How to Evaluate Indefinite Integrals with Radical Expressions?
y_lindsay
how to evaluate the indefinite integral
∫(x^2-1)^(-1/2) dx
and
∫x^(-1)*(1-x^2)^(-1/2) dx
Try to think like this:
Why are these integrals hard?
First hurdle:
There are ugly square roots here!
So, the next question is naturally:
What is the simplest way to "eliminate" a square root sign?
Answer:
Ensuring that the radicand is a perfect square!
Then, the root and the square would eliminate each other.
Agreed?
Thus, tackle the first one:
If x^{2}-1=y^{2}
then x^{2}-y^{2}=1
Do you know of any functions that behaves like x and y here?
Possibly, you are familiar with the hyperbolic functions, Cosh(u) and Sinh(u) which satisfies for all u the identity: Cosh^{2}u-Sinh^{2}(u)=1
In terms of exponentials, we have the relations:
Cosh(u)=\frac{e^{u}+e^{-u}}{2},Sinh(u)=\frac{e^{u}-e^{-u}}{2}
Thus, we set x=Cosh(u), whereby we transform the integral as follows:
\int\frac{dx}{\sqrt{x^{2}-1}}=\int\frac{1}{|Sinh(u)|}\frac{dx}{du}du
Now, we have that \frac{d}{du}Cosh(u)=Sinh(u), whereby the integral reduces to:
sgn(Sinh(u))\int{du}=sgn(Sinh(u))u=|u|
since Sinh(u) and u has matching sign domains.
Okay so far?
Actually, arildno I don't think we need to introduce hyperbolic functions. They might work, but you're thinking too much. I could solve both of them by using normal (non-hyperbolic) trigo substitutions.
@OP:
You might find this trigo identity useful:
(tan θ)^2 = (sec θ)^2 - 1
Once you figured out the proper trigo subst for the first one from the clue above, you're done.
For the 2nd one, you need a different trigo substitution. The following identity is useful:
(sin θ)^2 = 1 - (cos θ)^2
I LIKE hyperbolic functions, that's why I use them. :smile:
I am perfectly well aware of the sec substitution, but the result is more elegantly written in terms of hyperbolics/their inverses.
That's why I like them..
Defennnder, I also would tend to use trig functions, perhaps because that is what I first learned, but I noticed that arildno tends to use hyperbolic functions. It's certainly NOT a matter of "thinking too much"- one is as good as the other. One advantage I will conced to hyperbolic functions- you can use sinh and cosh rather than sec and tan which have more complicated integration and differentiation rules than sinh and cosh.
Thanks arildno, i haven't thought out the hyperbolic solution to the first problem.
yet to solve the 2nd problem,
is there any other way rather than using substitution x=sin u ?
I've thought out another possible substitution u=1/x, and then we could use the result of the firtst problem.
am i right?
That should work nicely, yes.
