What is the center of mass of a cone?
The discussion revolves around finding the center of mass of a right circular cone, along with its volume, mass, and moment of inertia. The cone has a constant density and specific dimensions provided by the original poster.
  • Participants discuss setting up integrals for volume and mass calculations, with some uncertainty about the limits of integration. There are attempts to clarify the relationship between mass elements and the geometry of the cone, particularly in relation to the center of mass and moment of inertia.
The discussion is active, with participants asking clarifying questions about the variables involved in the equations and the setup of integrals. Some guidance has been provided regarding the relationships between the dimensions of the cone and the integration process, but no consensus has been reached on the specific equations to use.
Participants are working under the constraints of homework rules, which may limit the amount of direct assistance they can provide. There is also a focus on understanding the definitions and relationships between mass, incremental mass elements, and the geometry of the cone.
Nightrider519
1. A right circulat cone of constant density (5kg per m^3) is 4 meters from the base to the tip. the diameter of the base is 6 m. find each of the following using inergrals
A) Find the volume and mass of the cone
B) find the center of mass of the cone
C) find the moment of inertia of the cone when rotated about the central axis
d) find the moment of inertia of the cone when rotated about the tip
Welcome to PF.
How would you think to go about setting up the integrals?
I can't figure out what equation to integrate i think for the volume the limits would be from 0-6 but i am not too sure
Maybe this will help?
http://www.mph.net/coelsner/JSP_applets/cone_ex.htm
You will still need to balance the weight along the height axis.
i can't figure out how to derive the moment of inertia about the center of the cone
Figure that
[tex]X =\frac{ \int x*m dm}{M}[/tex]
Now the mass at any point is a disk - our dm which is πr²*dx times density that we can just set to 1 because it is uniform.
Observing that the radius at any x can be given by r = R*(1-x/H)
where R is the radius of the base and H is the Height of the cone ... then combine and you get a definite integral in x from 0 to H
what is m and what is M and is this for C.O.M or the moment of inertia
Forgot to answer your question. M is the Total Mass in the system - in this case the Mass of the cone, and m is incremental mass elements.
Hence the term πr²*dx to replace the m*dm. Because with uniform mass distribution, you can model your incremental m along x as tiny disks of radius r, so you just use the area of that slice πr².
Now r as it turns out is also a function of x along x. You should be able to satisfy yourself that the (1 - x/H) is the relationship that r has with increasing x, as you move from the base along the x-axis toward the pointy top.
The rest is substitution and evaluating the integral between 0 and H, and I wouldn't want to spoil your fun at arriving at the answer all together.
  • · Replies 25 ·
