Vincf
- 25
- 2
- TL;DR
- Convergence problems for integrals giving the horizontal component of the field of an infinite plane
Hello,
I would like to discuss a mathematical point concerning the electric field of an infinite uniformly charged plane.
This question arose while I was discussing an electrostatics exercise with a student. I wrote an article about this (in 2023) in a French journal for french physics professors. I made it available online as a postprint at this link: https://zenodo.org/records/18431824
(But I continued to teach the usual result since it was in the official curriculum for my students !)
The usual result is that the field is strictly perpendicular to the plane and has magnitude ##E = \frac{\sigma}{2\varepsilon_0}##
Below, I reproduce what is a classic electrostatics exercise, which presents the problem quite clearly.
I compute the electric field of an infinite uniformly charged plane by decomposing it into infinite parallel wires.
I redrew a figure to make it easier to read :
Each wire, parallel to the x-axis, has linear charge density : ##d\lambda = \sigma \, dy_P## and produces the field :
d\vec{E} =
\frac{d\lambda}{2\pi\varepsilon_0}
\frac{1}{PM}
\, \vec{PM}
where ##r=PM## is the distance from the wire to the observation point ##M##.
Projecting onto the coordinate axes gives : (The notations are on the diagram.)
dE_y =
\frac{\sigma \, dy_P}{2\pi\varepsilon_0}
\frac{1}{PM}
\cos(\alpha)
$$dE_z =\frac{\sigma \, dy_P}{2\pi\varepsilon_0}\frac{1}{PM}\sin(\alpha)$$
From geometry, ##PM^2=r^2 = (y_M - y_P)^2 + z_M^2## and ##(y_M - y_P) dy_P = -r \, dr## so ##
\frac{dy_P \cos(\alpha)}{r}=-\frac{dr}{r}##
Also,
##\tan(\alpha) =\frac{z_M}{y_M - y_P}## or ##-dy_P =z_M \, d\left(\frac{1}{\tan(\alpha)}\right)## so ##
dy_P =
\frac{z_M}{\sin^2\alpha} \, d\alpha## and ##
\frac{dy_P \sin(\alpha)}{r}
=d\alpha##
Thus,
dE_y =- \frac{\sigma}{2\pi\varepsilon_0}\frac{dr}{r}
dE_z =\frac{\sigma}{2\pi\varepsilon_0}\, d\alpha$$
Integrating :
$$E_y =- \frac{\sigma}{2\pi\varepsilon_0}\ln\left(\frac{r_2}{r_1}\right)$$
E_z =
(\alpha_{\max} - \alpha_{\min})
It remains to pass to the limit of the infinite plane. ##
D_{\max} \to \infty,
\quad
D_{\min} \to \infty
For the vertical component, ##
\alpha_{\max} \to \pi,
\quad
\alpha_{\min} \to 0
## gives ##
E_z =
## as expected.
However, for the horizontal component,
\lim_{D_{\max}\to\infty \atop D_{\min}\to\infty}
E_y
\ln
\left(
\frac{
\sqrt{(D_{\max} - y_M)^2 + z_M^2}
\sqrt{(D_{\min} + y_M)^2 + z_M^2}
\right)
The result appears to depend on how the limit is taken.
If ## D_{\max} = D_{\min} ## then :
\lim_{D\to\infty \atop D_{\max}=D_{\min}=D}
E_y = 0
But if ##D_{\max} = K D_{\min}## (With ##K## a positive constante):
\lim_{D_{\min}\to\infty \atop D_{\max}=KD_{\min}}
E_y =
- \frac{\sigma}{2\pi\varepsilon_0}\ln(K)
This shows that the horizontal component obtained from direct integration depends on the procedure used to take the infinite limit.
My question is the following:
When computing the field of an infinite uniformly charged plane using this decomposition into parallel infinite wires, what is the mathematically rigorous procedure for taking the infinite limit?
In particular, why is it justified to interpret the integral as a principal value, corresponding to a symmetric extension of the plane around the observation point M?
d\vec{E} =
\frac{1}{PM}
\, \vec{PM}
dE_y =
\frac{1}{PM}
\cos(\alpha)
Also,
dy_P =
=d\alpha##
Thus,
Integrating :
E_z =
\quad
D_{\min} \to \infty
\quad
\alpha_{\min} \to 0
## gives ##
E_z =
## as expected.
E_y
\ln
\left(
\frac{
\right)
E_y = 0
E_y =
