Atom Excitation: Absorption Peaks or short wavelengths?
HMS-776
I just have a quick question.
Which way of Atom Excitation is more efficient?
Photon Energy which matches the absorption peak(s)?
Or Photon energy of a Shoter wavelength than the absorbtion Peak?
Photon with a "shorter wavelength" than necessary will not "hit" the right spot... You'll surely see a response (just like you can pluck a guitar string with any frequency you'd like) but it won't be as "efficient"..
So the "resonant wavelength" will do a better job - like in many cases in quantum systems.
Can you describe "Resonant Wavelength"?
Does the resonant wavelength of an Atom change when it's excited or ionized?
What about if the atom is in an electrical field? What effect does that have?
Resonant wavelength is the wavelength of the electromagnetic radiation that exactly matches the difference of a pair of discrete energy levels of an atom...
It doesn't change for an excited atom, because an excited atoms discrete energy levels (approximately) do not change when an electron is excited.
If it's ionized however, you change the electrostatic balance between the nucleus and the electrons, therefore the exact placement of energy levels might change significantly.
For this reason, the resonant wavelength also changes.
Similarly an electric field changes the discrete spectra , time independent "perturbation theory" allows you to calculate the differences in the spectra provided that the electric field you apply is small compared to the electric fields already existing between the nucleus and the electrons.
There's no reason 'resonance' has to apply to electronic levels only. (NMR, EPR, etc)
Or Photon energy of a Shorter wavelength than the absorbtion Peak?
Hi HMS-
A very good example of this resonant absorption is the 3P-->3S sodium spectrum (the yellow doublet).
If you look at the lines with a diffraction grating you will see the yellow doublet (wavelength about 5890 Angsroms)
http://hyperphysics.phy-astr.gsu.edu/Hbase/quantum/sodium.html
with about a 5 Angstrom splitting. Each of the two lines is broadened by the temperature of the sodium gas in the arc. If you look carefully, you will see a dark absorption line in the middle of each doublet line, caused by the emission lines being strongly resonantly absorbed by the surrounding colder sodium gas.
Bob S.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
