Non-Linear Infinite Resistor Ladder
  • Level: Undergrad
  • Thread starter Thread starter bob012345
  • Featured
54 replies · 7K views
bob012345
TL;DR
An infinite resistor ladder is given in one of Paul Nahin’s books* and he asks the reader to find the exact solution. I believe there is no closed form exact solution as a single rational number.
The circuit looks like this;
I used LTSpice simulations, hand calculations and other tools to compute the equivalent resistance of this ladder and to see it converge toward a solution but found no exact closed form solution. I believe the exact solution is an irrational number but I can’t prove it. Note that if one only computes to a few decimal places one might think it’s a repeating number as professor Nahin suggested in his book in which he freely admits he did not know the answer but instead challenged the readers to find one. Of course this is to be taken not as a practical exercise but more a math exercise.
* Mrs. Perkins’s Electric Quilt (challenge problem 3.4)
I get ##R_∞ =1.900991080179287315…##
Your spoiler is numerically correct.
For each stage, you add conductivity in parallel, then resistance in series.
Note that conductivity g, is the reciprocal of resistance r, so; g = r-1.
Thanks but do you agree it’s converging to an irrational number?
Simply fixed value ladders always do converge to a recurring continued fraction, and since an RCF can be evaluated with a quadratic equation, they will contain the square root of a non-square number, which is irrational.
In this case the ladder is exponentially converging, and so I expect it cannot be written as an RCF, but will almost certainly evaluate to an irrational number.
This code evaluates from right to left. A solution accurate to n digits requires n terms.
Code:
Dim As Integer i, n = 20
Dim As Double term, r = 10^(n+1)
For i = n To 0 Step -1
    term = 10^(-i)      ' this term
    r = term + 1 / r    ' add the term as conductance in parallel
    r = term + 1 / r    ' add the term as resistance in series
Next i
Thanks. In looking at the exact solutions for the first few terms it seems the fractions quickly get gigantic.
These seem also to have no common factors so each fraction cannot be reduced. I suspect this pattern continues as ##n→∞## we get an infinitely large fraction which cannot be reduced.
Also, I believe not all infinite ladders have to have irrational equivalent resistances. If in the ladder above, the horizontal resistors are all 4 Ohms and the vertical resistors are 3 Ohms, the equivalent resistance is 6 Ohms.
If you can evaluate the exponential ladder as a fraction, p/q, which you can, then the result must always be a fraction, and so the result should always be rational.
Then comes a problem, that you must evaluate an infinite number of terms, so p and q will each have an infinite number of digits, and the evaluation process will take longer than forever.
It seems there are few or no common divisors between p and q, so the numbers do not collapse.
You are correct, that is a good counter example.
bob012345 said:
TL;DR: An infinite resistor ladder is given in one of Paul Nahin’s books* and he asks the reader to find the exact solution. I believe there is no closed form exact solution as a single rational number.
The resistance between points A and B can be expressed in the form of the infinite continued fraction. $$ 1+\frac{1}{1+\frac{1}{0.1+\frac{1}{0.1+\frac{1}{0.01+\frac{1}{0.01+\ddots }}}}} $$
or $$ a_{0}+\frac{1}{a_{1}+\frac{1}{a_{2}+\frac{1}{a_{3}+\ddots}}} $$
where
  • ## a_0 = 1 ##
  • ## a_1 = 1 ##
  • ## a_2 = 0.1 ##
  • ## a_3 = 0.1 ##
  • ## a_4 = 0.01 ##
  • ## a_5 = 0.01 ##
  • ## a_6 = 0.001 ##
  • ## a_7 = 0.001 ##
In general, for any step ## n\ge0 ##, the paired coefficients are ## a_{2n} = a_{2n+1} = 10^{-n} ##.
By using Excel I get the next results:
  • Depth 1 (up to the second ## 1 ##): ## 2.0000000000000 ##
  • Depth 3 (up to the second ## 0.1 ##): ## 1.9099099099099 ##
  • Depth 5 (up to the second ## 0.01 ##): ## 1.9018741230797 ##
  • Depth 7 (up to the second ## 0.001 ##): ## 1.9010792969512 ##
  • Depth 9 (up to the second ## 0.0001 ##): ## 1.9009999009822 ##
  • Depth 11 (up to the second ## 0.00001 ##): ## 1.9009919622508 ##
  • Depth 13 (up to the second ## 0.000001 ##): ## 1.9009911683864 ##
  • Depth 15 (up to the second ## 0.0000001 ##): ## 1.9009910890000 ##
  • Depth 17 (up to the second ## 0.00000001 ##): ## 1.9009910810614 ##
  • Depth 19 (up to the second ## 0.000000001 ##): ## 1.9009910802675 ##
  • Depth 21 (up to the second ## 0.0000000001 ##): ## 1.9009910801881 ##
  • Depth 23 (up to the second ## 0.00000000001 ##): ## 1.9009910801802 ##
  • Depth 25 (up to the second ## 0.000000000001 ##): ## 1.9009910801794 ##
Obviously, the resistance between points A and B is approximately 1.9009910801794 ohms.
I have found that this continued fraction converges rather slowly. As ##n→∞##, the horizontal resistors become vanishingly small and the rest of the ladder collapses to ##0.9 ⋅10^n##. Substituting that for the last term in the series for each ##n## yields much faster convergence.
The thing I find about continued fractions, and ladder attenuators, is that evaluation from right to left attenuates the numerical errors made earlier on the right as the computation moves to the left. That means it is quite insensitive to the choice made as an approximate guess for the infinite right-hand side.
I’m not sure what you mean. It makes a big difference what value I pick for the infinite termination. The value of ##0.9⋅10^n## is not arbitrary.
BTW, the reverse ladder, where the horizontal resistors are large and the vertical resistors are small, converges super fast with no assumptions about the terminal stage since that is the one that vanishes. I get ##R_∞=1.90990909917198…##
where
  • ## a_0 = 1 ##
  • ## a_1 = 1 ##
  • ## a_2 = 0.1 ##
  • ## a_3 = 0.1 ##
  • ## a_4 = 0.01 ##
  • ## a_5 = 0.01 ##
  • ## a_6 = 0.001 ##
  • ## a_7 = 0.001 ##
Can we
But I don't see a clear functional equation nor anything else , to determine if the limit is Rational.
The limit is irrational, and the primary objective now is to provide a rigorous proof of its irrationality.
We know that a ladder network can be solved as a rational fraction, p/q, however that cannot be done with an infinite exponential ladder, so we need an approximation. Each time we add one more step, to get a closer approximation, that would increase the number of digits in p and in q, but as a truncated continued fraction, the approximation would remain rational.
So, instead, we consider a limit. How do we know that the limit is irrational?
The limit is neither of a sum, nor a product, the limit is of a recursive application of a continued fraction;
r' = ai + 1 / ( ai + 1 / r )
For the original infinite ladder in post #1 I have found that the number of digits in ##p## and ##q## goes as ##1+n(n-1)## as in post #5 above.
Infinite sums of Rationals aren't necessarily Rational. The Euler constant e can be written as e^1=1+1/2+...+1/n!+...
True, but a truncated rational series, is still rational.
The limit we need, is where the exponential will finally settle.
Here is a (poorly conditioned) bidirectional exponential extrapolator.
Given three y values, p, q, r, equally spaced along the x or time axis.
It predicts the final y value, s, to which the curve will settle.
Or, for a rising exponential, s, the y value from which it all began.
s = ( p*r - q*q ) / ( p - 2*q + r )
Obviously it requires the three points to have different y values.
It automatically handles both a monotonic, or an alternating approach to s.
So now take three sequential values from the exponentially converging ladder network, to see how well it predicts the limit.
A, yes, and the continued fraction expansion is infinite too.
And it may be rational, irrational and if irrational it may be expressible as a compact, exact quantity involving a square root or it may not be such as ##\pi##. Such a number is transcendental. Our ladder may be the latter.
The exponential function is also transcendental.
Does that demonstrate that the exponential ladder is also irrational?
I believe if it’s transcendental it is also irrational.
Isn't it necessary for [a1;a2, a3,....] to be finite for the limit to be Rational?
The recurrence relation seems like the natural way to attack this rather than relying on numerical convergence alone. For a finite ladder, the equivalent resistance is rational, so the interesting part is what happens as the number of sections tends to infinity. If the ladder is self-similar, the limiting resistance should satisfy an algebraic equation obtained from the repeated section. That would give a direct way to determine whether the limit is rational or irrational. It would be interesting to see the exact polynomial and then test its possible rational roots.
Yes, for ##q=a/b ; b /neq 0, bq-a ## has ##q## as a root.
Doing that derives the limiting term as ##0.9⋅10^n## discussed in post #8.
You're right, I missed that in my earlier comment. I was thinking along the right lines with the recurrence, but I overlooked the result you had already derived in post #8. Thanks for catching that. I'll go back through the derivation before commenting further.
Here are recursion relations that give the exact polynomials for the numerator and denominator for any ladder with ##N## stages and a scaling factor ##q##. In all cases the first stage resistors are both 1 unit. For the ##N^{th}## stage, the shunt resistor is ##q^n## where ##n=N-1##. For example the second stage (##N=2##) resistor is ##q^1##.
For ##R_N= \frac{P_1(q)}{Q_1(q)}## where the subscript ##1## is the highest order polynomial for a given ##N##. We start with the ##P## functions. We have ##P_N=1+q^{2N-2}## and ##P_{N+1}=1##, then for ##k=1,.N-1## we have
$$P_k=(1+q^{2k-2}+q^{2k-1})P_{k+1}-q^{4k-1}P_{k+2}$$ then ##R_N=\large\frac{P_1}{P_1-P_2}## with a simplifying relationship that ##Q_1=P_1-P_2##
Of course ##P_1## and ##P_2## are different polynomials for different numbers of stages ##N##. Here are some examples. First let ##N=1##. Then ## P_1=1+q^{2-2}=2## and ##P_2=1## so ##R_1=\frac{2}{2-1}=2##
Now let ##N=2##. Now ##P_2=1+q^2## and ##P_3=1## and ##k=1## and
$$P_1=(1+q^0+q^1)P_2 -q^3P_3$$ thus $$P_1=(2+q^1)(1+q^2)-q^3=2q^2+q+2$$
And $$P_1-P_2=q^2+q+1$$ thus ##R_2=\large\frac{2q^2+q+2}{q^2+q+1}=\large\frac{212}{111}## since ##q=10##
Hello everyone,
I think the exact value should be $$R_{\infty} = \sqrt{26} - 4 = 1.099019513592785,$$ that is the solution of the equation $$ x = 1+ \frac{1}{\frac{1}{1}+\frac{10}{x}},$$ or $$x^2+8x-10 = 0,$$ since the equivalent resistance at the right of the first vertical resistor is equal to that at the input divided by 10 (it is an infinite ladder ...). Do you agree?
@lrg
Welcome to PF.
lrg said:
I think the exact value should be √26 - 4 = 1.099019513592785
1.099019513592785, is very different from
1.9009910801792881, the numerical result evaluated over more than 100 terms.
Your result is for the CF = 1+1/10+1/10+1/10+1/10+1/10+1/10+1/10+ 1/. . .
The CF we need is = [1, 1, 9, 9, 1, 99, 99, 1, 999, 999, 1, 9999, 9999, 1, ...
According to Google, this number is an example of an irrational number that is extremely well approximated by rational fractions at specific truncation steps.
Baluncore said:
@lrg
Welcome to PF.
Yes, it is very different, but I think the numerical evaluation above is misleading, because it starts with ##r = 10^{n+1}##, which means that the infinite ladder to the right of the last vertical resistor is completely cut off, which is the worst thing to do. If we start with ##r=0## (still wrong, but closer to the real value), we got ##1.099990000999999994687##, which is closer to my value. It would be interesting to understand why it is not equal. I don't have an immediate answer, but I suspect that this is one of those computations where the initial condition matters a lot, if not most, and so only the 'right' numerical value can give the exact final value, but I'm just speculating...
