I can no longer render LaTeX
  • Thread starter Thread starter renormalize
    Latex
  • #61
Greg Bernhardt said:
latex should be fixed in message fields aka in homework help, and in quote blocks now
I'm having a somewhat different problem: whatever is going on in the editor changes my LaTeX to symbols like those from the "insert symbol" dropdown, but only after I hit "Post". It previews as LaTeX but posts as symbols. That is most emphatically not the behavior I want or expect. For one thing, LaTeX is more readable than those symbols.
I agree with @fresh_42 that whatever change happened to the editor is causing more problems than it solves.
  • #62
hmm yeah latex appears to be rendering in the editor outside of preview now. fix one thing, break another...
I agree, but it was part of a core software update. Not my decision. The sync between mathjax, the editor, preview and when and when not to render is a bit of a jungle gym.
  • #63
ok this should be fixed now
  • #64
Let's see.$$F=\frac{GMm}{r^2}$$##p=\rho gd##
Renders ok in preview.
Edit: seems ok in the post and now when editing the post too.
  • #65
Testing: ##p = w \rho##.
  • #67
Test with quoted text.
\begin{align*}
F&\sim\ddot x
\end{align*}
Inline a) ##\mathbb{R}##, b) \mathbb{C}, and single lined c) $$\mathbb{C}$$, \mathbb{C}.
Preview: check
Post: we'll see in a second
Edit mode: check
Preview in edit mode: check
$$\checkmark$$
Edited post: we'll see in a second
Edit: Well done and congratulations @Greg Bernhardt. I couldn't find a flaw, and I have really tried!
  • Haha
  • #68
Addendum: Although the tags [iTex] and [Tex] worked while I had tested the above functionality, they do not work now anymore that I have revisited the page, including the preview:
  • #69
hmmm not sure I understand. How can I reproduce?
  • #70
This is what I see:
If you edit my post (#67) then you see the correct code, and it also renders correctly in preview. Just not after posting it (anymore).
This is no problem for me, since I do not really use the Tex and iTex tags, only the abbreviations with hashtag and dollars. But it should be known.
  • #71
Although LaTeX is still working fine for thread posting, for me it's broken again in a direct message. Inserting LaTeX code into a DM works OK for the first preview but editing and previewing again gives a broken equation that can't be further edited and is even hard to delete. And if I generate a DM with LaTeX offline and copy it into the DM edit window, it looks OK before posting but it's broken when it appears in the string of DMs. :frown:
  • · Replies 16 ·
10K
  • · Replies 32 ·
  • · Replies 147 ·
19K
