DaveC426913
2025 Award
- 24,354
- 8,566
- TL;DR
- Trying to figure out something - anything - about this annooying noise from my humidifier
Brought out a small humidifier much like this Homedics Ultrasomic Humidifier:
to humidify my bedroom.
It makes a whine that is piercing when the room is very, very quiet, like when you're trying to fall asleep. The whine has number of harmonics, the lower ones simply buzz, which is perfectly fine, like white noise, but the high pitched note is a pure, perfect sine wave - you know, like a synthesizer on default settings.
The lower ones are pretty immune to self-interference, but the purity of the highest note makes it very susceptible to self-interference.
I manage to lie with my right ear in the spot where the frequency is loudest. I assume constructive interference requires either two identical sources or a good reflecting surface somewhere. I don't know why a humidifier would have two sources, and this device does seem to make the make the same noise whether on the floor, on the dresser, or at either end of the room, so I'm not sure it's a reflection. I've movrd it aorund a litte, pointing it this way and that, to see if it alters the location of the nodes, but not much luck so far.
Where do you suppose I'm getting self-interference from?
Anyway, I found a second spot with maximum constructive interference about a foot away from the first (alas, it puts my head almost off the edge of the mattress, so untenable).
I tried to use a(n online) frequency analyzer, but it's too faint to register.
I also tried to match it to a played tone, but its very hard to do. It's somewhere in the ballpark of 2.5-5 kHz.
Two aspects: one scientific, one practical.
Can I deduce its freq from the node distance? Also,can I baffle it somehow?
