Another nice problem from Savchenko
  • Thread starter Thread starter wrobel
wrobel
Insights Author
A slab rests on two massless rollers of different radii such that the angle of the slab's inclination is ##\alpha##. There is no slipping between the slab and the rollers, nor between the rollers and the ground. Prove that the slab moves with purely translational motion and find its acceleration.
(the value of the acceleration is ##g\sin(\alpha/2)##)
The standard obstacle here is finding the reactions of the rollers, but the use of the energy integral allows one to avoid this difficulty. Accurate proof that the motion is translational also requires some kinematic techniques.
It is also interesting to note that the hypothesis of ideal constraints here does not imply that the reactions of the rollers are perpendicular to the slab. This is not the case, even though the rollers are massless. It is because the net reaction is perpendicular to the virtual displacement, as it must be
I would try some math.
1. I observe that angle ##\alpha## does not change during the motion but the slab moves with NOT purely (horizontal, I would add. See my post #6. ) translational motion. Displacement d of the slab, which has horizontal and perpendicular components, is
$$d=r\theta\sqrt{(1+\cos\alpha)^2+\sin^2\alpha}=2 r\theta\cos\frac{\alpha}{2}$$
where r, ##\theta## are radius and rotation angle of either one of the rollers. Thus
$$\vec{d}=d(\cos\frac{\alpha}{2},-\sin\frac{\alpha}{2})$$
and
$$\vec{g} \cdot \frac{\vec{d}}{d} = g \sin\frac{\alpha}{2}$$
Therefore
$$d = \frac{1}{2}g \sin\frac{\alpha}{2} \ t^2+\dot{d}_0t+d_0$$
2. Lagrangian for massless rollers case is
$$L=m[\frac{1}{2} (2 r\dot{\theta}\cos\frac{\alpha}{2})^2 + g r\theta \sin\alpha)]=4mr^2\cos^2\frac{\alpha}{2}(\ \frac{1}{2}\dot\theta^2+\frac{g}{2r}\tan\frac{\alpha}{2}\ \theta\ )$$
where m is mass of the slab. By solving the Lagrange equation
$$ \ddot{\theta}=\frac{g}{2r}\tan\frac{\alpha}{2}$$
Thus
$$\ddot{d}=g \sin\frac{\alpha}{2}$$
My version is
$$L=mr^2\dot\theta^2(1+\cos\alpha)+mgr\theta\sin\alpha$$
hopefully that is the same:)
anuttarasammyak said:
angle α does not change during the motion but the slab moves with NOT purely translational motion
By definition, purely translational motion is when all the points of a rigid body move with the same velocity
The drop of the slab releases potential energy which enhances kinetic energy. The perpendicular component of the slab displacement should be considered as well as the horizontal component.
My bad. I confused translational with horizontal translational.
I fed my English translation of this problem (from the initial post) to an AI. It correctly recognized it as problem number 2.1.51 from Savchenko, but then provided an incorrect solution and the wrong answer.
Some people, to put it mildly, somewhat overestimate the omnipotence of this thing I guess.
Re:#2
2.1 When the rolls heve mass and inertia of rotation
$$r_1=r, M_1, I_1$$
$$r_2,M_2, I_2$$
The additional term to Lagrangian is
$$[(M_1+M_2)r^2+I_1+\frac{r^2}{r_2^2}I_2]\ \frac{\dot{\theta}^2}{2}$$
which reduces ##\ddot{d}##.
From this result I think of amending 1 for rolls with mass and inertia. Direction of displacement is common. New forces from the rolls to slab via contact points in this direction should be considered. That seems rather laborious than Lagrangian method.
  • · Replies 55 ·
10K
