Achievable accuracy of thermostatic radiator valves
  • Thread starter Thread starter sophiecentaur
sophiecentaur
Homework Helper
TL;DR
How do TRVs manage to measure room temperature in the proximity of a hot central heating radiator.
I have recently acquired some remotely controlled radiator valves in an attempt to control our domestic heating better. The water enters at the bottom of the radiator and the valve opens proportionally to let just enough hot water through to bring the local room temperature to your chosen setting.
I have had some real struggles with the Zigbee wireless network - which is another problem - but now I mostly have some sort of command of all five valves and also the boiler thermostat. I am impressed how the temperature of the room seems to measure within a fraction of a degree (C) after settling down. How do they do it?
I have read that there are three sensors in each valve body so they have clearly gone to some trouble to achieve the performance. The valves are about £50 each so I don't intend to poke inside one. Have any PF members been here and found out any of the trade secrets - or even some basics of temperature control that doesn't use remote sensing?
Whilst I am at it, most of the network elements are battery operated (2XAA) so they will use minimal power. So my system is very sensitive to placement of units (rads are fixed, of course). The manufacturers clearly have 'issues' with weak signals and local WiFi interference but their recommendations are deliberately vague and there's little solid guidance. If there were an affordable scanner to look at the Zigbee environment, that could help but that sort of test gear would be expensive.
For contrast, in the simplest kind of room thermometer:
There is a small resistor in the thermostat that mimics the heating of the room. So, as the room changes temperature, so does the bimetalic strip in the thermostat. Without this resistor, the thermostat would bring the room to its proper temperature, but wouldn't stop heating until the room warmed up the thermostat. By that time, the room would be too hot. Similarly, the heat would not turn back on until the cold room cooled the thermostat. The end result would be a room that goes through repeated hot/cold cycles. That resistor can be adjusted so that it matches the way the room heats up.
For an electronic thermostat, there is the "PID" loop. This is more sophisticated. It can work operate that variable flow control (not just on/off) and can be controlled by a microprocessor that will "learn" the room and tune the PID parameters accordingly. PID stand for proportional, integral, and derivative - the three factors that control the PID output (and thus the valve position). Each factor has a tuning parameter associated with it.
The "Proportional" factor is the difference between the set point (say 20C) and the actual measured temperature (say 20.1C). In this example, the difference would be -0.1C indicating that the room needs to cool down, so the valve position might be too open. The "P" value in this case would be a positive number - say 0.2. So 0.2*(-0.1) = -0.2 would be the "P" contribution to the valve position.
The "Integral" factor keeps score of how well the temperature has been tracking recently. In our example, the current error is -0.1C. If it the recent average has been -0.5C, then the "P" value is correcting so we may be okay. On the other hand, if the recent average has been +0.5C, the we have over corrected and we need to use "I" to close the valve even more.
The "Derivative" factor keeps track of how the temperature is changing and can be used to dampen the rate of temperature change.
Interesting and informative reply - thanks.
I seem to remember it was called an 'accelerating resistor'. The thermostat used to operate at higher frequency and gave a more steady temperature.
I can well appreciate that 'better' feedback will give a steadier temperature / heading / position etc. Many systems use a normal feedback loop which, with the right feedback parameter, will give a critically damped response. The more complicated feedback (PID) can improve things and produce a faster response and steadier output. That, I can understand and have managed to make a voltage regulator and a phase lock loop work.
However , those systems involve measurement of an 'output signal' and comparison with a standard. The Smart TRV can't see the room temperature because it's right next to the radiator's dominant effect.
The TRV doesn't have access to the actual room temperature (the value of y(t) in the Wiki block diagram) so it has a harder job. I suspect that the mean 'measured' temperature in the TRV (near the bottom of the rad) would be the same as in the room when the water flow is just right. It won't be a simple as that because the water temperature will have to be 'warm'. People on the Facebook group say they work on a different aiming point for a wanted room temperature.
It impresses me that my posh little datalogging room temperature / humidity sensor seems to agree, after a short delay, with the 'actual' temperature on the TRV. They say there are three sensors in the TRV so it could know the local air temperature and the water temperature. Not trivial. They say you need good air circulation.
You may be able to help me to relate what Wiki says with my added problem.
I've followed this thread a tiny bit thinking this is impossible. But it occurred to me that one of the sensors could be an infrared sensor similar to the little hand held jobs that shoot a laser spot at whatever it is that you want to know the temperature of? This way the sensor knows the water temp, the air temp at the radiator and the temp of the opposite wall/furniture/whatever. After a little learning it should be able to set the temperature accurately and repeatably.
@Averagesupernova good idea but the TRV rotates to point at anything and there’s no sign of any external sensor.
It’s not a surprise that Wanted and Actual do reach equality eventually but, as you imply, it’s magic that they seem to agree with a good room thermometer too. It must be to do with the fabled ‘three’ internal sensors. If they use information about the minimum temperature ( with no hot water at night) and rate of heating as new hot water flows then comparison between heating and cooling rates might give the brain some clues. But heat capacity and rad output are unknown.
We’ll have to wait for input from a Hive person.
Since I sorted the Router channel things have got even better. A really smart system could hop to the cleanest channel in your home.
sophiecentaur said:
...but the TRV rotates to point at anything and there’s no sign of any external sensor.
I think the fact that it rotates makes it more likely that it could be IR. Otherwise a window or external wall would throw a false low temperature. But rotating would average things. It would even know when it's pointing at the radiator. By this it may be able to form an 'image' of the room. However, this is somewhat speculative until we know if there is an IR sensor.
It's rotatable to see the display window. in the wanted position. There's a cap / shroud with no holes but for the screen. Have a look at the website. The cap / shroud covers all the workings.
There are a few possibilities to explain things. If the water flow were reduced so that the flow water cooled to a steady temperature, then that would be room temperature (as long as the lowest layers in the rad were also cool) but the rad is never less than 'tepid'. The TRV knows little about the water valve characteristic (it fits many different TRV bases.) - just the physical stops at each end.
To be fair, it's quite smart so it could remember the temperature range of the water and @.Scott 's post #2 points out how smart a basic thermostat system can be (and the room temperatures do stay pretty steady so that will explain the demanded and actual values match to well within a degree. There is another factor in that two rooms are set to Low during the day but people forget to close the doors (tut tut) and Actual is sometimes high. Interestingly, the system sometimes tell me 'there could be a problem' with that TRV 'is it turning off correctly?'
One more thing ..... the orientation of the valve (vertical or horizontal) needs to be set.
Clearly the thermal performance is pretty smart but the RF performance of the data network leaves a lot to be desired. (And the technical 'help' too)
  • · Replies 28 ·
