Compressive strength of aluminum
The discussion revolves around the compressive strength of aluminum, specifically addressing whether aluminum bars or load cells made from the same type of aluminum (such as high purity aluminum or various aluminum alloys) exhibit identical compressive strength or if variations exist. The scope includes theoretical considerations, material properties, and practical implications in manufacturing and calibration.
  • Experimental/applied
  • Some participants propose that variations in compressive strength can occur even among aluminum bars made from the same alloy due to factors like density and imperfections.
  • Others argue that experimental variability exists, influenced by standards that may include performance, compositional, and processing criteria.
  • A participant notes that porosity can also affect compressive strength, regardless of the material being the same.
  • It is suggested that achieving identical compressive strength between two load cells may require fine-tuning during manufacturing and calibration processes.
  • Concerns are raised about the inherent tolerances in load cell sensitivity, modulus of elasticity, and strain gauge measurements, which can lead to discrepancies in performance.
  • Some participants discuss the impact of the manufacturing process (e.g., extrusion, rolling) and heat treatment on the characteristics of aluminum alloys.
Participants generally agree that variations in compressive strength can arise from multiple factors, including manufacturing processes and material imperfections. However, there is no consensus on whether two bars made from the same aluminum alloy can be expected to have identical compressive strength, as opinions vary on the extent of variability.
Limitations include the dependence on specific definitions of "exactly similar" and the variability introduced by manufacturing tolerances and standards. The discussion does not resolve how to achieve identical compressive strength or the implications of accuracy specifications.
This discussion may be of interest to materials scientists, engineers involved in load cell design, and professionals concerned with precision measurements in mechanical applications.
Rev. Cheeseman
TL;DR
Do aluminum bars or anything made from the same type of aluminum have the same exact compressive strength for each of them?
Hello,
Do all of aluminum bars (or load cells) made from the same type of aluminum (i.e high purity aluminum or different types of aluminum alloys) share the same exact compressive strength or are there variations in compressive strength even among the same type of aluminum like high purity aluminum or same type of aluminum alloy?
What would cause the differences? Are you asking about small variations in the stress-strain curve due to small imperfections or slight differences in the alloying process?
https://en.wikipedia.org/wiki/Stress–strain_curve
There will be experimental variability. If you look at the standards, there are generally ranges for various parameters. Some standards are performance standards. Some are compositional standards. Some are processing standards. So the variability can vary by standard.
For example, two bars or load cells are made from the same aluminum alloy but maybe one of them is not as dense as the other thus not as strong in compressive strength due to some imperfections.
Therefore, two bars made from the same aluminum alloy should have the exact same compressive strength then.
No. They will be close.
Is it because there is no such thing as 100% similar or something like that? Therefore, those load cells made from the same aluminum alloy have slightly different compressive strength for each of them?
Yes. The standards allow a range of values.
Porosity will also affect the individual compressive strength too despite made from the same material. Isn't it?
Yes.
Frabjous said:
Yes.
In what way can we achieve to get two aluminum based load cells to have exactly similar compressive strength if possible in order to avoid inaccuracies in force measurements between those two aluminum load cells? Made with the same compositional standards, performance standards and processing standards?
No measurement is exact. You need to specify an accuracy.
Sorry, language barrier. I don't quite understand the specify an accuracy part. How to specify an accuracy especially in the context of getting exactly similar compressive strength between two bars or load cells that are made from the same type of aluminum alloy ?
What does “exactly similar” mean?
If you want 0.01% accuracy at the same temperature, for example, you would probably choose to do fine-tuning in the manufacturing and calibration of those load cells. This type of process is done all the time in high-precision resistor manufacturing, for example. Can you think of what process you might use in manufacturing/calibration for these load cell bars?
Usually, with a quality product, a manufacturer would guarantee a minimum strength value for all bars. So you can expect some bars to be stronger than the minimum value.
The compressive strength of the material in a load cell affects only the maximum load. Load cell sensitivity is directly proportional to the modulus of elasticity, and the cross sectional area. Both of those have tolerances. The load cell signal is the result of a strain measurement, which is made using strain gauges. Good search terms to learn more are modulus elasticity aluminum and strain gauge. Strain gauges also have tolerances for both resistance and gauge factor. And strain gauge signal conditions have their own tolerances.
The sum of all of these tolerances is normally greater than about 10%. That's why all load cells need to be calibrated, and strain gauge signal conditioners have controls for both zero adjust and gain.
The characteristics of metals and alloys may change, depending on how the profile was formed, (extruded, hot or cold rolled), and how the crystal structure or phase changes over time.
Most metals can, if needed, be brought to a stable structure by careful heat treatment, chilling, or by simply waiting for a day, a week, or leaving it outside in the weather for a year.
Lets say, two bars made from the same aluminum alloy has 100% same compressive strength at 600 mpa.
Doing drop tests like dropping a 10 kg object on it?
So, with two bars that are made with the same aluminum alloy, we can't expect the other aluminum bar to have compressive strength with the other one. This makes someone for example me hesitate to buy just one aluminum bar but instead I have to get multiple aluminum bars despite all of these aluminum bars are made from the same aluminum alloy.
Is calibration the same as when we try to drop things on load cell?
In order to get aluminum bars that share the same compressive strength, we need to made them from the same aluminum alloy that had been brought to a stable structure by careful heat treatment, chilling and leaving it outside in the weather for some time?
That will depend on you knowing what heat treatment is available, and how the alloy behaves over time.
No two samples of a material are ever 100% identical.
Two samples, that are each within ±1% of the specification, may differ by 2%.
Are you saying that your application will fail if one bar has a yield strength of Y and the other bar has a yield strength of 1.01 Y?
As a side note, for most applications, one does not want to get anywhere near the yield strength.
If your design requires a compressive strength of 600 MPa for example, and a manufacturer guarantees its product has a minimum compressive strength of, say, 640 MPa, why does it matter to you that the two different samples have, for example, 645 MPa and 657 MPa? They're both the same price and they are also both greater than 600 MPa, thus qualifying for your design.
Maybe you should describe your application. I find it difficult to envision a requirement that two bars yield at the exact same value, but that they application does not require them to yield.
Buy one bar, then cut two from it.
Notice that the -T6 tells you that it has been treated to make it hard and dimensionally stable. Avoid overheating it during cutting or machining.
"T6 temper 6061 has been treated to provide the maximum precipitation hardening (and therefore maximum yield strength) for a 6061 aluminium alloy."
https://en.wikipedia.org/wiki/6061_aluminium_alloy#6061-T6
  • · Replies 37 ·
14K
  • · Replies 19 ·
