lazyaditya
- 176
- 7
3,8,17,24,49,58,117,?
what is the missing number ? Also give the pattern you followed.
HallsofIvy said:There are of course, an infinite number of solutions.
MrAnchovy said:It is implicit in this kind of problem that although there are an infinite number of potential solutions, if the problem is well-formed the unique correct solution can be found by applying Occam's razor.
As you well know HallsofIvy![]()
How did you come by your solution?MrAnchovy said:128.
3 + 5 = 8
8 x 2 + 1 = 17
17 + 7 = 24
24 x 2 + 1 = 49
49 + 9 = 58
58 x 2 + 1 = 117
117 + 11 = 128
jedishrfu said:Using Occam's razor is still an arbitrary choice for any problem with incomplete knowledge.
jedishrfu said:There may yet be an underlying pattern to the one you discovered that even more understandable using one rule instead of two.
jedishrfu said:Also could we drop the sarcasm from your post?
jedishrfu said:Halls is a respected contributor and mentor to this forum and part of his responsibility is to direct students along the path of solution but not actually solve it.
jedishrfu said:How did you come by your solution?
What insight did you have or what method did you follow?
jedishrfu said:Personally, I felt it was complex but it brought to light another way to solve these kinds of problems.
jedishrfu said:As I looked at it I did see the odd numbers 5, 7, and 9 so perhaps that's all that needed to solve it. However, I didn't see the succ = pred*2 + 1 expression though.
Can you tell us how you came to your solution?
It would help the OP understand the methods of solution better. I didn't see the complete solution either so I too would benefit.
3 8 17 24 49 58 117
5 9 7 25 9 59
jbriggs444 said:The same solution had occurred to me, but did not seem sufficiently simple, so I refrained from posting. There are a number of pairs where the first member is n and the second member was 2n+1. The final such pair involves large enough numbers to make the coincidence suspicious.
The pairs occur in a pattern (every odd numbered term is the first member of such a pair).
The first members of those pairs occur in a pattern (simple arithmetic sequence of differences).
