DaveC426913
2025 Award
- 24,488
- 8,770
- TL;DR
- Under what conditions (diameter, rotational speed) would it be safe/unsafe to have human-powered flight inside a hollow spinning stucture - specifically worst-case impact speed?
Say we have a hollow asteroid colony, spun up to provide gravity. The residents would be unable to resist making wings and flapping about in the zero-g near the axis. What is the worst possible case in terms of impact with the ground?
I'm actually working at it backwards: what radius and rotational rate would be the maximum, above which free flying without nets would have to be prohibited? (So, if I wanted them to be able to fly without zone restrictions or safety nets, how big could my colony be?)
I'll start with some arbitrary numbers and go from there.
Say it has a maximum radius of 2.5km.
Say it contains one atmosphere of air.
Say they decide they like a comfy .333g. at the maximum radius.
(There's all sorts of complicating factors here if the interior space is not a cylinder. A more realistic sphere or football shape will have varying distances to fall, shorter - and therefore less danger - near the poles).
SpinCalc tells me that a hollow structure 2.5km in radius at its widest point (normal to axial spin), producing .33g will require a spin rate of ~1/3rpm, and a tangential velocity of ~90m/s.
(I thought the simplest scenario would be to ignore the accerelating influence of the air. So a flyer near the axis, whose wings break, will fall and hit the outer shell with a velocity of ... not applicable.
Without air, the flyer will not fall at all. They'll just float around with their initial velocity until they drift near the wall, which will be moving by at a rate of 90m/s.)
OK, so that's a bust. Guess we need the air. So now the falling ex-flyer gets spun up to rotational speed via drag.
John Varley's Titan series taught me that falling in a spinning space station diverts your motion tangentially, so that you will hit the ground at a very low angle.
I have no idea how to calculate or even estimate what speed that impact might be.
Alas, my gut is telling me that there is no safe speed to fall out of the sky. I will need to invoke
- designated areas where flying is allowed (perhaps near the poles, where fall potential is limited)
- parachutes
- safety nets.
Or, worse, flying might be limited to near the axis but in a cage.
(Context: No futuristic safety technology (think: steampunk). Also, set in a time when technology was idealistic and the world was not so litigious about a citizen spraining their ankle.)
Followup question: would the air pressure differential between axis and ground be substantial? Would simple breathing be noticeably impaired?
- parachutes
- safety nets.
