An abstract long-distance correlation experiment
242 replies · 34K views · last reply
stevendaryl said:
Let's split up the universe into three parts:
  1. The part λ relevant to the production of the twin-pair.
  2. The part α relevant to Alice's choice of her detector setting.
  3. The part β relevant to Bob's choice of his detector setting.
Why isn't there a fourth part ##\gamma##, relevant to both Alice's and Bob's choice of detector setting? You make the assumption that this part is empty, but I cannot see a good reason for it. Thus ##F_A## and ##F_B## also depend on ##\gamma##, and Bell's argument breaks down.
I am confused... so you think the weirdness comes from thinking in terms of particles...
"classical relativistic field theories have no problem at all as long as one doesn't introduce point particles"
But do you say changes in the fields that you have in that case still propagate at a finite speed (you used the term "relativistic", so I guess yes)? Then such a model can not reproduce Bell violations.
On the other hand if you have instantaneous or FTL changes in the fields, you already have non-locality, and hence weirdness.
I do not see how the FTL field changes in Newtonian mechanics (which is now known to be wrong) not being considered weird in the past supports your view that FTL changes in QM should not seem weird now.
Yes, most of it. All of it comes from mixing in an inappropriate way different intuitions coming from incompatible formal settings.
Note that I discuss classical weirdness by analogy rather than by giving a model that would explain the quantum results. Quantum mechanics makes predictions different from classical mechnaics hence shouldn't be explained in terms of the latter. I mainly argued two points:
1. Introducing no faster than light arguments into an otherwise completely nonrelativistic setting produces contradictions already in classical theories. This is relevant - even if though classical theories are known to be approximations only - since weirdness is clearly primarily deviation from classical intuition. Hence if classical thinking in approximate classical theories such as celestial mechanics or hydromechnaics is already incompatible with no faster than light arguments, the weirdness is already due to this and not primarily to the quantum features.
2. In a classical relativistic setting, the notion of a 2-particle system is already ill-defined and fraught with conceptual difficulties. Only a single particle has a good relativistic description.
Why ##\gamma## can't be included into ##\lambda## ? What's so specific about ##\gamma## ?
Neumaier, since back when instantaneous field were the norm we found out that spacetime is locally Minkowskian (as verified by atomic clocks on fast airplanes), so whatever the framework of the theory is, the Bell violations as proven by experimental loophole-free Bell tests (especially those avoiding the communication loophole) are still weird even if you abandon the particle idea.
All the Minkowski/relativistic principles you are applying are verified for macroscopic scales. A bunch of 'events' are happening in only a few microseconds, and robots are telling you they happened in a certain order - and gave certain measurement results. We then ascribe other events as being simultaneous with those. I would not stake a penny on that assumption being right unless I saw it with my own eyes. Which is impossible.
Applying billiard-ball dynamics is not appropriate.
So you would stake on the fact that, if we could maintain coherence for big enough distances, "nature's prank" would stop working? We've already gone a mile. I don't think there's any reason to believe that.
zonde said:
What's so specific about γ?
That (unlike ##\lambda##, if I interpret its definition correctly) it is not determined by local information.
It is a nontrivial restriction to assume that every piece of information must have originated at a single local point. It is this restriction that excludes nonlocal correlations.
It is natural fur us humans to assume this since we can generate and transmit information only locally. But Nature (being far bigger than a human or a machine built by humans) is not necessarily bound in this way, and Bell-type experiments prove that it really isn't.
So you say that weirdness is a function of our knowledge about Nature? Then after a century of having found out that Nature is quantum we should have long adapted our conception of weirdness to find the clash between classical relativistic thinking and quantum mechanics natural (non-weird) in the same way that we no longer find the clash between instantaneous action and relativity weird.
A. Neumaier said:
Local in local hidden variable theories cannot mean anything related to relativity theory - all of quantum mechanics is purely nonrelativistic!
I don't see your point here. Bell's Theorem is a statement about which results cannot be reproduced by local, realist, counterfactual definite models. Such models, by definition, respect the light- speed boundary.
A. Neumaier said:
Indeed, I have never seen a Bell-type argument where formal use was made of the the fact that values depend or do not depend on the past light cone. The arguments never involve space or time at all, only simultaneity, which is intrinsically nonrelativistic!
If we allow FTL influences, then Bell's Theorem certainly does not apply! That's why we have models like Bohmian Mechanics or Continuous Reduction.
Here is a short sketch of Bell's logic:
1.Given locality, and spacelike separation, Alice's detector settings and measurement result have no effect on Bob's measurement result.
2.Therefore, Bob's results depend only on the signal in Bob's region, and his settings.
3.Given that, for any setting Bob chooses, there is a hypothetical scenario in which his result can be known before the measurement, the result must be fully determined by the signal in Bob's region, for any detector setting.
4. Therefore, the only way probability enters is in the distribution of the signals: a probability of 3/4, say, for a measurement to find positive spin in some direction means that 3/4 of the signals are such that will definitely give the positive result for that measurement.
5. Now comes the formal algebraic part: there is no distribution that matches the quantum (experimental) probabilities for all settings.
6.Conclusion: one of the assumptions - locality, realism, or counterfactual definiteness- is not true of Nature.
Without the "no FTL" assumption, the measurements can affect each other, and the argument does not begin.
The weirdness discussed here is not "deviation from intuition". It's more like "inability to form a picture of the fundamental reality". This is only relevant for models that are intended to be fundamentally accurate.
I don't know of these difficulties. Please elaborate. Anyway, adding more problems does not a solution make!
We are trying. We have tried for a century, and thus far our efforts have been met with failure. This thread is part of the ongoing attempt.
The culprit is the form of locality assumed in 1. to be able to conclude 2. This form of locality is not realized in Nature. However, Assumption 1 is a far stronger assumption than what follows from relativity = Lorentz invariance alone.
This is what I mean when I say that the physical substance is always in the formulas and not in the story created around them, and that Bell's theorem isn't making the formal connection to relativity theory. The latter is obvious in your synopsis since the setting given is manifestly non-invariant and the Lorentz group isn't even mentioned.
Modern relativity is the claim that Nature is ruled by Lorentz invariant laws, nothing else. Every valid claim about conflicts with relativity must produce a contradiction with Lorentz invariance, not only with one of the fuzzy verbal phrases such as ''no FTL influences''. The (serious) step missing is to deduce from Lorentz invariance that, in a formally precise sense, there are ''no FTL influences'', and then to conclude Step 2 from this formally precise meaning of ''no FTL influences''.
To me it seems to articulate the ''inability to form a classical picture of the fundamental reality" - since the quantum picture is obviously an appropriate representation of fundamental reality. It allows us to predict and control a lot of stuff that 100 years ago were science fiction only.
The merit of these threads is that I've had my notion of weirdness clarified. At the very substance, it ended up being less about intuition and more about "undecidable" quandaries. Steveandaryl put it best imho: "what's weird is the lack of an answer to some basic questions about QM, particular to the EPR experiment". We can concoct some answers but they're all mutually exclusive, unfalsifiable and, worse, all have more or less an ad-hoc feel to them. They're not what physics' tradition considers elegant and sound; some are even on the wild speculations spectrum.
Yes, Bell locality is intended as a stronger assumption than "relativity holds". It is justified (for me) by:
1.The intuition that causation occurs from past to present to future, in an objective sense. Since relativity does not define regions outside the light-cone as "past" or "future", causation should be confined to this cone.
2.FTL signalling would imply a possibility of sending messages to the past, and I see no fundamental reason why signals should differ from other forms of influence.
Therefore, to me, the violation of locality is weird.
But the reason we got into "locality" was to explain the difference between EPR experiments and ones that can be explained classically, such as the polarization example in your slides. All relativistic classical descriptions are also local in Bell's sense. In those cases, "probability inequalities" indeed result only from assuming a particle concept,(which is "quantum" and certainly not classical). This is not the case for Bell's Theorem. No local realist model, whether involving particles, fields, or anything else, can violate the inequality.
That brings up another point: as far as I know, no Lorentz invariant description has ever been given for QM including measurements. To me this is a hint that something important is missing from the fundamentals.
Ability to predict and control does not imply understanding. By a "picture of reality" I mean the ability to answer simple questions like "if an electron propagates through space as a wave, and then is detected at one point, what happens to the rest of the wave?"
This was not part of a solution - which is partly indicated in this post - but part of my argument that weirdness is not in the quantum part but in the particle part.
The problems involved in a classical multiparticle setting are addressed in a post of the PF thread ''Introduction to relativistic quantum mechanics and maybe QFT'' and the subsequent discussion,
together with the references provided there. Discussion of this point should be done there, not here.
It would be enough to have a language that forbids asking questions such as this because they are meaningless.
A. Neumaier said:
I know that Bell (like earlier Einstein) used causality to motivate the experiment and to deduce nonlocality, but my emphasis was on ''formal use made of'' it. No formula involves anything relativistic - only the talk around it does.
Precisely what "formal use" were you expecting? The motivation behind Bell's theorem is that relativity implies that the order of spacelike separated events is reference-frame dependent, so that the simplistic idea of causality we're used to breaks down if faster-than-light causal influences are allowed. Where the speed of light ends up in practice in Bell experiments is that it determines how stringent the timing of selection of detector settings and recording of outcomes has to be in order that it's the "no FTL causal influences" assumption that is being tested instead of something else. Bell doesn't spell all of this out because he assumes you, the reader, understand relativity and should find all of this obvious.
From my point of view, nothing more mysterious happens in Bell's experiment [...]
What you personally find intuitive or mysterious is subjective and not the issue here. You've made more specific claims that are unjustified, e.g., that Bell's theorem relies on a "particle" assumption and that it doesn't apply to classical electromagnetism.
[...] since exactly the same algebra is used [...]
So? Bell's theorem is not an exercise in pure mathematics. It is meant to say something about physics and, as such, the context in which Bell's algebra is applied matters.
The point is that Alice's and Bob's choice of detector settings can be made at a spacelike separation. There is no reason to assume that their choices have anything in common. For example, let's suppose that each of them is carrying a little chunk of uranium, and they base their decision on which setting to choose on the number of decays (indicated by Geiger counter clicks) in a certain time interval. Then aren't those two choices completely independent? (At least, according to mainstream QM)
IMO those two choices (say a and b) are completely independent. But, wondering if this next is an acceptable statement, I would like to add: The detectors are not independent.
The spacelike-separated detectors are correlated by a simple function of the two independent choices, the scalar product of a and b. So with C = a.b: C = +1 = parallel, C = 0 = orthogonal, C = -1 = anti-parallel, with physically-meaningful intermediate values. So IMO independent inputs do not deliver independent detectors when it comes to correlation. This seems to me to be a basis for understanding the correlation in "An abstract long-distance correlation experiment" before any experiment has been done.
But I disagree with the "nothing else" part.
I'd have said that (special) relativity encompasses at least the Poincare group, restricted by some other empirically-motivated principles such as the (apparent) non-existence of tachyons, and +ve energy. I.e., causality is certainly part of modern relativity (else "modern relativity" would make false predictions).
Yes, modern relativity in the absence of gravity. It's one of the puzzles of physics how the Wigner theory (which starts with Poincaré invariance) leads to the theoretical possibility of tachyons, thus to a breach of the theory it started from.
I'm not sure that I understand your point, but I'm not saying that there is no correlation between the detectors. What I'm trying to do is to factor the influences on the outcomes of the detectors into things that are shared between the two detectors, and the things that are not shared. So if the outcome at Alice's detector is determined (and that seems to be what A. Neumaier is saying--that if you could take into account the entire rest of the environment, that the outcomes become deterministic, in the same way that a coin flip is deterministic, if you only knew enough about breezes and the distribution of mass, etc.) and there are no FTL influences, then it would seem that Alice's result must be a deterministic function of what Alice and Bob share, plus what influences Alice alone. In my earlier post, [itex]\lambda[/itex] represents everything that Alice and Bob had in common, and [itex]\alpha[/itex] represents what was unique to Alice (e.g., her lump of uranium, if that's what she's using to pick her detector setting), and [itex]\beta[/itex] represents what's unique to Bob (his lump of uranium). So if [itex]\alpha[/itex] and [itex]\beta[/itex] are independent, then that would seem to me to mean that Alice's result depends only on [itex]\alpha[/itex] and [itex]\lambda[/itex], while Bob's result depends only on [itex]\beta[/itex] and [itex]\lambda[/itex]. It doesn't actually matter whether [itex]\lambda[/itex] itself is local, or nonlocal. It only matters that Alice's result cannot depend on [itex]\beta[/itex] and Bob's result cannot depend on [itex]\alpha[/itex].
Instead of uranium they could be using light from distant galaxies from two antipodal regions of the sky. It's not far-fetched if you do the experiment on the ISS. Honestly, I think it drives superdeterminism to utter absurdity.
It does not matter how ##\gamma## is determined as long as it is independent from Alice's and Bob's measurement settings. Then it is shared information just like ##\lambda## .
There is no such assumption. There can be information that appears at two different locations independently. We even have a name for such information. It's called "coincidence".
The possibility of such a separation assumes that the ''things'' are located at points. But it is precisely this idealization that plays havoc, already in classical relativity. In quantum field theory, it also causes initially problems (infinite interactions), which are then removed by renormalization. But renormalization turns point particles into point-like particles, which are (in principle infinitely) extended.
Yes, special relativity encompasses the Poincare group, but relativity as such doesn't, as field theory in curved spaces (where the translation group is explictly broken but the local Lorentz groups are still intact) shows.
In quantum field theory we have to add unitaity and local commutativity, which automatically excludes tachyons. Classically, tachyons are not forbidden, and indeed Crenkov radiation is a tachyonic classical feature though it happens inside matter and not in vacuum.
But in extended objects the independentce is questionablle. The environment consists not of independent point objects.
A. Neumaier said:
The possibility of such a separation assumes that the ''things'' are located at points. But it is precisely this idealization that plays havoc, already in classical relativity. In quantum field theory, it also causes initially problems 9infinite interactions), which are then removed by renrmalization. But renormalization turns point particles into point-like particles, which are (in principle infinitely) extended.
Well, let's look at the specific example I gave, namely the decay of uranium atoms. Alice has a blob of uranium. Bob has a blob of uranium. Yes, this situation has a description in terms of quantum field theory, with lepton and baryon fields. But are you saying that, because there is a description in terms of fields, the Geiger counter clicks at Alice and Bob are correlated in a nonlocal way?
Anyway, if it is true that the approximation that Alice's choice of detector settings and Bob's choice are not really independent, that seems like the superdeterminism loophole of Bell's theorem.
