Paradox in Induced Dipole Forces: Does it violate Newton's Third Law?
  • Thread starter Thread starter EM-learner
EM-learner
Consider a molecule B with a permanent dipole moment $\vec{p}_B = p_B \hat{z}$ and a polarizable molecule A with atomic polarizability $\alpha$. Molecule A is located on the $z$-axis at a distance $z$ from B.
B creates an electric field that induces a dipole moment $\vec{p}_A$ in A.
Calculate the force $\vec{F}_A$ exerted on the induced dipole A.
Calculate the force $\vec{F}_B$ exerted on the permanent dipole B by the field of A.
Compare $\vec{F}_A$ and $\vec{F}_B$. My current derivation shows $\vec{F}_B = 2\vec{F}_A$, which seems to violate Newton's Third Law.
Dipole electric field (on-axis): $\vec{E} = \frac{p}{2\pi\epsilon_0 z^3} \hat{z}$
nduced dipole: $\vec{p}_A = \alpha \vec{E}_B$
Force on a dipole in a non-uniform field: $\vec{F} = (\vec{p} \cdot \nabla) \vec{E}$
First, I calculated the field produced by B at the position of A:
In Physics Forums you should use ## to wrap in-line LaTeX equations and $$ to wrap display equations. I've reformatted your post below:
EM-earner said:
Homework Statement: Consider a molecule B with a permanent dipole moment ##\vec{p}_B = p_B \hat{z}## and a polarizable molecule A with atomic polarizability ##\alpha##. Molecule A is located on the ##z##-axis at a distance ##z## from B.
B creates an electric field that induces a dipole moment ##\vec{p}_A## in A.
Calculate the force ##\vec{F}_A## exerted on the induced dipole A.
Calculate the force ##\vec{F}_B## exerted on the permanent dipole B by the field of A.
Compare ##\vec{F}_A## and ##\vec{F}_B##. My current derivation shows ##\vec{F}_B = 2\vec{F}_A##, which seems to violate Newton's Third Law.
Relevant Equations: Dipole electric field (on-axis): ##\vec{E} = \frac{p}{2\pi\epsilon_0 z^3} \hat{z}##
Induced dipole: ##\vec{p}_A = \alpha \vec{E}_B##
Force on a dipole in a non-uniform field: ##\vec{F} = (\vec{p} \cdot \nabla) \vec{E}##
And to make our lives easier, please try using LaTeX to post your solution attempt here, rather than making us all open your PDF attachment.
Your mistake comes from differentiating the dipole moment as well, whereas it must be kept constant during the differentiation. To clearly expose the issue, I will redo the calculation in the simplest possible case: a field directed only along the x-axis (which actually corresponds to your situation).
Consider a dipole formed by a charge ##q## at position ##x+a## and a charge ##-q## at position ##x##. The force acting on the dipole is:
F = q\,E(x+a) - q\,E(x)
Using a first-order expansion, this gives:
F = q\,a\,\frac{dE}{dx} = p\,\frac{dE}{dx}
This result remains valid even if ##a## is a function of ##x##. Physically, this means that the dipole, in its instantaneous configuration, responds to the spatial variation of the field.
In your case, ##a## is a function of ##x##, and you write:
q\,\frac{d(aE)}{dx}
which is incorrect.
Thanks a lot !!
  • · Replies 25 ·
  • · Replies 25 ·
