Calculate Probability of Winning Head and Tails Game
  • Thread starter Thread starter haiha
    Game Head
The discussion revolves around calculating the probabilities of winning and tying in a coin-flipping game between two players. Participants are trying to derive formulas for the probabilities of each player winning (A) and the probability of a tie (B). The conversation highlights the use of binomial distribution to compute these probabilities, with specific focus on the case where both players achieve the same number of heads. An approximation using normal distribution is suggested for calculating the probability of equal scores, yielding a result of 1/√(nπ). The complexity of the calculations and potential errors in the initial approach are acknowledged throughout the discussion.
haiha
I ve got this simple problem and I can can not find the solution.
Two men play head and tails. Each man flips the coin n times, every time he has head, he should add one point to his score. At the end, they compare the scores, whose score has more points , the man is the winner.
A is the probability of a man lose or win, B is the probability when the two have the same points. Calculate A and B?
Thanks
The first thing you want to do is show us where you're stuck. As a hint, find the probability that person 1 rolls m heads, then find the probability that the other rolls more than m heads.
Thanks for your answering me
My way is to find the B value meaning the two are equal. So i tried to calculate the probabiltiy of 1st man to have m heads, then the 2nd also must have m heads, which is called Pm. Then I will sum up Pm with m running from 0 to n. But the formula is very long and i think there must be mistakes somewhere..
P0 = 1/2^(2n)
P1=2.n/2^2n
P2=..
Your sum is correct. Are you sure you have to actually evaluate the sum, or can you just leave your answer in terms of the sum?
This is not a trivial sum to compute.
- Warren
Can anyone find the general formula for Pm?, at least one that can be computed using a program.
"Pm" is simple -- it's a Binomial distribution:
<br /> p \left( m \right) = \left( {\begin{array}{*{20}c}<br /> n \\<br /> m \\<br /> <br /> \end{array} } \right)p^m \left( {1 - p} \right)^{n - m} = \left( {\begin{array}{*{20}c}<br /> n \\<br /> m \\<br /> <br /> \end{array} } \right)2^{ - n} <br />
where p is the probability of heads (1/2), n is the number of flips, and m is the number of heads.
Remember that the probability of both men getting m heads is actually [p(m)]^2.
- Warren
So I can not calculate P0, when the two men both have no heads ?
Oh I m sorry, I thought (n/m) is a division!.
You can get an approximate answer by replacing the binomial distribution by a normal distribution. The pdf of the "two scores are equal" distribution is the square of the pdf of the normal distribution.
Since (e^{-x^2})^2 = e^{-2x^2} this is similar to a normal distribution so you can integrate it.
The approximate probability of equal scores after n tosses is 1/\sqrt{n\pi}.
please explain me how do this
