Static Mechanics: Aircraft Nosewheel Linkage Torque
  • Thread starter Thread starter jojosg
The discussion centers on analyzing the torque in the aircraft nosewheel linkage system using free body diagrams (FBDs). Participants emphasize the necessity of creating separate FBDs for each moving part, particularly focusing on the forces and torques acting on the linkage. It is established that links BC and CD can be considered massless for simplification, and the torque at point M is crucial for maintaining equilibrium in the assembly. The vertical force at point G, representing a combined mass of 50 kg, remains constant while the moment M varies during the wheel's elevation.
  • Understanding of free body diagrams (FBDs)
  • Knowledge of static mechanics principles
  • Familiarity with torque and force analysis
  • Basic concepts of rigid body dynamics
  • Study the principles of static equilibrium in mechanical systems
  • Learn how to construct free body diagrams for complex linkages
  • Explore torque calculations in multi-body systems
  • Review case studies on static force analysis in mechanisms
Mechanical engineers, students in engineering mechanics, and professionals involved in aircraft design and analysis will benefit from this discussion.
jojosg
Hi I'm stuck at how to draw the free body diagram for thise nose wheel question
Moment equal 0
see attached
A free body diagram shows the forces on a single rigid body. Here you have a linkage, so you need an FBD for each moving part. This will involve defining unknowns for forces and torques between connected bodies, each such force being represented in the FBDs for both bodies.
What are the moving rigid bodies in this problem? Pick one and list the forces on it. Then post your attempt at its FBD.
I think it is safe to assume that links BC and CD are massless because no masses are given for them. Assume that the torque at M gives rise to a force ##F_D## at D that is just right to prevent the combined (arm + wheel) assembly AO from rotating either clockwise or counterclockwise.
Consider the external force and moment acting on the whole mechanism first.
One is the represented M, which is necessary to raise the combined mass of 50 kg, which can be represented as a vertical force applied at point G.
Note that the value of that vertical force will be constant, while the value of the necessary moment M will change as the wheel is being raised, reason for which the problem asks for the value of moment M at that specific position of the mechanism's stroke.
Please, see this example:
https://www.school-mechademic.com/blog/static-force-analysis-on-a-4-bar-link-mechanism
:cool:
ok I think I got it thanks everyone
