Solve for nGeometric Sequences: Solving for Number of Terms
20 replies · 3K views
nomad2817
Hi, I was trying to work out this question, but i kinda got stuck. Can anyone help me please?
Thanks
4. Find the number of terms in each of these geometric sequences.
2,10,50...1250
ar^n-1
1250=2x5^n-1
I take it you mean [itex]1250=2*5^{n-1}[/itex] with n starting at 1? You're on the right track. What is the problem with the expression you found so far? You are unable to solve it for n? Hint: logarithm
i don't get what the next step is
n is the term, but i don't know how to find it
"The term", you mean is the number of terms in the sequence. The first step in solving it is to put 5^(n-1) on one side and the other terms on the other side. Then take the logarithm on both sides.
so do i have to balance both sides and eliminate 1250?
An equation is balanced by definition. If you substitute x=5^(n-1) then the equation becomes 1250=2x. Now solve this equation for x and then back substitute x.
ps. Are you familiar with logarithms?
Thank you very much. I've just started learning about it, so I'm trying to get the hang of it, but thank you for helping me.
1250= 2x so x=1250/2 x=625
oh no, I'm getting confused again. sorry
Correct x=625 and because we substituted x=5^(n-1) we know that 5^(n-1)=625. We now want to write 625 in terms of 5 raised to a certain exponent. For example we can write 8=2^3, 125=5^3. Try to write 625 in a similar way.
Yes that is correct although not entirely what I had in mind. Note that you can write 25=5^2 therefore 25^2=(5^2)^2=5^4=625.
So now your equation becomes:
[tex] 5^{n-1}=5^4[/tex]
Therefore n-1 equals...?
No the two exponents need to be equal to each other, it is the only way the equation can hold. So I will ask you again n-1=?
What you're saying now is that 5^5=5^4. Convince yourself that this cannot be correct.
because 5^(5-1) which equals to 5^4
Well your reasoning and your answer are correct although a bit of a detour. You know that both exponents need to be the same therefore n-1=4.
ohhhhh, i see now. Thank you
