Application of piezo-electric effect
  • Thread starter Thread starter Young Learner
    Application
The discussion centers on the feasibility of using a piezo-electric crystal to charge a small battery while simultaneously supplying current to a load. It raises concerns about whether the same battery can be used for both charging and discharging, given the battery's need to provide current for short periods. Participants suggest that directly connecting the load to the battery may be possible, but caution that piezo-electric devices typically generate high voltage at low current. Additionally, the potential for feeding back vibrations from the load to recharge the piezo-electric crystal is explored, with references to relevant projects and resources. Overall, the conversation emphasizes the complexities and limitations of integrating piezo-electric systems with battery technology.
Young Learner
Can I use the piezo-electric crystal to charge a small battery and connect the battery to a load.
The problem here is that the battery has to supply current to the load for a short period. Then it has to be recharged by the crystal. will I be able to use the same battery for charging and discharging?
The circuit for piezo-electric storage found in the internet is http://ej.iop.org/images/0957-0233/23/1/015101/Full/mst399991fig10.jpg
Should I directly connect the load to the battery.
Can I be able to feed back the vibration produced by the load to PZT and hence using it for charging the battery
Likes 1 person
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
