?
Good.
Yes.
No. The x and y components are perpendicular to each other--so you can't just add them like numbers. How do you find the magnitude (and direction) of a vector, given its components?
F = \sqrt{}(Fx^2 + Fy^2)
ok i think i got it...Thank you very much for your help! :smile:
14K
  • · Replies 16 ·
