Is Time Static Like Other Dimensions?
  • Level: Graduate
  • Thread starter Thread starter dimensionless
    Time
53 replies · 10K views
dimensionless
When I make plots and graphs, time is just another dimension. When I write an equation, it is just another variable. The present does not erase the past, and it does not preclude the future. Clearly our consciousness moves in the positive direction along the time axis, but time itself, does not appear to be moving anywhere. If you could travel back in time, my body would still be there. If you could travel forwards in time, my body would be there as well(or at least the mass and energy that used to be me). If you made a plot of me vs. time, I would exist everywhere along the time axis. Do you think that time is static in the same way that height, width, and depth are?
The universe appears to be evolving, changing from instant to instant. The past is our record of physical configurations that no longer exist. The future is our prediction, based on records of the past, of physical configurations that might evolve.
Time is motion, the recording of different physical configurations. The fact that each recorded configuration is unique, and that each unique configuration in our index is more like its close neighbors than its distant ones, suggests a preferred evolutionary direction -- ie., an arrow of time.
You can't travel to something that doesn't physically exist any more -- except in your imagination of course.
That's the point. The matter and energy of the universe are continually changing. 1000 years from now there won't be any you.
Yes, for as long as you actually exist. But even then, each instantaneous configuration of you would be unique. You, as all of us, are evolving to nonexistence.
No.
I could also define past and future as volumes in space-time that merely have a value of "t" greater than or less than the present value.
This continuity exists in the other three dimensions as well, and I think we are in agreement that these are relatively static.
If space-time were defined as a function, say,
[tex]S(x,y,z,t)[/tex],
it would exist. It would just be at a different location along the t-axis.
I once had a physics teacher that said "We don't see people getting younger, we see them getting older, therefore time goes forwards." I believe this logic is flawed, because even if time did go backwards we would be unable think. Our thoughts would be undone. Our acquired knowledge would be leak from our consciousness like video tape being rewound. My understanding of time is that it is stagnant and moves neither forwards nor backwards. In mathematical terms, I see now reason why
[tex]S(x,y,z,t_{present})[/tex]
should exclude the existence of
[tex]S(x,y,z,t_{present}-\tau)[/tex]
and
[tex]S(x,y,z,t_{present}+\tau)[/tex]
Yes, I see what you mean.
I was using the word time as a synonym for change or motion, and I see now that that's not correct.
Time is an index of recorded spatial configurations. Psychological time refers to our personal, subjective experience of the world wherein the index is made via our human biological data processing faculties following the direct detection of physical variables via our sensing faculties. Objectively, time refers to the generation of indexes via standardized protocols and time-keeping devices, and the physical data might be generated, accumulated, and processed via instruments used to amplify physical variables and augment our human biological capabilities.
Time is just an index, no more no less -- nothing mysterious there.
Spacetime refers to a coordinate backdrop onto which spatial configurations and time indexes are jointly mapped. Nothing mysterious there either.
The phrase 'time moves forward' refers to the observation that each spatial configuration in an index of real world spatial configurations is unique -- that is, no configuration is repeated.
There's an archetypal pattern regarding physical processes that's most clearly seen in the radiative 'arrow of time' (eg., the evolution of a wave produced by dropping a small round object into calm water).
So, while it's not quite correct to say that 'time moves forward', nevertheless all real world time indexes have a common feature. They're all asymmetric in the same way, in that as you look backward through the indexed configurations they appear increasingly different from the most recent.
Yes, but the convention is, t_past < t_present < t_future.
Records of past spatial configurations exist, but not the spatial configurations themselves.
Insofar as the word, time, is used in ordinary language as a synonym for change or motion, then saying that it's static or stagnant without any elaboration can result in communication problems. But I now see what you're saying. Time is an index of motion (not motion itself) -- and the concept of an index is static in the same sense that the concepts of height, width and depth are static.
That is what you're saying, isn't it?
This is a standard debate in philosophy of time. Cfr Eternalism and Presentism and there is no final word on it.
I think that is more or less what i was trying to get at. There maybe other communication problems as well. I used words like "is," "would," and "are" and they can imply a specific point in time.
Thanks xantox. I don't think that the eternalist or presentist philosophies of time have it right. And, the conventional model of time vis Wikipedia is a sort of layman's philosophical extension of the way that the word, time, is used in everyday discourse, but not equivalent to it.
Time is just an index of a set of events or spatial configurations. Time indexes are generated by associating (correlating) configurations of some set or sets of spatial configurations with some other set or sets of spatial configurations. This interpretation is a generalization of SR's definition (or convention, regarding the procedure for generating time indexes) of the time of an event as the reading on a clock that is in the frame of reference of the object event or object configuration.
Time is a dimension in the sense that it is a set of measurements (correlations) that, collectively, organize (index) data accumulated via measurements of the spatial dimensions.
I think that that's all there is to it. Note that I'm not saying that time is like an index, but that it is an index (wrt both standard ordinary and technical scientific usage), no more, no less, no mystery, no problem. The word, time, as with any word, can be defined as something other than what it refers to in ordinary and technical scientific discourse. But what would be the point of that?
Can we revisit the spatial configurations catalogued in our recorded history, our time index, of the universe? This is the same as asking if we can rewind the evolution of the universe or any significant part of it? The evidence (salient features and emergent patterns revealed in the time indexes) suggests that we can't. The question of whether past universal configurations exist now is a nonsensical one.
Asking if we can take a shortcut through the natural evolution of the universe and sort of previsit temporally distant spatial configurations of some possible evolutionary path (wrt some possible future time index) that haven't happened yet, but might, is also a nonsensical question.
I'm not sure what you mean. Can you provide some examples where using those words would present problems?
Maybe we should talk about this in the philosophy forum?
For example, I used the sentence
This contained the phrase "is stagnant." Literally, this would mean that time is stagnant at the present time. It 'would' not, however, specify whether time 'would be' stagnant in the past or future.
It may have been better to put this in the philosophy forum, although some (more) mathematical arguments would be nice. Maybe the entire thread could be moved.
Eternalists do not suggest that we can revisit the past, but rather that there is a time-less ontology which is defined globally, and that we just happen within a photogram of a global movie. It also implies that the present is observer-dependent. For presentists, only the present has a defined ontology. It also implies that the present is absolute.
dimensionless said:
Clearly our consciousness moves in the positive direction along the time axis, ... If you could travel back in time, my body would still be there. If you could travel forwards in time, my body would be there as well
Actually, if you are going to talk about consciousness and time then I would say that we travel backwards in time. If I walk "forwards" towards the north then I percieve objects to the north of me which I have not yet reached. On the other hand, if I walk "backwards" towards the north then I see objects to the south of me which I have already passed and have to guess about the position of objects I am approaching. Similarly with time, as I walk towards the future I remember only things in the past and I have to guess about things that I am approaching in my future. I think it is therefore pretty clear that as far as consciousness goes we travel backwards through time.
dimensionless said:
For example, I used the sentence, "My understanding of time is that it is stagnant and moves neither forwards nor backwards."
If we define time as an index (a certain sort of index, but an index nonetheless) of a set of physical states -- whether it's observed states in the near or distant past or extrapolated states which might include the future as well as the past -- then insofar as the index is a set of corrolations of 'stagnant' physical states (ie., each state is a 'snapshot' of the universe or some part of it that is associated with a 'snapshot' of a clock of some sort -- note that wrt time indexes the states aren't simply assigned a value according to some more or less arbitrary indexing scheme like, say, the Dewey Decimal System or whatever), then the states, or any subset thereof, specified in the index are all 'stagnant' whether they are past or present or future states.
Time indexes themselves, as records, aren't motion, and don't necessarily imply it. The word, motion, refers to the observation that at least some states in a time index are unique. An interesting feature of the time index of the universe is that all the states in that index are different, and they are different in a way that suggests that the universe is evolving away from previous states.
This feature of time indexes wrt any physical scale is what is commonly termed the 'arrow of time'.
I'm not sure if this adequately addressed your consideration, but it's the way I'm currently thinking about time. I used to equate time with motion or change, and I now think (as explained in my recent posts) that that's not quite correct.
I think we might be on the same page wrt this issue, but I'm not sure. The index that we call time is stagnant in the same sense that any index is stagnant. The general concept of an index is static in the same sense that the concepts of height, width, and depth are static.
The concept of time, just as the concept of motion, doesn't tell us anything about the physical world. These terms just refer to ways of organizing recorded data about the world and talking about it. And, as I mentioned, the evidence is that the world is indeed changing and will continue to change in ways revealed by our time indexes of it.
Quantifiable mathematical shorthand representations are necessary to unambiguously communicate detailed statements about the world. But it's a good idea, I think, to have these sorts of semantic discussions in order to refine our ideas of what we're talking about and how it might be mathematically modeled.
For example, during the course of this discussion I discovered at least one error in the way I was thinking about the word, time.
If you think we're not on the same page wrt time, or if I've got it wrong in any of my ramblings, then your comments and criticisms are welcomed.
And, thanks for starting the thread.
Commonsensically we recognize that the word, time, refers to an index of sorts. But, without a detailed semantic analysis to more precisely ascertain what the word is referring to, we tend to reify it, and phrases like the flow of time or that we are moving in time emerge to confuse the issue. I view eternalism and presentism as byproducts of this confusion.
The ontological status of time is that it's a certain sort of index.
It's not about the reification of time. Eternalists and presentists talk about events. Eternalists consider that all events share the same ontology. Presentists consider that only present events have an ontology.
When Koko the signing gorilla was asked to point to the future she would point behind her. She could see the past, so it was in front of her. Or something like that :smile:
Anyway, what you wrote is compatible with the definition of time as an index of our experience.
Define an event as an indexed set of snapshots (subjective, ie., biologically sensed and recorded; or objective, ie., instrumentally recorded or via agreement of two or more subjective reports) of the world.
Subjective events and objective events share the same ontological status.
What we call the present, either wrt a subjective or an objective time index of the world, is the most recent past.
What we call the future is a projection or prediction regarding possible, but not yet recorded, events. A past might also be a backward extrapolated time index of possible, but not recorded, events.
Events (subjective and objective) and possible events don't share the same ontological status.
The word, time, doesn't refer to the object events of a time index or to any motion or change that might be revealed by the index. It refers to the index itself. An operational definition specifies a procedure for generating such an index. That's the ontological status of time.
ThomasT said:
What we call the future is a projection or prediction regarding possible, but not yet recorded, events. A past might also be a backward extrapolated time index of possible, but not recorded, events. All events don't share the same ontological status. Some are recorded and some aren't.
Recorded by who? Eternalists consider that all events no matter their time coordinate are recorded by some observer, so they all exist in some local present. They are just like events happening in a different space, say a different city : they all exist for someone who lives there. This means that the ontology of an event is independent from its space and time location, and that all events are recorded in Nature, which is like a giant Babel's library of all events.
For a presentist this is not true: only present events are real, and an event which happened in year 1020 only exists in present memories of it (which are in fact, other events), but the "original" event itself does not exist in Nature, which has a single memoryless state.
xantox said:
Recorded by who?
By us or instruments that we construct.
Our time indexed records, our objective histories, seem to indicate that this isn't the case. The conjectured occurrence of certain events doesn't establish their existence in any sense other than as constituents of the projected or extrapolated time index in which they occur.
Of course, not having an objective record of some possible event or other doesn't necessarily mean that it can't or didn't happen. And the universe of our records is itself a record of sorts that preserves at least some aspects of its more distant history.
However, the idea that recorded past events exist in some physical sense other than as records would involve a reification of the time index, and there's no reason to do that. The time index, like any index, is just an index, a data organizing tool.
xantox said:
This means that the ontology of an event is independent from its space and time location ...
The ontological status of an event is a function of our apprehension of it in time indexes of spatial configurations.
xantox said:
... and that all events are recorded in Nature, which is like a giant Babel's library of all events.
As I mentioned, remnants of more distant past events might be found in more recent events, but there's no reason to suppose that (say) the Chicago of 1920 exists in any physical way other than the remaining remnants of it and as part of our historical records of it.
I think it's reasonable to reject eternalism.
This makes more sense. However, as I've mentioned, what we call the present is actually a subset of the past.
Nevertheless, we can reasonably assume that there is single, memoryless spatial configuration that is the object of the most recent snapshot in our time index of an event.
However, only a physical theory, not reason alone, can be invoked to falsify whatever interpretation of reality (provided it is logically consistent). Special and general relativity falsify vanilla presentism, and are compatible with eternalism, so eternalism is the mainstream view amongst physicists. Since there is no full theory of quantum gravity, there is still a possibility that eternalism, or both eternalism and presentism, are wrong. According to some current incomplete theories of quantum gravity, some also falsify presentism and a very few others are compatible with both.
Physical theories are the result of reason applied to observations of the world.
xantox said:
Special and general relativity falsify vanilla presentism ...
I don't think so. It's just that since we get all of our info about the world via em, and since the rate of em propagation is finite, then we need a standard set of definitions, conventions, and procedures for generating time indexes in order to unambiguously communicate the information that those time indexes contain.
The idea that there is a single spatial configuration of the universe corresponding to each spatial configuration in a time index of an event isn't at odds with either SR or GR.
xantox said:
... and are compatible with eternalism ...
Yes, SR and GR can't be used to decide between presentism and eternalism.
xantox said:
... so eternalism is the mainstream view amongst physicists.
I don't think that's true. I don't think you'll find many physicists who think that the phrase "Plato exists" has any physical meaning other than wrt our historical records of him.
The grounds for rejecting eternalism and Plato's continued existence is in the information revealed in our time indexes of the world.
Our experience of the world is the final arbiter of statements about it, and our experience seems to indicate that time is an index -- no more, no less. Presentism is a reasonable extension of that. Eternalism isn't.
Both presentism and eternalism are nonsensical in that our experience can never (and hence no physical theory can ever unequivicably) establish the truth or falsity of either.
But, eternalism is the more nonsensical. :smile:
Yes, which means indeed not reason alone.
If which is time for one observer is space for another and the opposite, how you consider it's not at odds? Perhaps you could elaborate this point.
It's even worse for quantum physicists, many of them considering that even "Plato may exist" has a physical meaning.
You seem to consider that "our time indexes of the world" have a preferred status vs those of an infinite number of other observers located elsewhere in spacetime.
The fact that time is an index says nothing about the ontology of events. Both presentists and eternalists will agree that time is what is indicated by a clock. The different ontologies of the two viewpoints concern the reality status of non-present events. Our understanding of the world is relativistic, and if simultaneity is relative there is a prima facie problem with presentism which is not trivial to solve.
The way I see it, time as a fourth dimension is needed for the mathmatical model. The term "forward" when talking about time is just too abstract.
Right, what I was getting at was that we can use observation and reason to decide whether eternalism or presentism is closer to reality -- that we don't necessarily need a physical theory per se.
xantox said:
If what is time for one observer is space for another and the opposite, how do you consider it's not at odds? Perhaps you could elaborate this point.
The time of an event is, itself, an event. The time of a spatial configuration (or set thereof) is, itself, a spatial configuration (or set thereof).
Time is an index of events. Of course, acceleration (which includes gravity) affects time indexes -- and, SR and GR provide tools for transforming, and unambiguously communicating, time indexes from one frame of reference to another.
Ok. :smile: However, there's no particularly compelling reason to believe that all possible events in imaginary spaces (phase, Hilbert, spacetime, etc.) are in one to one correspondence with the real world. Physicists routinely discard solutions (allowed by models) that contradict observations.
One of the open questions in physics has to do with the problem of identifying a fundamental physical dynamic that makes events like broken teacups spontaneously reassembling themselves or Plato suddenly popping into existence (which, while so improbable that they'll never happen, are, nevertheless, possible wrt at least one model that's used extensively in physics) that have never been observed, and which would be contrary to the observed arrows of time, not just highly improbable but impossible in our universe.
An important thing to realize, imho, is that many (maybe most) of the various mathematical models of modern physics (especially wrt the quantum theory) aren't, and weren't developed as, descriptions of reality in any sense other than that they provide a framework or a scheme for predicting the outcomes of experiments.
Sure, I think our recorded observations of real spatial configurations (and extrapolations thereof) have a preferred status vs possible events in imaginary spaces (and extrapolations thereof). Don't you?
Ok -- but the indexes themselves do. I think that presentism is a reasonable extension of our experience and that eternalism isn't. Our experience is our time indexes of the physical world -- the world of our sensory experience.
(Of course, experimental results suggest that reality is deeper than that -- that there are spatial configurations in media that aren't amenable to our senses. It's reasonable to assume that there are wave structures, particulate media, and possibly non-particulate media that underly the behavior of the world of our senses. It's also reasonable to assume that, say, the wave mechanics of a deeper reality is not essentially different from the wave mechanics of the world of our sensory apprehension. But the eternalist assumption that the once extant now of the presentist still exists, somewhere in time, requires time to be something more than or other than just our indexes of our experience -- and, as I've mentioned, I don't think that the word, time, refers to anything more than or other than that.)
Yes, sort of like Copenhageners and MWIers agree that qm is a set of rules for calculating the probabilities of certain experimental preparations.
However, MWIers and eternalists attribute more, or a different, physical significance to their objects of consideration -- qm wavefunctions and time indexes, respectively -- than is necessary to understand their physical meaning.
The way that we resolve arguments about the world is by looking at the world. Our experience is the final arbiter of physical meaning. One problem that MWIers and eternalists have is that arguments concerning the truth or falsity of the physical states that they advocate are unresolvable.
As I understand it, the eternalist is saying that the real physical spatial configurations that correspond to the past, present, and future of the physical universe all exist simultaneously and eternally.
The presentist, on the other hand, is saying that existence is fleeting, and that the real physical spatial configuration of the universe that corresponded 5:00 pm on my clock doesn't exist by the time I percieve 5:00 pm on my clock.
Astronomers (who use SR and GR) are being presentists when they tell us that light that travelled, say, 10 light years is a record of a star or a galaxy as it existed 10 years ago.
Cosmologists (who also use SR and GR) routinely model the universe from a god's eye point of view. If the whole universe is the frame of reference, then there's no problem talking about one universal configuration corresponding to one configuration (say 5:00 pm) of some local clock.
The prima facie problem is with the eternalist who says that existence is eternal, because our experience tells us that it isn't.
Your home exists as much as my one, though I never observed your living room. Thus both have the same ontological status independently from a spatial coordinate. Relativity implies in addition that, since the spatial slicing of spacetime is arbitrary and observer-dependent, the ontological status of events must also be independent from a time coordinate.
It is indeed more compatible with everyday experience. But are quarks compatible with everyday experience? Are particle physics observations less reliable than sensory experiences of cups of tea?
The point of general relativity is precisely to say that there is no absolute "frame of the whole universe" like there was one in the Newtonian universe.
If anything anywhere changes in any way, time has lapsed. These changes only increase disorder so time only moves in one direction.
---Quote (Originally by ThomasT)---
But not independently from our experience -- and our experience is coordinate dependent.
The location in real 3D space of some extant object can't be independent of the spatial coordinates that define the location.
We make the reasonable assumption that we exist at the same time at different coordinate locations in a 3 dimensional volume bounded by our sensory experience.
Spacetime is an imaginary space.
Not with my everyday experience. But they're certainly part of the everyday experience of physicists who use QCD in their work. Don't confuse some imagined, deep reality mode of existence of quarks with their actual mode of existence which is as mathematical constructs which relate various material and instrumental manipulations and behaviors. Independent of these sorts of events in someone's sensory experience of our world quarks don't exist.
Particle physics observations and teacup observations are both time indexes of spatial configurations of our 3D world, and my guess is that particle physics observations are less ambiguously communicated than teacup observations.
xantox said:
The point of general relativity is precisely to say that there is no such "frame of the whole universe" like there was one in the Newtonian universe.
Nevertheless, the universe can be modeled as a bounded, expanding and evolving 3D volume whose internal spatial configurations are also continually changing. If you were to look at one frame of a movie of the universe, then it would show one unique spatial configuration and no others. In any specific 'now' of the universe there are no other 'nows'. If time is an idex of unique 'nows', and our collective experience seems to indicate that it is, then it would be incorrect to say that the universe, or any physical process for that matter, is 'moving through time' as the eternalist does.
Which do you like better, eternalism or presentism?
OK for the location, but let's just talk about its existence, since that's where eternalism and presentism differ. If we consider that some object at the north pole keeps existing despite we're are in another continent, the relativity of simultaneity (which is an experimental fact) indicates that it must also keep existing despite we're in another time.
I suggested that the same applies to teacups. Teacups are theoretical constructs we form in our minds to relate various manipulations with the world - whose ontology is however not in our minds (no solipsism).
But again, nothing allows to choose a preferred 3D slicing instead of another, leading to the definition of a preferred time variable. The "state of the universe at a time T" is perfectly meaningless in general relativity.
I used to dislike eternalism on the same basis one can dislike MWI at first, but afterwards found nothing wrong with it while noticing that literal presentism has a much weaker basis. However, eternalism has also various issues. This whole dichotomy will probably disappear by deepening the monolithic notion of "existence" into a much more fine-grained set of concepts.
xantox said:
OK for the loation, but let's just talk about its existence, since that's where eternalism and presentism differ. If we consider that some object at the north pole keeps existing despite we're are in another continent, the relativity of simultaneity (which is an experimental fact) indicates that it must also keep existing despite we're in another time.
We might define existence in terms of the similarities between, or degree of congruence of two spatial configurations.
Consider a freeze-frame of a movie of the spatial configurations bounded by our behavior, the various movements of you and I. In that one configuration, the readings on local clocks that you and I refer to will be different if you and I have different acceleration histories - - even if you and I started out from the same location with identical clocks with identical settings.
Nevertheless, we exist at the same time wrt a view which encompasses both of our locations -- ie., wrt a single spatial configuration that contains both of us.
Suppose we get back together and don't reset our clocks so that they show the same time, and the Earth explodes and we're blasted to smithereens. According to our local clocks, this explosion (that ended our existence) happened at different times. But to an observer on, say, the moon, you and I became smithereens at the same time.
The point is that it's reasonable to think of the universe (or any arbitrary grouping of objects therein) as a singular entity, and the evolution of the universe (or whatever) in terms of successive singular spatial configurations. If an object (a specific subset, including a proper subset, of a spatial configuration) isn't in a particular spatial configuration, and if the spatial configuration is the physical universe, then we say that the object doesn't exist.
Wrt the eternalist view, it's simply illogical to say that two different (incongruent) spatial configurations of the universe exist at the same time, if the time of the universe is it's spatial configuration (if 'a' time of the universe is a 'unique' spatial configuration), and if there is only one 'our universe'.
For the eternalist view to be coherent then, it's necessary that there be not just a larger but an infinite 'space' containing all the coexisting 'our universes'. And so time is rendered as a meaningless term. But the word, time, isn't meaningless. We use it, and it refers to something -- the question is, what?
This stuff is new to me, and I thank you for intruducing me to it. My notion of time has changed during the course of this thread.
Presentism seems to be based on the idea of time as an index. Which is what I think time is -- no more, no less, and nothing other than.
The eternalist view of time has it as some sort of 'thing' that we're traveling through.
What's the basis for this view? I suggest that it, like presentism, comes from the notion of time as an index -- it's just that the eternalist's notion of that is less clear and this lack of clarity has led to thinking of time as something more, or other than, what it is. (We do, in a sense, 'travel through' our time indexes of the world in that they are our sensory experience, and our sensory experience is the world. The meaning of 'time passing' is equally understandable.)
It would seem that both presentism and eternalism are compatible with the idea of time as an index -- just as the Copenhagen and MW interpretations of qm are both compatible with the idea of qm as a probability calculus. But in their desire to have time and qm be more that what we can unambiguously say they are, the eternalists and MWIers have succeeded only in creating unresolvable problems and clouding the issue(s).
So, in defining time as an index, we have, I think, clearly abstracted its essence.
I think a discussion along those lines might obfuscate the issue irreparably, if it isn't already.
Yes, some particular teacup (eg., the one I'm now drinking tea out of) has a different mode of existence from the concept or abstraction, 'teacup'.
The difference between teacups and, say, photons (I don't know much at all about quarks) is that the unambiguous symbolic representation, 'this' teacup, refers to a single object of the world of our sensory experience that I can pick up or point at. The unambiguous symbolic representation, 'this' photon, however, refers to a set of mathematical symbols which in turn refer to many objects of the world of our sensory experience requiring various manipulations to (maybe) produce a set of instrumental behaviors which one could then point at as, collectively, corresponding to 'this' photon.
There's no compelling reason to think that the universe isn't a bounded, expanding and evolving 3D volume whose internal spatial configuration is continually changing. So, any instantaneous 'snapshot' of its evolution should show a unique spatial configuration, just as any frame of some video you might shoot of the real world will be a unique picture.
The time (index) variables are the frames per second at which you are recording the video and the view that each snapshot encompasses (the reference frame). Elaborating how these variables affect our psychological or subjective time indexes should be an interesting exercise.
What does 'time' mean in general relativity?
Again, there is no way to define a preferred spatial configuration of the universe - just like for bread, which can be sliced in various ways, at various angles, etc so there cannot be a universal "present" slicing all observers can agree with.
More or less yes - but in one case only present events are stored in nature's books, in the other all eternal events are written there once and for all.
Physical time has an operational definition - it is the reading of clocks. However it is not necessarily something fundamental, just like snow has been found not to be a fundamental substance. The only way to know more about that, is to build physical theories and obtain experimental confirmation.
ThomasT said:
The difference between teacups and, say, photons [..]
Yes, there is a little longer chain, but it looks like there is no essential difference between manipulating of photons with photon detectors and teacups with hands and eyes (well, photons look of course different than teacups because of their non-classical behavior, but that's another story).
Nothing - it does not exist. It is not part of the fundamental theory.
I see the problem. I'm just talking about this for illustrative purposes, to sort out the logical implications. The fact that we can't actually take a picture of the whole universe is irrelevant.
Doesn't it seem sort of obvious that the latter (eternalism) is an unnecessary and unwarranted (not to mention physically meaningless) 'interpretation' -- given that they're both talking about the same thing?
Yes, we're discussing the physical meaning of the word, time. We have a general definition, an abstraction of the physical referents of time. They're indexes. The reading of 'clocks' is part of the process of generating those indexes.
I agree. Time isn't fundamental. Indexes aren't fundamental.
It could be argued that the expansion of the universe is fundamental. What do you think?
To know more about what is fundamental? Yes, I agree. There are reasons to believe that what science generally regards as fundamental might not be fundamental. But modern science is in its infancy. And advances in theory and hardware, and more and better data, will possibly lead to discoveries and realizations that are only just hinted at, or maybe not even imagined, now.
xantox said:
Yes, there is a little longer chain, but nothing fundamentally different seems to separate the manipulating of photons with photon detectors and of teacups with hands ...
The point is that we have no direct apprehension of an underlying quantum 'reality' that quantum experimental phenomena suggest exists. Anything about such a reality, even its existence, has to be inferred from our sensory experience. So, the physical meaning of 'photon' isn't some entity or other that 'exists' in some 'reality' that we can't directly apprehend. The physical meaning of 'photon' is the experimental preparations that produce events called photon detections and the mathematical schemes which relate those preparations and events.
I don't think that's true. Isn't the physical meaning of 'proper' time the same in GR as in SR -- clock readings?
