Mentor
- 50,800
- 26,800
No, we don't see that, because, as has already been pointed out multiple times, the fact that Ma's (1) is algebraically equivalent to Ma's (2), to us, means that physically they are the same state. So if Ma's (1) is the pre-swap state, so is Ma's (2).DrChinese said:Don't you see this has no useful meaning in the physics we are discussing?
You disagree; you think Ma's (2) is the post-swap state. That's a disagreement about physics, not about algebra. It's you not believing what I said in the previous paragraph. Which, to us, is like not believing that the different expressions in #238 are all describing the same thing.
Here's another analogy: suppose I have a vector on the Euclidean plane. I pick a basis ##\vec{x}##, ##\vec{y}## such that the vector is ##\vec{x}##. It's an arrow with a specific length (one) pointing in a specific direction (whichever direction the ##x## axis points).
Now I rewrite that vector in a new basis ##\vec{u}##, ##\vec{v}##, whose axes are rotated by 45 degrees, so that we have
\vec{x} = \frac{1}{\sqrt{2}} \left( \vec{u} - \vec{v} \right)
To me, and as far as I can tell to everyone in the thread except you, the expression on the RHS above is describing the same vector--the same arrow, with the same magnitude, pointing in the same direction--as the LHS. To you, it's apparently some meaningless math that has no relationship to anything. Or maybe to you it describes some other vector, which we obtained by doing something to the arrow described by ##\vec{x}##. At this point it's hard for me to tell what your mental model of all this is.
That's the kind of disagreement we're having. All these states we've been writing down are vectors in a vector space. True, it's a vector space over the complex numbers instead of the reals, and it has eight dimensions (2 for each photon) instead of two, so it's not the same vector space as the 2-dimensional Euclidean plane. But it's still a vector space, and a general fact about all vector spaces is that you can rewrite a vector in a different basis--which is just algebra--without changing the vector. And when we use vector spaces in physics, the physical meaning of what I just said is that different rewritings of the same mathematical vector in different bases describe the same physical thing. In this case, the state of the 4-photon system pre-swap. If Ma's (1) describes that physical thing, and Ma's (2) is a rewriting of Ma's (1) in a different basis, i.e., just algebra, then Ma's (2) also describes that physical thing. It doesn't describe some other physical thing.
That's how I see things, and as far as I can tell, it's how everyone here except you sees things. One thing is certain: it's not just a mathematical disagreement. It's a physical disagrement, because we're using math here to do physics.
