Control type problem from mechanics
  • Thread starter Thread starter wrobel
The discussion centers on a mechanics problem involving a rod (AB) of mass M and length ℓ that can slide along axes OX and OY, with a bug (C) of mass m running down the rod. The problem explores whether the bug's movement can keep the rod stationary. It concludes that while the rod can remain in equilibrium for a finite time as long as the gravitational force on the rod equals the force exerted by the bug, the rod will eventually slide once the bug reaches point B on the x-axis. The analysis employs Lagrangian mechanics, specifically using the generalized coordinate of the angle φ = OAB.
  • Lagrangian mechanics
  • Understanding of equilibrium in mechanics
  • Knowledge of forces and motion in two dimensions
  • Basic calculus for analyzing functions over time
  • Study Lagrangian mechanics in detail, focusing on systems with constraints
  • Explore equilibrium conditions in dynamic systems
  • Investigate the effects of gravitational forces on moving bodies
  • Learn about the dynamics of systems with variable mass
This discussion is beneficial for physics students, mechanics enthusiasts, and researchers interested in dynamic systems and equilibrium analysis in mechanics.
wrobel
Insights Author
I saw this problem several years ago in a Russian journal devoted to physics olympiads. This problem was discussed there under some certain simplifying assumptions which I do not remember. I tried to solve it without simplifications but laziness and large formulas stopped me. Nevertheless, I find this problem interesting and solvable and perhaps some of PF participants will be interested in it.
A rod ##AB## of mass ##M## and length ##\ell## can slide without friction along the axes ##OX## and ##OY## by its hinges ##B## and ##A## respectively. A bug ##C## of mass ##m## runs downwards along the rod. Can the bug's run be such that the rod does not move?
My suggestion is as follows.
Let us regard the function ##u(t)=|AC|## as a given function. Then we have a Lagrangian system with one degree of freedom. For a generalized coordinate take an angle ##\varphi=OAB##.
Then write down the Lagrange equation and substitute there ##\varphi=\mathrm{const}##. We will have an equation for the function ##u(t)##.
wrobel said:
A bug C of mass m runs downwards along the rod.
"Downwards" suggests that the rod is being accelerated down the y-axis and along the x-axis by gravity.
Yes, but only for a finite time.
While the force along the rod, due to gravity, is equal to the force applied by the running bug, the rod will remain in equilibrium. The bug will accelerate down the stationary rod, until it reaches B, on the x-axis, then shortly after, it may be crushed by the rod after the rod begins to slide.
The question becomes, can the rod ever catch up with the accelerated bug?
By accelerating its small mass (m) along the bar, the muscular force of the bug will need to induce a vertical component equal to (M+m)g.
That would be easier achieved at positions of the bar closer to vertical.
  • · Replies 17 ·
  • · Replies 78 ·
  • · Replies 62 ·
10K
  • · Replies 19 ·
  • · Replies 16 ·
