Why an Extra Coin Gives Bob a 50% Chance?
  • Context: Engineering
  • Thread starter Thread starter Kakashi
The discussion revolves around a probability problem involving two players, Bob and Alice, who each toss a certain number of coins. The central question is about the impact of giving Bob an extra coin on his chances of winning against Alice based on the number of heads obtained.
  • Participants explore the relationship between the number of heads each player obtains and the probabilities associated with winning. Some discuss the implications of pairing sequences of heads and the overall counting of outcomes. Others question the validity of certain assumptions regarding the probabilities involved.
Several participants have offered insights and hints regarding the probabilities, with some suggesting that Bob's extra coin gives him an even chance in specific scenarios. There is acknowledgment of previous posts that provided similar guidance, indicating a collaborative exploration of the problem.
Participants note that the problem's assumptions, such as the fairness of the coin and the initial conditions of the tosses, are crucial to the discussion. There is also mention of varying interpretations of the probabilities involved, particularly when considering different probabilities of heads.
Kakashi
Alice and Bob have 2n+1 coins, eahc coin with probability of heads equal to 1/2.Bob tosses n+1 coins, while Alice tosses the remaining n coins. Assuming independent coin tosses, show that the probability after all coins have been tosses, Bob will have gotten more heads than Alice is 1/2.
N/A
Whether Bob has more heads depends on both Bob and Alice outcomes. For Bob to win Alice must get fewer heads. If bob gets x heads then Alice must get 0,1,2,..,x-1 heads. The number of sequences with k heads is $$ {n} \choose {k} $$. So for a fixed x the number of Alice sequences with less than x heads is $$ \sum_{k=0}^{x-1} {{n} \choose {k}} $$. The number of bob sequences with exactly x heads is $$ {n+1} \choose {x} $$.
I'm not sure whether you've posted an attempt or just some initial calculations.
You need to be clever. Here's a big hint. If they toss ##n## coins each, then there is a probability ##p## that Alice has more Heads; the same probability ##p## that Bob has more Heads; and, a probability ##q## that they have an equal number of Heads.
Take it from there.
Wow I dont know why I was overcomplicating things.
The probability that Bob wins= p+q*1/2=p+(1-2p)*1/2=1/2
My counting attempt was that every sequence with x heads for Bob can be paired with every Alice sequence having fewer than x heads. So the total number of pairs for this fixed x is $$ {{n+1} \choose {x}} \sum_{k=0}^{x-1} {{n} \choose {k}} $$
Summing over all x
$$ \sum_{x=1}^{n+1} {{n+1} \choose {x}}*\sum_{k=0}^{x-1} {{n} \choose {k}} $$
Then $$ P(\text{Bob wins})=\frac{\sum_{x=1}^{n+1} {{n+1} \choose {x}}*\sum_{k=0}^{x-1} {{n} \choose {k}}}{2^{2n+1}} $$. Since there are 2^{n+1} Bob sequences and 2^{n} Alice sequences.
Suppose we look at the situation after both have tossed n coins and say that they have equal probabilities for every number of heads. Then, give Bob one more coin to toss and calculate his probability of getting more heads as 1/2.
NOTE: I missed that post #2 already gave this advice.
Yes, very neat, but might not be clear to all. A bit of elaboration might help…
After n tosses each,
- A has more heads than B with probability p
- B has more heads than A with probability p
- equal counts with probability 1-2p
A's extra toss doesn’t change the outcome in the first two cases but gives A an evens chance of winning in the third.
Very good! I didn't clarify it because I couldn't see a clear proof. You did it. Thanks!
This solution was already posted in posts #2 and #3.
Look at posts #2 and #3.
If this argument were valid, then it would work for any probability of Heads. But, it only works in the special case of 1/2. For the general case, where the probability of Heads is ##r## we get:
$$P(Bob) = p + r(1-2p) = r + (1-2r)p$$This only equals ##r## if ##r = 1/2## or ##p =0##.
Ouch! Sorry, I missed that. Maybe my posts and other's responses should be deleted.
  • · Replies 37 ·
  • · Replies 35 ·
  • · Replies 45 ·
  • · Replies 41 ·
  • · Replies 29 ·
  • · Replies 35 ·
