What is the typical resistance for GMR in 3-layer Fe-Cu-Fe configuration?
  • Thread starter Thread starter michaeltorrent
michaeltorrent
for giant magnetoresistance with 3 layers suppose Fe-Cu-Fe, and suppose we take room temperature (300K) and moderate layer thickness (eg Fe = 30 Amstrong, Cu = 20 Amstrong),
what is the typical magnetoresistance we get? I mean the maximum resistance (in ohms) when the magnetization of the FM layers are antiparallel (i am not asking the GMR ratio delta r/ro).
Is it in the order of few tens of ohms, hundreds of ohms, kilo ohms ?
i just want rough estimate. all references i saw talk about the gmr ratio only, not the actual resistance.
thank you.
You can make a rough estimate using the bulk resistivity of copper and/or of iron. So it depends on the other dimensions of the film (length and width).
If we just take the sheet or surface resistance of a 10 Å film, one would divide the bulk resistivity by the thickness: (10^-8 Ohm.m)/(10^-9 m) = 10 Ohm (per square).
(Of course, this does not really work when dimensions become smaller than the electron mean free path. I copper at room temperature, this is about 300 Å. It only gives a rough estimate.)
hey .. guys . ... I was wondering if anyone did some exerimental work on GMR .. I have been trying to get GMR in nanowires but have not been successful .. I have tried varying pulse timing but have had no luck ... Can anyone help me out??
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
