- 13,763
- 16,529
- TL;DR
- Off the back of yesterday's thread about relativistic discs I tried to work out the KE of a rotating disc and got an odd result.
Consider a disc of radius ##R## with a uniform mass distribution and total mass ##M## rotating in its own plane. In its COM's inertial rest frame it has angular velocity ##\omega## about its center. In the obvious polar coordinates in that frame the kinetic energy of a small part of the disc at radius ##r## is $$dK=\frac{M}{\pi R^2}\left(\frac 1{\sqrt{1-\omega^2r^2}}-1\right)r\,dr\,d\phi$$in units where ##c=1##. I just integrate to get the total KE of the disc. The ##\phi## integral is trivial and the ##r## one is not much harder:$$\begin{eqnarray*}K&=&\frac{2M}{R^2}\int_0^R\left(\frac 1{\sqrt{1-\omega^2r^2}}-1\right)r\,dr\\
&=&\frac{2M}{\omega^2R^2}\left(1-\sqrt{1-\omega^2R^2}-\frac 12\omega^2R^2\right)
\end{eqnarray*}$$This formula has the correct limit for ##|\omega R|\ll 1## - plugging in the Taylor expansion ##\sqrt{1-x^2}\approx 1-\frac 12x^2-\frac 18x^4## gives ##K\approx\frac 14MR^2\omega^2=\frac 12I\omega^2##, as expected. But it is finite in the ultra-relativistic limit where ##\omega R\rightarrow 1## - in fact it tends to the absurdly low ##M##. Clearly this is wrong, since you can chip off a flake of matter near the rim and it can have arbitrarily high kinetic energy.
What's going on? The integrand looks sensible and diverges at ##|\omega r|=1##, but the integral behaves in an unexpected manner. Have I overlooked something? Just screwed up the maths? Can I not study a massive rotating disc in SR at these speeds because spacetime will be significantly curved by the energy?
I had a look for the result online. I found a lot of discussion of Ehrenfest and a lot of derivations of the KE of a spinning disc in Newtonian physics, but I couldn't find the result for the total kinetic energy in the relativistic case.
