Calculating Gravity and Orbital Speed of Mercury at Mean Distance from the Sun
  • Thread starter Thread starter vasfinest18
    Motion
The problem involves calculating the strength of the Sun's gravitational field at Mercury's mean distance and determining Mercury's orbital speed. The context is centered around gravitational physics and orbital mechanics.
  • Participants discuss the appropriate formula for gravitational strength and question the necessary variables needed for calculations. There is mention of the gravitational constant and the mass of the Sun, as well as the interpretation of the mean distance as the radius.
Some participants have provided guidance on looking up necessary values and clarifying the formula to use. There is an ongoing exploration of the variables involved, with no explicit consensus reached on the approach to take.
Participants note the need for additional information, such as the mass of the Sun and the gravitational constant, which are not provided in the original problem statement. There are reminders about posting etiquette and the importance of showing attempts in homework queries.
vasfinest18
hey, i am really stuck on this problem and i was wondering if anyone could help me...
The planet Mercury orbits the Sun at a mean distance of 5.80X10^7 km.
a) calculate the strength of the Sun's gravity field (g) at Mercury's mean distance.
b) Calculate Mercury's orbital speed in m/s and in km/h.
Any assistance on the problem would be greatly appreciated!
Hi vasfinest18,
In the future, post questions like these in the homework section. And lastly, you must show an attempt. So any thoughts what to do?
is the formula that i need to use g=GM/r^2? there must be some more info that i need to derive from the problem, because i was only given 1 number. should i substitute 10m/s^2 in for G?? but if that is the right equation to use, i am still missing another piece of info that i would need...
g=GM/r^2... i think but i need 3 out of those 4 variables, and i only have 1 given.. G is mostly likely 10 m/s^2, but from there i don't know how to calculate 'g' or M.
Well for first problem, you are right track. G is simply the gravitational constant (look up the value). r is the distance between the sun and mercury. And you already know the mass of the sun. Just plug in the values into the formula and all should be good.
Open your physics book, there you will find the values you don't have. Usually on a table.
is the mean distance the radius? and for the mass should i just look up the mass of the sun?
Obviously you must look up the mass if you do not know it.
If this thread appears to be confusing, that's because it has been merged with another that was posted in the wrong forum.
Please do NOT cross post.
Zz.
I don't find this thread constructive at all.
The question is blatantly straightforward.
g=GM/r²
where g = gravitational strength at that point,
G = gravitational constant,
M = mass of the object "creating" the gravity field, the sun in this case,
r = distance between the CG(center of gravity) sun and CG of the planet.
You should read up on any physics textbooks on chapter about gravitation before asking.
Edit:
and as for the second part, its another rigid equation you can find under circular motion. zzz
12K
