What Are the Final Velocities After a Two-Dimensional Collision?
  • Thread starter Thread starter hdo
    Collision
In a two-dimensional collision problem, two objects, each with a mass of 6 kg, are analyzed before and after the collision. The first object moves at 3 m/s before the collision and deflects at a 40-degree angle to the left after the collision, while the second object, initially at rest, moves to the right of the first object's original path. The conservation of momentum equations for both x and y directions are applied to find the final velocities of each object. Since the masses are equal, they can be simplified out of the equations. The discussion emphasizes the importance of correctly applying the equations with the given angles to solve for the final velocities.
hdo
problem:
before - 1st object: m=6kg, v=3m/s
2nd object: m=6kg, v=0m/s
after - 1st object move off in a direction 40 degree to the left of its original path
2nd move to the right of the first's original path
find the speech of each object after the collision
equations:
x-direction: m1v1ix + m2v2ix = m1v1fx + m2v2fx
y-direction: m1v1iy + m2v2iy = m1v1fy + m2v2fy
Welcome to PF!
Hi hdo! Welcome to PF!: :smile:
(try using the X2 tag just above the Reply box :wink:)
hdo said:
… 2nd move to the right of the first's original path
Do you mean at 90º?
ok, those are the correct equations … now put the numbers in …
what do you get? :smile:
(btw, all the masses are the same, 6 kg, so you can leave them all out! :wink:)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
