Is the true for any scalar function?
  • Thread starter Thread starter CalcYouLater
    Function Scalar
The discussion revolves around the properties of a scalar function \(\phi\) that depends on a single spatial variable, specifically in the context of line integrals and the implications of certain theorems in vector calculus.
  • Participants explore the validity of integrating the partial derivative of \(\phi\) over a closed path, questioning the implications of \(\phi\) depending solely on one variable. Some participants attempt to clarify the meaning of "a single position" and its relevance to the problem.
The conversation includes various interpretations of the problem, with some participants suggesting that the original poster's assumptions may not hold true in all cases. There is acknowledgment of the need for clarity regarding the definitions and conditions presented.
Participants note potential confusion regarding the term "single position" and its implications for the scalar function \(\phi\). There is also mention of specific examples, such as \(\phi = xy\), which challenge the original assumptions. The discussion references the irrotational field theorem and the gradient theorem as relevant concepts.
CalcYouLater
If \phi depends on a single position only, \phi=\phi(x,y,z)
Can I say that:
\oint{\frac{\partial\phi}{\partial{x}}dx=\oint{d\phi}=[\phi]_{a}^{a}=0
Provided that the point a lies on the closed path being integrated around?
I am 99.99% sure I can. I am in the middle of "showing" how one theorem implies another, and I wasn't sure if I could knock the partial dx off with the total dx in any case under the conditions above. Thanks for any help. (Sorry, I can't seem to get my latex correct. The second to last term is intended to be phi evaluated from a to a. Also the title should read "Is this true for any scalar function")
Well, since \phi depends only on x,
<br /> \frac{\partial\phi}{\partial y} = 0 = \frac{\partial\phi}{\partial z}.<br />
So,
d\phi = \frac{\partial\phi}{\partial x} dx + \frac{\partial\phi}{\partial y} dy + \frac{\partial\phi}{\partial z} dz = \frac{\partial\phi}{\partial y} dx.
Hence,
\oint d\phi = \oint \frac{\partial\phi}{\partial x}dx = \int_a ^a\frac{\partial\phi}{\partial x}dx = 0.
However, I'm not sure what you mean by
What point are you referring to?
Can I say that:
Not sure what you mean when you say φ "depends on a single position only" but I think the answer is no. Consider φ = xy and C the boundary of the unit square.
\oint_C \phi_x\, dx = \oint_C y\, dx = -1
because only the top side of the square contributes a nonzero value.
I think he means that φ depends on a single parameter (e.g. only the x-coordinate).
Thank you both for the responses.
Sorry, I should have been more clear. I intended to say that "a" is a point on the path. That was bad use of wording on my part.
When I said that φ depends on a single position only, I meant to imply that it was something like a potential, or temperature distribution. I can see how the way I worded it is confusing.
After thinking about LCKurtz's scenario with the unit square I realize that I have totally butchered this question.
Here is what I should have done from the start:
Irrotational field theorem
Given that:
a.) \overline{\nabla}\times\overline{F}=0
b.) \oint{\overline{F}\cdot{d{\overline{l}}}=0
Show that a\rightarrowb
\overline{\nabla}\times\overline{F}=0\Leftrightarrow{\overline{F}}=\overline{\nabla}V
I know that Stoke's theorem will show this in an instant. I wanted to try and show it using the equations listed under relevant equations. My thought was that by writing the vector indicated by "F" as the gradient of some scalar, I could show that integrating along a closed path would give me a null result for any scalar chosen.
Well, you could use the fact that \nabla V is a path-independent vector field.
Hmm, does that mean it is as simple as saying:
\overline{\nabla}V{\bot}{d\overline{l}}
For constant "V"
Duh, I should have been thinking about the fundamental theorem of Calculus as well as the gradient theorem.
Gradient Theorem:
\int_{a}^{b}(\nabla{f})\cdot{d{\overline{l}}}=f(b)-f(a)
Thanks again to foxjwill and LCKurtz for their help!
