Could Using AC Induction to Separate Aluminum from Food Products be Harmful?
  • Context: Undergrad
  • Thread starter Thread starter jmedlen27
    Ac Induction
The discussion revolves around the feasibility and safety of using AC induction to separate aluminum from food products. Participants explore the technical aspects of the process, its potential effects on food safety, and comparisons to existing methods used in recycling.
  • One participant questions the possibility of using AC induction to separate aluminum, referencing existing methods like Edy machines used in recycling.
  • Another participant asserts that aluminum does not experience a force due to AC induction and suggests that charging the aluminum may be necessary for attraction.
  • Some participants clarify that aluminum is repelled by an alternating magnetic field, which is a principle behind eddy-current separators.
  • Concerns are raised about the effectiveness of AC induction for removing metal scraps from food products, with suggestions that sieving or screening might be more effective.
  • There is a discussion about whether microwave energy has harmful effects on food, with one participant suggesting that AC induction might not be harmful either, although it could potentially heat the food depending on the power density and frequency.
  • Another participant explains that non-ferrous materials like aluminum can still experience eddy currents and describes how these currents behave in the presence of a magnetic field.
  • One participant notes that while AC induction shouldn't harm food directly, there could be risks of excessive heating or electrochemical reactions between the container and the food.
Participants express differing views on the effectiveness of AC induction for separating aluminum and its potential impact on food safety. There is no consensus on the feasibility of the method or its safety implications.
Participants mention various assumptions about the behavior of aluminum in magnetic fields and the conditions under which eddy currents are generated. The discussion includes references to specific technical principles like Lenz's law without resolving the complexities involved.
jmedlen27
I am currently looking into using a master magnet to separate aluminum from food products by AC induction. First, does anyone know if this would be at all possible? I know that recycling companies use Edy machines which sound like the same process of seperating cans from other materials. I am also wondering if this process would be hamrful to use with food because I have only found incidences of this with waste and recycling products. Please let me know what you think.
Aluminum will not feel a force due to AC induction.
You will need a way to charge the aluminum and attract it away.
Sorry, LC, but Alumin(i)um is repelled by an alternating field. That is the basis of the eddy-current separators mentioned.
See...
http://college.usc.edu/labs/physicsdemolab/electrostatics/eddy.cfm#em53
How cost-effective it will be at clearing scraps and slivers of metal from eg animal feed, I have no idea. Sieving or screening may be a better option. Sadly, the best option may be to tackle the source of the debris...
Its non ferrous, so it shouldn't have any loop currents? It shouldn't feel any force. Also if there were currents wouldn't they follow the currents of the inductor and it would attract?
Well if microwave energy doesn't have any proven harmful effects with food, it's hard to imagine ac inducion would. On the other hand, if the power density is sufficient, you might slightly cook (heat) the food depending on frequencies involved...there was a thread about microwave cooking here in the last few months if you are interested...seems most of the effect is related to dipole moments in water molecules...
A material doesn't have to be ferrous to experience eddy currents, it only needs to conduct electricity, and the induced field opposes the applied one.
Take a thick aluminum plate and wave a rare Earth magnet across it...when you approach the plate closely, you'll feel the drag produced by the eddy currents induced in the aluminum. Works with coins, too...put a US quarter on a piece of cardboard and slide a large rare Earth magnet around beneath it. The coin will "catch on" the moving magnetic field and move along with the magnet. With an AC powered electromagnet, you can easily achieve repulsive forces in highly conductive non-ferrous materials while still having net attractive forces on ferrous materials. Aside from recyclable metal sorting, it's used for electromagnetic brakes and repairing dents in aluminum aircraft skins (electromagnetic "dent pullers").
And to answer the actual question...it shouldn't harm the food directly. Depending on the construction, you may heat parts of the container excessively or possibly induce currents that could cause electrochemical reactions between the container and the food. The latter seems unlikely, but is something to watch out for.
It still amazes me every time I drop a magnet down a copper or aluminum pipe.
I guess I just find it amazing that the currents refuse to follow the current from the electro magnet but are willing to curl in the opposite way.
For it to do otherwise would be...surprising. A growing field penetrating a conductor would make itself grow faster. A magnet pushed into a copper tube would accelerate, with acceleration proportional to its velocity. (actually, I'm not sure you could say that much...since the Lorentz force would have to flip direction to allow it, and if it did so randomly, there should be no overall induced current)
http://en.wikipedia.org/wiki/Lenz's_law
  • · Replies 43 ·
